1. Caddy version (v2.4.6):
2. How I run Caddy:sudo caddy start
a. System environment: Archlinux, systemd, installed via arch user repository
sudo caddy start
c. Service/unit/compose file:I dont start it as service
cracken.duckdns.org {
output file C:\caddy\logs\emby_access.log {
roll true # Rotate logs, enabled by default
roll_size_mb 5 # Set max size 5 MB
roll_gzip true # Whether to compress rolled files
roll_local_time true # Use localhost time
roll_keep 2 # Keep at most 2 log files
roll_keep_days 7 # Keep log files for 7 days
reverse_proxy 192.168.0.8:8096
tls email@email.com
im using duckdns, it is pointed at my ip adress, im using this for a jellyfin server, whenever i run caddy i get this error msg (in step 4)
anyone know why im failing challenges, i tried the same methods on my main pc and it works perfectly fine.
the 80 and 443 ports are open on the ip addy
4. Error messages and/or full log output:[jelly@server:~]$ sudo caddy run - Pastebin.com
5. What I already tried:rebooting pc,
using one-liner caddy script
using different duckdns domains
trying on different pc (works)
but nothing doing none of these worked.
also, when starting caddy on my main pc, ports 80 and 443 show as open, but on my server pc they show as closed
