We have caddy on 2 servers both connected to a consul
cluster for distributed TLS storage.
Debian Linux.
/usr/sbin/caddy run -config /etc/caddyserver/caddy.json
Caddy started renewing a bounch of certificates due to expire in ~30 days and crashed.
{"level":"info","ts":1624549442.7298193,"logger":"tls.renew","msg":"acquiring lock","identifier":"dom1.eu"}
{"level":"info","ts":1624549442.745405,"logger":"tls.renew","msg":"acquiring lock","identifier":"dom2.eu"}
{"level":"info","ts":1624549442.7781668,"logger":"tls.renew","msg":"acquiring lock","identifier":"dom3.eu"}
{"level":"info","ts":1624549442.7857873,"logger":"tls.renew","msg":"acquiring lock","identifier":"dom4.eu"}
{"level":"info","ts":1624549442.7933903,"logger":"tls.renew","msg":"acquiring lock","identifier":"dom5.eu"}
{"level":"info","ts":1624549443.8955014,"logger":"tls","msg":"served key authentication certificate","server_name":"dom2.eu","challenge":"tls-alpn-01","remote":"18.197.97.115:13872","distributed":true}
{"level":"info","ts":1624549444.227819,"logger":"tls","msg":"served key authentication certificate","server_name":"dom1.eu","challenge":"tls-alpn-01","remote":"18.197.97.115:13964","distributed":true}
{"level":"info","ts":1624549444.2303605,"logger":"tls","msg":"served key authentication certificate","server_name":"dom3.eu","challenge":"tls-alpn-01","remote":"3.120.130.29:35008","distributed":true}
{"level":"info","ts":1624549444.2698698,"logger":"tls","msg":"served key authentication certificate","server_name":"dom2.eu","challenge":"tls-alpn-01","remote":"66.133.109.36:30662","distributed":true}
{"level":"info","ts":1624549444.3561459,"logger":"tls","msg":"served key authentication certificate","server_name":"dom5.eu","challenge":"tls-alpn-01","remote":"18.197.97.115:13990","distributed":true}
{"level":"info","ts":1624549444.4526017,"logger":"tls","msg":"served key authentication certificate","server_name":"dom2.eu","challenge":"tls-alpn-01","remote":"18.116.86.117:42258","distributed":true}
{"level":"info","ts":1624549444.5201306,"logger":"tls","msg":"served key authentication certificate","server_name":"dom4.eu","challenge":"tls-alpn-01","remote":"18.197.97.115:14026","distributed":true}
{"level":"info","ts":1624549444.5312564,"logger":"tls","msg":"served key authentication certificate","server_name":"dom2.eu","challenge":"tls-alpn-01","remote":"34.221.186.243:63866","distributed":true}
{"level":"info","ts":1624549445.189281,"logger":"tls","msg":"served key authentication certificate","server_name":"dom1.eu","challenge":"tls-alpn-01","remote":"18.116.86.117:42442","distributed":true}
{"level":"info","ts":1624549445.2701666,"logger":"tls","msg":"served key authentication certificate","server_name":"dom3.eu","challenge":"tls-alpn-01","remote":"3.142.122.14:16940","distributed":true}
{"level":"info","ts":1624549445.3078008,"logger":"tls","msg":"served key authentication certificate","server_name":"dom4.eu","challenge":"tls-alpn-01","remote":"3.142.122.14:16962","distributed":true}
{"level":"info","ts":1624549445.4730475,"logger":"tls","msg":"served key authentication certificate","server_name":"dom3.eu","challenge":"tls-alpn-01","remote":"66.133.109.36:30916","distributed":true}
{"level":"info","ts":1624549445.698484,"logger":"tls.renew","msg":"lock acquired","identifier":"dom2.eu"}
{"level":"info","ts":1624549445.7244895,"logger":"tls.renew","msg":"certificate appears to have been renewed already","identifier":"dom2.eu","remaining":7772397.275513487}
{"level":"info","ts":1624549445.72452,"logger":"tls.renew","msg":"releasing lock","identifier":"dom2.eu"}
fatal error: concurrent map read and map write
goroutine 942994 [running]:
runtime.throw(0x18a199d, 0x21)
runtime/panic.go:1117 +0x72 fp=0xc000067d20 sp=0xc000067cf0 pc=0x438652
runtime.mapaccess2_faststr(0x1641de0, 0xc004ab5e90, 0xc005faaae0, 0x1c, 0xc0017b5980, 0xc005024118)
runtime/map_faststr.go:116 +0x4a5 fp=0xc000067d90 sp=0xc000067d20 pc=0x414505
github.com/pteich/caddy-tlsconsul.ConsulStorage.Unlock(0x0, 0x0, 0xc0043410e0, 0xc001aa2688, 0xc004ab5e90, 0xc004bfb920, 0x19, 0x0, 0x0, 0xa, ...)
github.com/pteich/caddy-tlsconsul@v1.3.2/storage.go:87 +0x66 fp=0xc000067e70 sp=0xc000067d90 pc=0x14f70a6
github.com/pteich/caddy-tlsconsul.ConsulStorage.Lock.func1(0xc0050240c0, 0xc0015d2120, 0xc005faaae0, 0x1c)
github.com/pteich/caddy-tlsconsul@v1.3.2/storage.go:75 +0xb8 fp=0xc000067fc0 sp=0xc000067e70 pc=0x14fa3d8
runtime.goexit()
runtime/asm_amd64.s:1371 +0x1 fp=0xc000067fc8 sp=0xc000067fc0 pc=0x4728a1
created by github.com/pteich/caddy-tlsconsul.ConsulStorage.Lock
github.com/pteich/caddy-tlsconsul@v1.3.2/storage.go:73 +0x68e
goroutine 1 [select (no cases), 335 minutes]:
github.com/caddyserver/caddy/v2/cmd.cmdRun(0xc00003a240, 0x0, 0x0, 0x0)
github.com/caddyserver/caddy/v2@v2.4.3/cmd/commandfuncs.go:276 +0x1395
github.com/caddyserver/caddy/v2/cmd.Main()
github.com/caddyserver/caddy/v2@v2.4.3/cmd/main.go:85 +0x25b
main.main()
caddy/main.go:15 +0x25
goroutine 9 [select, 335 minutes]:
github.com/caddyserver/certmagic.(*RingBufferRateLimiter).permit(0xc000097180)
github.com/caddyserver/certmagic@v0.14.0/ratelimiter.go:216 +0xb2
github.com/caddyserver/certmagic.(*RingBufferRateLimiter).loop(0xc000097180)
github.com/caddyserver/certmagic@v0.14.0/ratelimiter.go:89 +0xa8
created by github.com/caddyserver/certmagic.NewRateLimiter
github.com/caddyserver/certmagic@v0.14.0/ratelimiter.go:45 +0x148
goroutine 49 [chan receive, 335 minutes]:
github.com/caddyserver/caddy/v2.trapSignalsCrossPlatform.func1()
github.com/caddyserver/caddy/v2@v2.4.3/sigtrap.go:42 +0x129
created by github.com/caddyserver/caddy/v2.trapSignalsCrossPlatform
github.com/caddyserver/caddy/v2@v2.4.3/sigtrap.go:37 +0x35
goroutine 50 [chan receive, 335 minutes]:
github.com/caddyserver/caddy/v2.trapSignalsPosix.func1()
github.com/caddyserver/caddy/v2@v2.4.3/sigtrap_posix.go:34 +0x139
created by github.com/caddyserver/caddy/v2.trapSignalsPosix
Just restarting the process so far and submitted an issue here:
https://github.com/pteich/caddy-tlsconsul/issues/18
(not sure if it’s caddy related or caddy-tlsconsul related)
