Good day,
I’m new here and hope I can describe my problem well enough.
I recently switched from Apache2 to Caddy because security updates are important to me and this wasn’t always so easy with Apache2.
I run a simple, small web server that is only supposed to provide data for game servers like CS or Minecraft. For this I use Caddy’s integrated file server with the ability to navigate through the data (file_server browse).
This works without any problems so far, but I have problems setting the optimal security settings for the web server.
I’m in the process of restricting the HTTP headers and am stuck with the Content Security Policy (CSP). This is specifically about the entry style-src and script-src.
If I give both entries the value ‘none’, the website appears very restricted (Example 1). The following error messages can be seen in the DevTools browser (Example2):
This makes sense to me too since I don’t trust any sources. Now comes the point where I can’t get any further.
If I enter the value ‘unsafe-inline’ in both entries, the loaded images and the script on the website work again without any problems. However, I don’t think this is the right way because I’m just circumventing the problem and not solving the actual problem.
I tried to troubleshoot the problem based on the error description and, among other things, added a SHA256 hash under script-src. With the combination of style-src '‘unsafe_inline’ the website works a little better again, but certain script functions still don’t work. (For example the search field or swapping between list and GIrd - Example3).
According to the error message in the browser, I should work with the ‘unsafe-hashes’ command so that the content works. I researched it and discovered that errors occur when, for example, onload is used in the HTML file.
I looked at browse.html and found this entry at position 774.
Now I’ve reached a point where I no longer know exactly how to proceed. It could also be that I’m completely wrong and I haven’t configured something correctly.
My goal is to make my content safely available to the public and to use the given functions safely.
Thank you for reading this far.
best regards
Kevin
Refused to execute inline event handler because it violates the following Content Security Policy directive: "script-src 'sha256-8zcg0Opv8dwoY1teqFCiZwXD2LqnIwT+bwKhfGPQKeA='". Either the 'unsafe-inline' keyword, a hash ('sha256-...'), or a nonce ('nonce-...') is required to enable inline execution. Note that hashes do not apply to event handlers, style attributes and javascript: navigations unless the 'unsafe-hashes' keyword is present.
v2.7.6
I installed Caddy on a Debian 12 via this Guide: Install — Caddy Documentation
Caddy runs as a service in the background and only one domain is used:
https://downloads.armyofsinata.de
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
cat /etc/debian_version → 12.4
Caddy run as a Service.
# domain name.
downloads.armyofsinata.de {
root * /var/www/html
file_server {
browse
# php_fastcgi localhost:9000
# disable FLoC tracking
Permissions-Policy "interest-cohort=()"
# enable HSTS
# clickjacking protection
X-Frame-Options "DENY"
# restrict information
Referrer-Policy "no-referrer"
# disable URL Content
Content-Security-Policy "default-src 'none'; object-src 'none'; base-uri 'self'; frame-ancestors 'none'; img-src 'self'; font-src 'self'; style-src 'self' 'unsafe-inline'; script-src 'sha256-8zcg0Opv8dwoY1teqFCiZwXD2LqnIwT+bwKhfGPQKeA='; form-action 'self'; worker-src 'none'; frame-src 'none'; require-trusted-types-for 'script';"
# Remove Server Tag
-Server
Github - Browse.html
Beitrag zum ‘unsafe-hashes’ Eintrag:
