I cannot access my HomeAssistant page externally by using my domain name (x.gmx.no). Other services like Plex, Immich, Joplin etc works just fine, they are hosted on same domain name, behind the same firewall.
HomeAssistant is also running on a separate VM, but on the same proxmox, and the same network segment. I can access HomeAssistant by using NAT and exposing the 8123 port to internet. This all worked nicely with Caddy just a few months ago, Im not sure what has changed.
Caddy log:
2025-01-13T08:59:06.107507167Z INF ts=1736758746.107299 msg=trying to solve challenge identifier=x.gmx.no challenge_type=http-01 ca=https://acme-v02.api.letsencrypt.org/directory
2025-01-13T08:59:16.358874694Z ERR ts=1736758756.3586977 msg=challenge failed identifier=x.gmx.no challenge_type=http-01 problem={"type":"urn:ietf:params:acme:error:connection","title":"","detail":"88.92.119.1: Fetching http://x.gmx.no/.well-known/acme-challenge/LV6jJnhS46Dt9cInBhFfPN51e5VBMRC9RNjZuXvkwl0: Timeout during connect (likely firewall problem)","instance":"","subproblems":null} stacktrace=github.com/mholt/acmez/v3.(*Client).pollAuthorization
github.com/mholt/acmez/v3@v3.0.0/client.go:557
github.com/mholt/acmez/v3.(*Client).solveChallenges
github.com/mholt/acmez/v3@v3.0.0/client.go:378
github.com/mholt/acmez/v3.(*Client).ObtainCertificate
github.com/mholt/acmez/v3@v3.0.0/client.go:136
github.com/caddyserver/certmagic.(*ACMEIssuer).doIssue
github.com/caddyserver/certmagic@v0.21.6/acmeissuer.go:477
github.com/caddyserver/certmagic.(*ACMEIssuer).Issue
github.com/caddyserver/certmagic@v0.21.6/acmeissuer.go:371
github.com/caddyserver/caddy/v2/modules/caddytls.(*ACMEIssuer).Issue
github.com/caddyserver/caddy/v2@v2.9.1/modules/caddytls/acmeissuer.go:249
github.com/caddyserver/certmagic.(*Config).obtainCert.func2
github.com/caddyserver/certmagic@v0.21.6/config.go:626
github.com/caddyserver/certmagic.doWithRetry
github.com/caddyserver/certmagic@v0.21.6/async.go:104
github.com/caddyserver/certmagic@v0.21.6/config.go:700
github.com/caddyserver/certmagic.(*Config).ObtainCertAsync
github.com/caddyserver/certmagic@v0.21.6/config.go:505
github.com/caddyserver/certmagic.(*Config).manageOne.func1
github.com/caddyserver/certmagic@v0.21.6/config.go:415
github.com/caddyserver/certmagic.(*jobManager).worker
github.com/caddyserver/certmagic@v0.21.6/async.go:73
2025-01-13T08:59:16.358911668Z ERR ts=1736758756.3587453 msg=validating authorization identifier=x.gmx.no problem={"type":"urn:ietf:params:acme:error:connection","title":"","detail":"88.92.119.1: Fetching http://x.gmx.no/.well-known/acme-challenge/LV6jJnhS46Dt9cInBhFfPN51e5VBMRC9RNjZuXvkwl0: Timeout during connect (likely firewall problem)","instance":"","subproblems":null} order=https://acme-v02.api.letsencrypt.org/acme/order/1919698096/343879972615 attempt=2 max_attempts=3 stacktrace=github.com/mholt/acmez/v3.(*Client).ObtainCertificate
github.com/mholt/acmez/v3@v3.0.0/client.go:152
2025-01-13T08:59:16.358917348Z ERR ts=1736758756.3587656 logger=tls.obtain msg=could not get certificate from issuer identifier=x.gmx.no issuer=acme-v02.api.letsencrypt.org-directory error=HTTP 400 urn:ietf:params:acme:error:connection - 88.92.119.1: Fetching http://x.gmx.no/.well-known/acme-challenge/LV6jJnhS46Dt9cInBhFfPN51e5VBMRC9RNjZuXvkwl0: Timeout during connect (likely firewall problem)
2025-01-13T08:59:16.358942077Z INF ts=1736758756.3588967 logger=tls.issuance.acme msg=waiting on internal rate limiter identifiers=["x.gmx.no"] ca=https://acme.zerossl.com/v2/DV90 account=espen@gmx.no
2025-01-13T08:59:16.358948008Z INF ts=1736758756.3589046 logger=tls.issuance.acme msg=done waiting on internal rate limiter identifiers=["x.gmx.no"] ca=https://acme.zerossl.com/v2/DV90 account=espen@gmx.no
2025-01-13T08:59:16.358949653Z INF ts=1736758756.3589098 logger=tls.issuance.acme msg=using ACME account account_id=https://acme.zerossl.com/v2/DV90/account/LOCD8dnnPJUqvmp0_A3Z7w account_contact=["mailto:espen@gmx.no"]
2025-01-13T08:59:19.265809788Z INF ts=1736758759.2655487 msg=trying to solve challenge identifier=x.gmx.no challenge_type=http-01 ca=https://acme.zerossl.com/v2/DV90
curl to the acme-challenge:
curl -vL https://x.gmx.no/.well-known/acme-challenge/LV6jJnhS46Dt9cInBhFfPN51e5VBMRC9RNjZuXvkwl0
* Host x.gmx.no:443 was resolved.
* IPv6: (none)
* IPv4: 88.92.119.1
* Trying 88.92.119.1:443...
* Connected to x.gmx.no (88.92.119.1) port 443
* CApath: /etc/ssl/certs
* OpenSSL/3.0.13: error:0A000438:SSL routines::tlsv1 alert internal error
* Closing connection
curl: (35) OpenSSL/3.0.13: error:0A000438:SSL routines::tlsv1 alert internal error
Caddy version:
$ docker exec caddy caddy version
Its installed in portainer. Searched for “Caddy” in the templates section, and clicked “Deploy container”
Docker running on Ubuntu VM, with proxmox as hypervisor.
# domain name.
email redacted@123.com
start.gmx.no {
reverse_proxy 10.0.10.31:3000
plex.gmx.no {
# We don't need to set the X-Forwarded-For and X-Forwarded-Proto headers
# Caddy does this automatically.
reverse_proxy 10.0.10.15:32400
prox.gmx.no {
reverse_proxy 10.0.10.30:8006
portainer.gmx.no {
reverse_proxy 10.0.10.31:9443
x.gmx.no {
reverse_proxy 10.0.10.12:8123
img.gmx.no {
reverse_proxy 10.0.10.31:2283
joplin.gmx.no {
reverse_proxy 10.0.10.31:22300
root * /usr/share/caddy
