Caddy is restarting
caddy:command not found
docker compose:
    image: caddy:2.4.0
      - 443:443
      - /home/mike/docker/caddy/Caddyfile:/etc/caddy/Caddyfile
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
 uname -a
Linux ubuntumedia 5.4.0-72-generic #80-Ubuntu SMP Mon Apr 12 17:35:00 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
docker-compose up -d
version: "3.7"
##########SABNZBD###############################
  sabnzbd:
    image: linuxserver/sabnzbd
    container_name: sabnzbd
      - PUID=1000
      - PGID=1000
      - TZ=America/New_York
      - UMASK=002
      - /home/mike/docker/sabnzbd:/config
      - /home/media/data/usenet:/downloads
      - 9090:9090
 ##########JELLYFIN##############################
  jellyfin:
    container_name: jellyfin
    image: linuxserver/jellyfin
     - PUID=1000
     - GUID=1000
     - /home/mike/docker/jellyfin:/config
     - /home/media:/media
    devices:
      # VAAPI Devices
      - /dev/dri/renderD128:/dev/dri/renderD128
      - /dev/dri/card0:/dev/dri/card0
##########RADARR#################################
  radarr:
    image: linuxserver/radarr
    container_name: radarr
      - PUID=1000
      - PGID=1000
      - UMASK=002
    depends_on:
      - sabnzbd
      - /home/mike/docker/radarr:/config
      - /home/media/movies:/movies
##########SONARR################################
  sonarr:
    image: linuxserver/sonarr
    container_name: sonarr
      - PUID=1000
      - PGID=1000
      - UMASK=002
    depends_on:
      - sabnzbd
      - /home/mike/docker/sonarr:/config
      - /home/media/shows:/tv
##########OMBI##################################
  ombi:
    image: linuxserver/ombi
    container_name: ombi
      - PUID=1000
      - PGID=1000
      - /home/mike/docker/ombi:/config
############CADDY###############################
    image: caddy:2.4.0
      - 443:443
      - caddy_data:/data
  caddy_data:
  caddy_config:
ombi.digitalwashu.net{
reverse_proxy 192.168.1.10:3579
jellyfin.digitalwashu.net{
reverse_proxy 192.168.1.10:8096
I’m starting caddy via docker compose. I don’t see anything listening on 443 or 80 via “netstat -tulpn”. Come to discover Caddy seems to be restarting itself. see below.
CONTAINER ID   IMAGE                  COMMAND                  CREATED         STATUS                         PORTS        NAMES
34fb3c0b0832   caddy:2.4.0            "caddy run --config …"   7 minutes ago   Restarting (1) 2 seconds ago        docker_caddy_1
1dd75493e895   linuxserver/radarr     "/init"                  24 hours ago    Up 24 hours                    0.0.0.0:7878->7878/tcp, :::7878->7878/tcp                                              radarr
5e60c28d2bd5   linuxserver/ombi       "/init"                  2 days ago      Up 24 hours                    0.0.0.0:3579->3579/tcp, :::3579->3579/tcp                                              ombi
40bc50e57f8d   linuxserver/jellyfin   "/init"                  2 days ago      Up 24 hours                    0.0.0.0:8096->8096/tcp, :::8096->8096/tcp, 8920/tcp                                    jellyfin
5f3bea616ac1   linuxserver/sonarr     "/init"                  3 days ago      Up 24 hours                    0.0.0.0:8989->8989/tcp, :::8989->8989/tcp                                              sonarr
4aa00f1c6385   linuxserver/sabnzbd    "/init"                  3 days ago      Up 24 hours                    0.0.0.0:8080->8080/tcp, :::8080->8080/tcp, 0.0.0.0:9090->9090/tcp, :::9090->9090/tcp   sabnzbd
 docker logs docker_caddy_1
{"level":"info","ts":1620772105.2475128,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: subject does not qualify for certificate: 'jellyfin.digitalwashu.net{'
{"level":"info","ts":1620772105.9857144,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772106.7414095,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772107.6775606,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772108.9979444,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772111.1251059,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772114.8487175,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772121.7703526,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772135.1207004,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772161.2734962,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772213.010025,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772273.5174444,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772334.0496645,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772394.5672925,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772455.08088,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772515.5892978,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772576.1126788,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1620772636.6482515,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
I’ve tried using various versions for the caddy image to no avail. 2.4.0-alpine, etc. btw, can I use “caddy:latest”? does that work?
You need a space before the { in the Caddyfile. Spaces are significant.
YOU’RE MY HERO. I would never have figured that out - never. Works perfectly now, all is being reverse proxied. thank you!
Caddy should not be automatically restarted if the exit code is 1. (Doing so can lead to looping. Instead, you should fix the problem before restarting.)
Unfortunately @matt this is a dumb limitation of Docker where it isn’t possible to define a restart policy that checks specific error codes. You may remember like ~4-5 years ago when I tried to do this. The next best available is unless-stopped.
Edit: here it was
