I have a Caddyfile (see below) whose only job it is to reverse proxy a bunch of localhost domains to localhost:port addresses, one backed by a nodejs server running on port 8000, and the rest backed by Docker containers. The docker ps command confirms that my containers are running, and shows correct port bindings, and loading each http://localhost: using curl works fine, resolving to the webservers running in each container.
However, caddy only works for the first two of the four reverse proxies, resolving to seemingly completely different ports and generating 502’s for the latter two others.
For completeness, the docker ps output is:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
0cd073ed4964 nodejs "sh ./run.sh" 37 hours ago Up 37 hours (healthy) 0.0.0.0:54253->8000/tcp, [::]:54253->8000/tcp nodejs
fabef5acc8ba pomax "sh ./run.sh" 37 hours ago Up 37 hours (healthy) 0.0.0.0:54191->8000/tcp, [::]:54191->8000/tcp pomax
0395f24ecdac lame "sh ./run.sh" 2 days ago Up 2 days (healthy) 0.0.0.0:57830->8000/tcp, [::]:57830->8000/tcp lame
A curl lookup for https://nodejs.app.localhost shows:
* Host nodejs.app.localhost:443 was resolved.
* IPv6: ::1
* IPv4: 127.0.0.1
* Trying [::1]:443...
* Connected to nodejs.app.localhost (::1) port 443
* CAfile: /etc/ssl/cert.pem
* CApath: none
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* (304) (IN), TLS handshake, CERT verify (15):
* (304) (IN), TLS handshake, Finished (20):
* (304) (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / AEAD-CHACHA20-POLY1305-SHA256 / [blank] / UNDEF
* ALPN: server accepted h2
* subject: [NONE]
* start date: Jul 27 12:29:41 2025 GMT
* expire date: Jul 28 00:29:41 2025 GMT
* subjectAltName: host "nodejs.app.localhost" matched cert's "nodejs.app.localhost"
* issuer: CN=Caddy Local Authority - ECC Intermediate
* SSL certificate verify ok.
* using HTTP/2
* [HTTP/2] [1] OPENED stream for https://nodejs.app.localhost/
* [HTTP/2] [1] [:method: GET]
* [HTTP/2] [1] [:authority: nodejs.app.localhost]
* [HTTP/2] [1] [:path: /]
* [HTTP/2] [1] [user-agent: curl/8.7.1]
* [HTTP/2] [1] [accept: */*]
> GET / HTTP/2
> Host: nodejs.app.localhost
> User-Agent: curl/8.7.1
* Request completely sent off
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Sun, 27 Jul 2025 16:29:21 GMT
* Connection #0 to host nodejs.app.localhost left intact
With this associated caddy error:
ERROR
http.log.error
dial tcp 127.0.0.1:56359: connect: connection refused
"request": {
"remote_ip": "::1",
"remote_port": "58506",
"client_ip": "::1",
"proto": "HTTP/2.0",
"method": "GET",
"host": "nodejs.app.localhost",
"uri": "/",
"headers": { "User-Agent": ["curl/8.7.1"], "Accept": ["*/*"] },
"tls": {
"resumed": false,
"version": 772,
"cipher_suite": 4867,
"proto": "h2",
"server_name": "nodejs.app.localhost"
"duration": 0.002264209,
"status": 502,
"err_id": "4bp27jsez",
"err_trace": "reverseproxy.statusError (reverseproxy.go:1390)"
For completeness, a curl for the associated http://localhost:54253 shows:
* Host localhost:54253 was resolved.
* IPv6: ::1
* IPv4: 127.0.0.1
* Trying [::1]:54253...
* connect to ::1 port 54253 from ::1 port 58687 failed: Connection refused
* Trying 127.0.0.1:54253...
* Connected to localhost (127.0.0.1) port 54253
> GET / HTTP/1.1
> Host: localhost:54253
< HTTP/1.1 200 OK
< X-Powered-By: Express
< Content-Type: text/html; charset=utf-8
< Content-Length: 15
< ETag: W/"f-r1NvCP6NiRUAkgXPHbwx7mVakRg"
< Date: Sun, 27 Jul 2025 16:55:43 GMT
< Connection: keep-alive
< Keep-Alive: timeout=5
Node server running on port 8000, exec for "python3 --version" shows: Python 3.12.11
This is a standard brew install on MacOS
MacOS 13.7.5 (22H527)
brew install caddy
Caddy is not being used inside a container configuration, it is simply invoked using caddy start, caddy reload, and caddy stop.
editor.com.localhost {
reverse_proxy localhost:8000
lame.app.localhost {
reverse_proxy localhost:57830
nodejs.app.localhost {
reverse_proxy localhost:54253
pomax.app.localhost {
reverse_proxy localhost:54191
No links, but the editor.com.localhost and lame.app.localhost lookups seem to work fine, resolving to services running on :8000 and :57830, but nodejs.app.localhost and pomax.app.localhost seem to use completely random ports that aren’t found anywhere in the config.
Running caddy start notes that it autosaved the config to /Users/pomax/Library/Application Support/Caddy/autosave.json but when I open that up, the ports as noted above are the same as the ports listed in that JSON file.
Running caddy reload does not change the routing behaviour
