I haven’t used Docker much so I’m unsure on how to set this up properly. I currently have a reverse proxy set up on my home PC but I’m migrating everything to a NAS.
I am using the official caddy image, and I’ve given it mount points /data and /config. I’m unsure on where to place the Caddyfile though. I have created a mount point for /etc and put it in the file etc/caddy/Caddyfile but it doesn’t seem to be working.
I’ve tried moving the caddyfile around in my NAS and I’m not sure how to get it to read it from Docker. It’s possible I’m missing something basic since I haven’t used Docker before a day ago.
I have Synology with few containers running, one of which is Caddy. I’m mobile now, so I’ll come back later to this thread to share details and answer how to set it up.
The way I manage containers’ data is by namespacing them into directories. I have a root directory called /docker in which all containers’ data live. I created a directory inside it, so the path becomes /docker/caddy. Caddy’s files/directories are laid out there. Thus I end up with:
/docker/caddy/config
/docker/caddy/data
/docker/caddy/etc/caddy ← put your Caddyfile here
When you launch a new container, map the directories (not files; there are 2 buttons) as follows (the entries are in the format: local => container:
/docker/caddy/config => /config
/docker/caddy/data => /data
/docker/caddy/etc/caddy => /etc/caddy
I don’t know if you’ve had these issues, but the base Synology OS owns the ports 80 and 443, so your HTTP and HTTPS ports needs to be mapped to different ports. My Caddyfile is something like this:
Again, you have to map the ports when you’re launching the new container.
I’d include screenshots, but the Synology and I are in different cities and it isn’t exposed externally (yet).
Hi, thanks for the reply. Do I need to forward those extra ports on my router? I’m at work at the moment so can’t test until I get home but just curious if I should do this also.
I believe I’ve done this but I’m getting ‘trying to solve challenge’ errors, which I believe relates to not being able to access the ports. On my router I’ve tried this:
External Port: 8080 Internal IP: Internal IP of my NAS Internal Port: 80
TCP and UDP
External Port: 8443 Internal IP: Internal IP of my NAS Internal Port: 8443
TCP and UDP
I’ve also tried changing external and IP ports around but I still get the same error.
Hmm I’ve done that and I still get connection refused on all ports. These are all the ports I have: https://i.imgur.com/1n5ALeu.png
Name : External Port : Internal IP : Internal Port
I’ve tried turning the external/internal 80 and 443 ports off and on, and leaving the ones with 443:8443/80:8080 on but no matter what combination of those I get I still get connection refused on all ports. It definitely picks up my IP address externally but just refuses to connect. Anything else I can try?
curl -v does find my host IP address: (I’ve replaced my domain and IP address)
* Rebuilt URL to: https://mydomain.ddns.net/
* Trying MY HOST IP...
* TCP_NODELAY set
* Connected to mydomain.ddns.net (MY HOST IP) port 443 (#0)
* schannel: SSL/TLS connection with mydomain.ddns.net port 443 (step 1/3)
* schannel: checking server certificate revocation
* schannel: sending initial handshake data: sending 189 bytes...
* schannel: sent initial handshake data: sent 189 bytes
* schannel: SSL/TLS connection with mydomain.ddns.net port 443 (step 2/3)
* schannel: failed to receive handshake, need more data
* schannel: encrypted data got 1414
* schannel: encrypted data buffer: offset 1414 length 4096
* schannel: next InitializeSecurityContext failed: SEC_E_UNTRUSTED_ROOT (0x80090325) - The certificate chain was issued by an authority that is not trusted.
* Closing connection 0
* schannel: shutting down SSL/TLS connection with mydomain.ddns.net port 443
* schannel: clear security context handle
curl: (77) schannel: next InitializeSecurityContext failed: SEC_E_UNTRUSTED_ROOT (0x80090325) - The certificate chain was issued by an authority that is not trusted.
And yes I have got that port forwarded to my NAS IP, still unable to connect
Means the Synology is hijacking the http call and supplying its own cert. The port forwarding table shows you’re forwarding 443 to both 443 and 8443. Keep only the latter (80 to 8080, and 443 to 8443).
* Trying MY IP...
* TCP_NODELAY set
* connect to MY IP port 443 failed: Connection refused
* Failed to connect to mydomain.ddns.net port 443: Connection refused
curl: (7) Failed to connect to mydomain.ddns.net port 443: Connection refused
Which makes me think that maybe my NAS is blocking the port or something? Do I need to enable the NAS firewall and then allow the ports? Or maybe do I need to do something in router configuration on the external access tab of control panel? Currently the only thing in that entire area is my noIP account/URL
So I have my Jellyfin server set up on Docker, which I can access using my NAS’ internal IP and the jellyfin port.
Then I have the no-ip account set up like this:
Caddy set up on Docker:
I’ve just noticed that this has port settings on here, maybe this has something to do with it? Or does the caddyfile override it?
The Caddyfile has nothing to do with Docker port mappings. You need to make sure the Docker container has the right ports mapped. The Caddyfile only controls what Caddy does, inside the container. It cannot have any effect of what happens outside the container.
Your Caddyfile doesn’t really make sense. You’re exposing container ports 80 and 443, so those are the ports on which Caddy will accept requests. Your Caddyfile can probably simply be this:
Make sure that port 80 and 443 from outside your network eventually get routed to ports 80 and 443 on the container. If you need to use ports 8080 and 8443 at your router and on your machine before it reaches the container because your machine already uses ports 80/443, that’s also probably fine. But it’s important that ports 80/443 are used so that ACME challenges properly succeed.
I’ve played around with a few caddyfiles, and even re-created the caddy container and tried different ports, none have worked, using the caddyfile above I am getting the below now though:
C:\Users\USER>curl -v https://mydomain.ddns.net
* Trying MY IP...
* TCP_NODELAY set
* Connected to mydomain.ddns.net (MY IP) port 443 (#0)
* schannel: failed to receive handshake, SSL/TLS connection failed
* Send failure: Connection was aborted
* schannel: failed to send close msg: Failed sending data to the peer (bytes written: -1)
curl: (35) schannel: failed to receive handshake, SSL/TLS connection failed
C:\Users\USER>curl -v https://mydomain.ddns.net:80
* Rebuilt URL to: https://mydomain.ddns.net:80/
* Trying MY IP...
* TCP_NODELAY set
* Connected to mydomain.ddns.net (MY IP) port 80 (#0)
* schannel: SSL/TLS connection with mydomain.ddns.net port 80 (step 1/3)
* schannel: SSL/TLS connection with mydomain.ddns.net port 80 (step 2/3)
* schannel: encrypted data got 103
* schannel: encrypted data buffer: offset 103 length 4096
* schannel: next InitializeSecurityContext failed: SEC_E_INVALID_TOKEN (0x80090308) - The token supplied to the function is invalid
* schannel: shutting down SSL/TLS connection with mydomain.ddns.net port 80
curl: (35) schannel: next InitializeSecurityContext failed: SEC_E_INVALID_TOKEN (0x80090308) - The token supplied to the function is invalid
C:\Users\USER>curl -v https://mydomain.ddns.net:443
* Rebuilt URL to: https://mydomain.ddns.net:443/
* Trying MY IP...
* TCP_NODELAY set
I’ve cleaned up all the other ports I used for my working Windows 10 reverse proxy so it is just this now:
And the logs in the Caddy container are giving me this:
2021/07/04 11:34:21.558 ERROR tls.issuance.acme looking up info for HTTP challenge {"host": "mydomain.ddns.net", "error": "no information found to solve challenge for identifier: mydomain.ddns.net"}
My container has these ports also, not sure if having this means I don’t need to set the http/s port in the file though:
I did actually have one running on my Windows 10 machine, I’ve turned it off and can access the site on 443 and 80 now, and get my responds that are in the Caddyfile, however I get connection refused on the port I am trying to reverse proxy to. I’ve tried changing the port a few times and no matter what it is I get connection refused, but a connection on 443 and 80. I’ve tried forwarding the ports in the container but that also doesn’t help https://i.imgur.com/n5EBksb.png
And also tried changing the reverse proxy block to the internal IP instead of 127.0.0.1 and I get connection refused
