v2.4.1
Ubuntu 20
sudo systemctl start caddy
k.sand-box.online {
root * /var/www/k/public/
output file /var/log/caddy/k.log
format console
My php.ini config
max_execution_time = 60
max_input_time = 60
max_input_vars = 3000
memory_limit = 512M
post_max_size = 150M
upload_max_filesize = 100M
max_file_uploads = 10
date.timezone = "Africa/Nairobi"
Hi Caddy community,
I have a Laravel application that has a form for data input. The form has an upload images feature and it to only 5 uploads only per request and image size less than 4mb.
The issue is every time there are a number of users, >40, using the form I noticed the server becomes slow and freezes. I have to stop caddy sudo service caddy stop
and start it again. If there are less users, <20, the caddy service works well.
The log error is too large and format I am not able to understand.
Is there a caddy config that can help me diagnose what may be the problem? Is there a config I may have missed out?
