Caddy gives errors on the most basic Caddyfile?
Cant start a caddy server. Caddy fmt keeps telling me there is an error with the the caddy file
2023/07/01 15:30:31.662 INFO    using adjacent Caddyfile
2023/07/01 15:30:31.664 WARN    Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies    {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
Error: Caddyfile:2: Caddyfile input is not formatted
installed it from the docs - the latest stable version
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy
Ubuntu 22.04, not docker
systemctl start caddy
sudo caddy reload
Second command to format the file
caddy fmt
indrajeethaldar.com {
        respond "Foo!"
None really im super confused because this was working last night?
It’s still working. It’s not an error. It’s a warning. Yeu probably have spaces instead of tabs in the second line. Run
caddy fmt --overwrite
to resolve the cause of the warning. Anyways, nothing is blocking running the server.
Hi so i tried that and it seems to run - but I see a blank page on the domain instead of “Foo”
I also tried running the actual website code
	root * /home/indrajeet/portfolio
and despite there being an index file there it seems to be giving me a blank page
/portfolio$ ls
about.html              index.html           all.html       data                    Projects                images
Okay so I’ve fixed this for me. The issue was that caddy wasnt using the correct config file. To be sure use the command (Even if you are in the same directory as the Caddyfile)
sudo caddy start --config Caddyfile
Using --config Caddyfile isn’t necessary. It is the same as the default without specifying --config.
