I have a Caddyfile on my VPS that uses reverse proxy for a Plex server that I use and works, however if a Plex client joins, the Plex server always shows the IP of the VPS (Tailscale VPS node) and not the remote ip of the client. I checked the Caddy logs on the VPS and the remote IP is correct for the client. Is that somehow that Caddy is passing the incorrect address on the headers ? Or do I have to add extra headers and use that parameter ?
NA
NA
NA
the Plex subdomain/domain is registered at Cloudflare and is being proxied.
plex.domain.tld:port {
reverse_proxy https://docker_tailscale_plexdirect_ipv4:port
