Latest release on Docker hub.
I run this in Docker on a Linux (Debian 10) host. Compose file below.
docker-compose up --build
version: "3.7"
image: caddy:latest
- 443:443/tcp
- 80:80/tcp
- /home/penumbra/images/:/etc/images/:ro
network_mode: host
container_name: "caddy"
fastapi:
image: python:3.9.0-buster
build: .
- 9000:9000/tcp
- /home/penumbra/images/:/etc/images/:rw
network_mode: host
container_name: "fastapi"
umbra-is.gay:80, might-be.gay:80 {
header remote_addr "{header.X-Forwarded-For}"
root * /etc/images/
try_files {path} /404.html
umbra-is.gay:80/image, might-be.gay:80/image {
reverse_proxy localhost:9000
maybe.umbra-is.gay:80, maybe.might-be.gay:80 {
redir https://github.com/AbstractUmbra
The issue I’m having is that the traffic routed through Caddy to my Python application (running uvicorn) is being passed the Docker internal IP addresses, not the external ones. By setting it to network-mode: host I am able to pass the address that comes through CloudFlare, but instead I want to set the remote_addr header (I believe?) to the value of the X-Forwarded-For header and what I have currently does not achieve this.
No errors as such, all output is successful except the logging from the uvicorn app is showing the CloudFlare address(es) as it should.
I have tried using the header directive in Caddy to rewrite the remote_addr header, albeit incorrectly so far.
N/A
