Caddy healthcheck logger
Hello All,
#1 - Problem - Health check module bloats the systemctl log files every 10 seconds saying the Host is up. host never comes down. How do I skip these log entries? The caddyfile instructions are unclear on this.
#2 - Redacted system logs because we don’t need 1000 things to prove this is repetitive.
Sep 20 23:24:15 caddy-A caddy[2555]: {"level":"info","ts":1726889055.9601016,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
st":"ussdefiant.some.tld:8006"}
Sep 20 23:24:25 caddy-A caddy[2555]: {"level":"info","ts":1726889065.9539926,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
st":"192.168.122.251:80"}
Sep 20 23:24:25 caddy-A caddy[2555]: {"level":"info","ts":1726889065.9543757,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
st":"192.168.122.250:80"}
Sep 20 23:24:25 caddy-A caddy[2555]: {"level":"info","ts":1726889065.9556007,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
st":"ussvoyager.some.tld:8006"}
Sep 20 23:24:25 caddy-A caddy[2555]: {"level":"info","ts":1726889065.9597545,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:35 caddy-A caddy[2555]: {"level":"info","ts":1726889075.9545627,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:35 caddy-A caddy[2555]: {"level":"info","ts":1726889075.9548547,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:35 caddy-A caddy[2555]: {"level":"info","ts":1726889075.9561517,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:35 caddy-A caddy[2555]: {"level":"info","ts":1726889075.960286,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","hos
Sep 20 23:24:45 caddy-A caddy[2555]: {"level":"info","ts":1726889085.9538763,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:45 caddy-A caddy[2555]: {"level":"info","ts":1726889085.9541879,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:45 caddy-A caddy[2555]: {"level":"info","ts":1726889085.955155,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","hos
Sep 20 23:24:45 caddy-A caddy[2555]: {"level":"info","ts":1726889085.9598725,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:55 caddy-A caddy[2555]: {"level":"info","ts":1726889095.9545105,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:55 caddy-A caddy[2555]: {"level":"info","ts":1726889095.9547412,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:55 caddy-A caddy[2555]: {"level":"info","ts":1726889095.9562342,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
Sep 20 23:24:55 caddy-A caddy[2555]: {"level":"info","ts":1726889095.9602382,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"host is up","ho
#3 Caddy version -
v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk= and rebuilt with cloudns and a few modules.
#4-a Installed via proxmox-ve tool scripts in an lxc container running debian 12.
#4-b - starts with systemctl
#4-c - systemctl file
root@caddy-A:~# cat /etc/systemd/system/multi-user.target.wants/caddy.service
# caddy.service
# for your installation.
Type=notify
root@caddy-A:~#
#4-d My Caddy config redacted, irrelevant sections removed. I do not have a syntax problem.
# Global
        email <REMOVED>
# Snipplts
(cloudns_default) {
                issuer acme {
                    dns cloudns {
                                                auth_id "<REMOVED>"
                                                #sub_auth_id "<num>"
                                                auth_password "<REMOVED>"
                        propagation_delay 120s
                        resolvers 185.136.96.79 1.1.1.1
        encode zstd gzip
                hostnames {args[0]}
                output file /var/log/caddy/{args[0]}.log
                format transform "{common_log}"
# default site
        root * /usr/share/caddy
# define sites
<REMOVED>
proxmox.some.tld {
        import cloudns_default proxmox.some.tld
        reverse_proxy * {
        to ussvoyager.some.tld:8006
        to ussdefiant.some.tld:8006
        lb_policy ip_hash     # Makes backend sticky based on client ip
        lb_try_duration 1s
        lb_try_interval 250ms
        health_uri /          # Backend health check path
        # health_port 80      # Default same as backend port
        health_interval 10s
        health_timeout 2s
        health_status 200
            tls_insecure_skip_verify
Please fill out the help topic template as per the forum rules.
Please mind your post’s formatting, use code blocks for config and logs, not quotes. Post your entire config, and post more of your logs.
updated …
Ah, sorry, this is a bug that got fixed on master but hasn’t been released yet.
You can build from master for the time being if you want the fix right away.
