v2
everything worked fine to stream my jellyfin server for abouth 3 months. suddenly stopped after an apt-get upgrade I think. but at this time i’m about 8 hours in of troubleshooting and still found nothing.
ubuntu desktop 20.04
I use caddy as a service in systemctl. It worked right a the beginning ( 3 months ago )
Paste command here.
since I purged it and reinstall it everything is ‘default’
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
listened hours and hours of movies remotely on jellyfin via caddy during 3 months untill yesterday. I cant even reach the default ‘‘Caddy’s working’’ site ( with the default Caddyfile)
no error messages.
–ports are opened and caddy is listening (used portchecker)
–firewall disabled
–systemctl status caddy reveal no errors and tell that everything is running fine (default
on :80 OR on SSL via a ddns.net address port 443 )
–looked if there is some ports conflicting each other and its look like nothing is in conflicting
–been searching on reddit github forums and so on for about 3-4 hours but caddy seems to be still relatively ‘new’ to community so havent found anything that helped me so far.
– seems like and apt-get upgrade messed up something
