Caddy initial config question
my saas app have main domain and subdomain and custome domain
please help how i can config Caddy??
I moved your post to its own topic.
Please fill out the forum template and provide as much information as possible.
Thank you
You can try configuration like this
        email your@email.com
*.maindomain.local maindomain.local {
        root * /usr/local/www/public   # /usr/local/www/public is where your web root
        # php_fastcgi 127.0.0.1:9000   or  php_fastcgi unix//run/php/php8.1-fpm.sock
        # depend on you, uncomment  # to use
        # forbidden access to /privatedate/ and install.php directly, respond with HTTP 403 Forbidden
        @forbidden path /privatedata/* /install.php
        handle @forbidden {
                respond * 403
         # reverse_proxy subdomain.maindomain.local to your other server located in your local network at ip 192.168.1.100. It must be accessible locally when your browse http://192.168.1.100
        @subdomain host subdomain.maindomain.local
        handle @subdomain {
               reverse_proxy 192.168.1.100 {
                      rewrite /
       #when accessing  maindomain.com/folder1/ , following take place
        handle /folder1/* {
                respond "Hello folder1"
        try_files {path} {path}/ /index.php
www.maindomain.local {
        # redirection  https://www.mainldomain.local to https://maindomain.local
        redir https://maindoman.local
# custome domain https://custome.domain.local  will be as follow
custome.domain.local {
The above should cover what you ask.
Link below will explain it mean, and how to use it.
Cheers
i have unlimied custome domain each customer can create munti custome domain .
do custome.domain.local just for one custome domain ?
another question is , do work for all subdomain * wildcard ?
    handle @subdomain {
                  rewrite /
Please fill out the help topic template, as per the forum rules.
I’d recommend reading this guide fully:
after two day search i cant fix probleam in *.sample.com and custom domain2.com please help me
this my caddy file . just work in sample.com
sample.com *.sample.com {
        root * /var/www/html/public
        encode gzip zstd
        tls dddddd@gmail.com
        php_fastcgi unix//run/php/php8.0-fpm.sock
www.sample.ir {
       redir https://sample.com
Wildcard certificates require the DNS challenge, as stated in “Wildcard certificates” in Automatic HTTPS — Caddy Documentation and other places, including the wiki/guide, which is the topic you originally posted your post and @matt recommended you read in Caddy initial config question - #6 by matt
Are you sure php_fastcgi point it to correctly ?
Remove wildcard, and php_fastcgi , does the page load correctly with the code below ?
sample.com {
        encode gzip zstd
        tls your@email.com
        respond "Hello World!"
        #php_fastcgi unix//run/php/php8.0-fpm.sock
www.sample.ir {
i sovled dns challenge for domain and subdomain with cloadflare .
but have one problem in custome domain .
becuase each customer have self domain and subdomain . and i want to serve all thing in caddy .
please help me in this type of custome domain .
I ask again.
There’s a lot of gaps in our understanding of what you’re trying to do, and filling out the help topic template would clear a lot of that up for us.
can you explain what does this mean ?
Is my example given above able to help you ?
i have central domain (sample.com) after registration create one subdomain for each user like (ada.sample.com)
then user can change ada.sample.com to >>> doain.com or my.doain.com or other user can use self domain like dxa.com , … unlimited custome domain or subdomains
How to define the settings of these states?
	root * /var/www/public
		dns cloudflare "_H_vQajBjTvG_G-nJtF8UdZPr0kR8i8"
		resolvers 1.1.1.1
in same this tutorial Serving tens of thousands of domains over HTTPS with Caddy use this syntx
https:// {
        on_demand
    reverse_proxy localhost:9000
Now how do you combine these two?
So you want to have both a wildcard cert for your main domain, plus On-Demand TLS for domains your customers point to your server?
You’ll need two sites, one with https:// and on_demand (and you must set up an ask endpoint for On-Demand TLS – see the docs – otherwise you’re at risk of denial of service attacks), and the other site with your main + wildcard domains.
You need to enable the DNS challenge for Caddy to issue a wildcard certificate – that’s a requirement of ACME. It looks like you’re doing that with CloudFlare, so that’s good :+1:
It looks like you just posted your CloudFlare API. You’ll want to revoke that API key as soon as possible, otherwise anyone could start doing bad things with your account. You must keep your API key secret.
But again. Please, follow the forum rules, as we ask.
You must fill out the help topic template.
i solve many problem in php-fpm prmission in www-data and cady user , about this this in docs not exists ant document !!
so . custom domain get ssl but not connect to main website there are splice another website and not related to center domain
It’s not Caddy’s job to document how to run PHP. That’s out of scope.
I’m not sure what you mean.
Once again, and this is the last time I’ll ask before I lock this topic, fill out the help topic template. You’re not following the rules.
