I am trying to use Github Actions for some automation, and when I use a working Caddyfile in Github Actions it gives an error saying wrong arguments for tls
In my Caddyfile on Line 11 I commented out the tls section with environment variables and put in the actual paths and when running docker compose up in Github the error goes to the next tls section in the Caddyfile
I have echoed out the environment variables SSL_CERT_PATH and SSL_KEY_PATH by temporarily adding command: bash -c "echo $SSL_CERT_PATH" and command: bash -c "echo $SSL_KEY_PATH" section to the compose.yml and the echo is coming back with /etc/letsencrypt/cert.pem and /etc/letsencrypt/key.pem respectively.
I’d rather not hard-code the SSL cert and key paths as I want to keep them outside the Caddyfile.
Any ideas?
caddy | Error: adapting config using caddyfile: parsing caddyfile tokens for 'tls': wrong argument count or unexpected line ending after 'tls', at /etc/caddy/Caddyfile:18
Github Actions - Ubuntu latest
b. Command - GitHub Actions workflow file:
name: Docker Compose Action
on: [push]
jobs:
build:
runs-on: ubuntu-latest
steps:
- name: Checkout repo
uses: actions/checkout@v4
- name: Write key file
env:
SSL_CERT_ENCODED64: ${{ secrets.SSL_CERT_ENCODED64 }}
SSL_KEY_ENCODED64: ${{ secrets.SSL_KEY_ENCODED64 }}
run: |
echo $SSL_CERT_ENCODED64 | base64 --decode > ${HOME}/cert.pem
echo $SSL_KEY_ENCODED64 | base64 --decode > ${HOME}/key.pem
mkdir -p ${GITHUB_WORKSPACE}/docker_hosts/docker02/proxied_apps/certbot/letsencrypt
cp ${HOME}/cert.pem ${GITHUB_WORKSPACE}/docker_hosts/docker02/proxied_apps/certbot/letsencrypt/cert.pem
cp ${HOME}/key.pem ${GITHUB_WORKSPACE}/docker_hosts/docker02/proxied_apps/certbot/letsencrypt/key.pem
- name: Run docker-compose
uses: hoverkraft-tech/compose-action@v2.0.1
with:
compose-file: "./docker_hosts/docker02/proxied_apps/caddy/compose.yml"
env:
CADDY_IMAGE_VERSION: ${{ vars.CADDY_IMAGE_VERSION }}
CADDY_CLOUDFLARE_HTTPS_PROXY_PORT: ${{ vars.CADDY_CLOUDFLARE_HTTPS_PROXY_PORT }}
CADDY_HTTPS_PORT: ${{ vars.CADDY_HTTPS_PORT }}
CADDY_METRICS_PORT: ${{ vars.CADDY_METRICS_PORT }}
SSL_CERT_PATH: ${{ vars.SSL_CERT_PATH }}
SSL_KEY_PATH: ${{ vars.SSL_KEY_PATH }}
DOMAIN_NAME: ${{ secrets.DOMAIN_NAME }}
image: caddy:${CADDY_IMAGE_VERSION}
- DOMAIN_NAME=${DOMAIN_NAME}
- CADDY_CLOUDFLARE_HTTPS_PROXY_PORT=${CADDY_CLOUDFLARE_HTTPS_PROXY_PORT}
- CADDY_METRICS_PORT=${CADDY_METRICS_PORT}
- ${CADDY_HTTPS_PORT}:${CADDY_HTTPS_PORT}
- ${CADDY_METRICS_PORT}:${CADDY_METRICS_PORT}
- ${CADDY_CLOUDFLARE_HTTPS_PROXY_PORT}:${CADDY_CLOUDFLARE_HTTPS_PROXY_PORT}
- ./data:/data
- ../certbot/letsencrypt:/etc/letsencrypt
- proxy
proxy:
driver: bridge
auto_https off
servers {
metrics
admin :{$CADDY_METRICS_PORT}
# Internally Accessible Only Servers
mqtt.{$DOMAIN_NAME} {
reverse_proxy http://mqtt:18083
#tls {$SSL_CERT_PATH} {$SSL_KEY_PATH}
tls /etc/letsencrypt/cert.pem /etc/letsencrypt/key.pem
kuma.{$DOMAIN_NAME} {
reverse_proxy http://kuma:3001
homer.{$DOMAIN_NAME} {
reverse_proxy http://homer:8080
jellyfin.{$DOMAIN_NAME} {
reverse_proxy http://jellyfin:8096
paperless.{$DOMAIN_NAME} {
reverse_proxy http://paperless-ngx-webserver-1:8000
# Externalliny and Internally Accessible Servers
owncloud.{$DOMAIN_NAME}:2096 {
level INFO
output file /data/logs/caddy.log {
roll_size 10MB
roll_keep 10
reverse_proxy http://owncloud:8080 {
header_up X-Forwarded-For {http.request.header.Cf-Connecting-IP}
onlyoffice.{$DOMAIN_NAME}:2096 {
reverse_proxy http://onlyoffice
jellyfin.{$DOMAIN_NAME}:2096 {
# Uncomment this in addition with the import admin_redir statement allow access to the admin interface only from local networks
(admin_redir) {
@admin {
path /admin*
not remote_ip private_ranges
redir @admin /
vaultwarden.{$DOMAIN_NAME}:2096 {
level INFO
roll_size 10MB
roll_keep 10
encode zstd gzip
import admin_redir
reverse_proxy http://vaultwarden:80 {
header_up X-Real-IP {http.request.header.Cf-Connecting-IP}
