Caddy Server Authentication
This is a example of how to use the Caddy forward_auth directive to create a separate authentication server.
See auth-server.py and app-server.py.
Important note: The security of this example has not been independently reviewed. Use at your own risk.
Setup
This example assumes Caddy v2.5.2 or later.
Use following Caddyfile:
localhost {
forward_auth localhost:8001 {
uri /auth/check
copy_headers X-User X-Forwarded-Uri
reverse_proxy /auth/* localhost:8001
reverse_proxy localhost:8002
Start Caddy:
cd ~/GitHub/python3-experiments
./caddy run --config caddy-server-auth/Caddyfile
Start the app server in a separate terminal (port 8002):
cd ~/GitHub/python3-experiments/caddy-server-auth
python3 app-server.py
starting app server
======== Running on http://0.0.0.0:8002 ========
(Press CTRL+C to quit)
Start the auth server in another separate terminal — a TEST API token is specified for this example — in a real system the inityial token is auotmatically generated when the server starts (port 8001):
python3 auth-server.py api-bfyujsagbtnfvfwjvwfut3hiwy
starting auth server
Authorization: Bearer api-bfyujsagbtnfvfwjvwfut3hiwy
======== Running on http://0.0.0.0:8001 ========
Use your browser to view a test page — https://localhost/test.
Two TEST users are defined:
- John Smith (john@example.com / password1) with a role of admin
- Mary Jones (mary@example.com / password2) with a role of user
And a Service Account with a TEST API token of api-bfyujsagbtnfvfwjvwfut3hiwy.
Caddyfile
The Caddyfile has three parts.
forward_auth
The first part uses the route /auth/check to authenticate each request to the proxies that follow. The GET method is used so the body (if present) is not consumed. /auth/check is the verification endpoint.
forward_authforwards all requests to/auth/check.- The
X-Userheader contains some information about the authenticated user. - The
X-Forwarded-Uriheader passes the original path to the proxy servers.
uri /auth/check
Auth server
The second part is a proxy to handle all requests for the /auth route.
In this example the auth server has the following additional routes:
/auth/password-authenticate— processes the sign-in form and creates the session token and cookie/auth/sign-in— display the sign-in web page/auth/sign-out— removes the session-token and cookie
Application server
The last part of the Caddyfile passes all remaining requests to the application server.
In this example the app server has the following routes:
//admin— authorises users with a role ofadminto view the page/test/api-test— returns JSON data for api access
Browser UI
Sign-in as one of the users shown above.
API (use the api token returned when the server starts)
As well as password users, an API can access the website using the Authorization header.
When the auth server starts, it prints the Authorization which has been automatically generated or specified on the command line.
curl --header "Authorization: Bearer api-bfyujsagbtnfvfwjvwfut3hiwy" https://localhost/api-test
{"result": "ok", "title": "API Test Page"}
curl --header "Authorization: Bearer api-zzz" https://localhost/api-test
401: Unauthorized
curl --header "Authorization: Bearer api-bfyujsagbtnfvfwjvwfut3hiwy" https://localhost/zzz
404: Not Found
Notes
X-Forwarded-For header
If a request goes through multiple proxies (or one proxy multiple times), the addresses of each successive proxy is listed.
The format is:
X-Forwarded-For: <client>, <proxy1>, <proxy2>
