Caddy & HHVM portable. Idea for plugin
I started Caddy & HHVM from Desktop in Debian. Portable.
I’m still working on the command. But the principle is that everything can be started from one folder.
EDIT. This works definitly
./hhvm0 --mode server  --config php.ini --config server.ini > /dev/null 2>&1 &
./caddy0 > /dev/null 2>&1 &
Various ideas arise in my mind.
One click WordPress :roll_eyes:
I tested yesterday and today.
Here is my (~34.7 MB) folder from the above pictures. For testing purposes. (works on Debian 8)
https://goo.gl/BvS33W
WordPress from one literally any - folder {anywhere} as a separate server. With HHVM. So you do not need even open_basedir.
Works on Raspberry Pi 3 - I tried. Can hold a blog of 200 people online.
The only thing remains to install MySQL separately.
Should be made portable MySQL also . PostgreSQL or SQLite ?
With this, it could literally be delivered preinstalled WordPress.
Self-extracting for for various systems.
Because HHVM and WP works together. The problem is that not all php software is compatible with it.
hello mikorist,
i managed to use sqlite with wordpress on my home windows server.
what you did would make a very portable wordpress setup.
1 first you install sqlite plugin for wordpress https://wordpress.org/plugins/sqlite-integration/
2 then you create db.php file in wp-content folder
3 then you add some lines to wp-config.php and voila
check this tutorial: WordPress with SQLite - Darryl Dias
