Windows
:3333
file_server /static/* {
root ./
output file log.txt
reverse_proxy /* http://localhost:5000
I believe I’m missing some critical piece of information. I’m unable to get a Python Flask app to behave right. I just need some Caddy Guru to please review my config and tell me what I’m doing wrong. I can’t get the reverse_proxy and the file_server directive to play nicely. I need the static resources to be handled by caddy while every other path is handled by reverse proxy but caddy file_server shows 404 for files that are right there and that i can see using the file_server browse command.
My apologies if i’m not following the help template correctly. Its my first time here.
2021/08/06 18:56:16.863 error http.log.access.log0 handled request {“request”: {“remote_addr”: “[::1]:63076”, “proto”: “HTTP/1.1”, “method”: “GET”, “host”: “localhost:3333”, “uri”: “/static/images/member/4.jpg”, “headers”: {“Sec-Fetch-Dest”: [“document”], “Cache-Control”: [“max-age=0”], “Sec-Fetch-User”: ["?1"], “User-Agent”: [“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.131 Safari/537.36”], “Accept-Encoding”: [“gzip, deflate, br”], “Accept-Language”: [“en-US,en;q=0.9”], “Upgrade-Insecure-Requests”: [“1”], “Sec-Fetch-Site”: [“none”], “Sec-Fetch-Mode”: [“navigate”], “Sec-Ch-Ua”: ["“Chromium”;v=“92”, " Not A;Brand";v=“99”, “Google Chrome”;v=“92"”], “Sec-Ch-Ua-Mobile”: ["?0"], “Connection”: [“keep-alive”], “Accept”: [“text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9”]}}, “common_log”: “::1 - - [06/Aug/2021:23:56:16 +0500] “GET /static/images/member/4.jpg HTTP/1.1” 404 232”, “duration”: 0.002144, “size”: 232, “status”: 404, “resp_headers”: {“Server”: [“Caddy”, “waitress”], “Content-Length”: [“232”], “Content-Type”: [“text/html; charset=utf-8”], “Date”: [“Fri, 06 Aug 2021 18:56:16 GMT”]}}
I have tried different variations of the reverse_proxy and file_server directive and I’ve changed file paths inside my html files in order to get them to find the files. I’ve had mixed results e.g sometimes the file_server works correctly and the reverse_proxy fails whereas with other configs when the reverse_proxy works correctly the static resources are not found by caddy.
