2.4.3, I believe
Docker compose, split over different directories.
Caddy is under the caddy dir, and other sites/apps in their own (i.e. wordpress, enclave, etc.), each containing their own docker-compose file.
Ubuntu 20.04, and Docker/Docker Compose
From within the caddy dir:
docker-compose up -d
Caddy docker-compose
version: '3.7'
image: caddy:latest
- $PWD/site:/srv
- caddy_data:/data
- caddy_config:/config
caddy_data:
caddy_config:
wordpress.domain.tld {
reverse_proxy wordpress:4000
# also tried :80/:443
enclave.domain.tld {
reverse_proxy enclave:5000
Simply put, when visiting the subdomains, I am greeted with a whitescreen, and nothing else.
The DNS does resolve successfully, as when I don’t run the Caddy container, the “site cannot be found”.
If I don’t have the DNS set up, it does to my main site (as intended).
What I would like to achieve, eventually, is to use enclave to gain access to my homeserver which is locked behind CGNAT (all inbound traffic is blocked).
I have plans to have a couple of WordPress sites too, in containers.
Concept:
Remote → DO Droplet, with Docker → Caddy send to containers → either WordPress sites, or Enclave → Home Server
I’ve tried two different tutorials (linked below), and both lead to a similar issue.
I have been able to get a successful whoami via the browser, but nothing else.
