Caddy expose remote client
I set caddy to expose my sonarr service on mydomain.com/sonarr/ which works, but I noticed that sonarr treats this connection as a “local address” which logins are bypassed for. Since I want to attempt to keep local addresses from needing to login, this is undesirable. Is there a way to treat my client requests as local only when actually on my local network?
No errors
3. Caddy version: 2.9.1
Using docker compose
    image: caddy:latest
      - "443:443/udp"
      - ./site:/srv
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
Caddy running in Docker Desktop, host machine is Windows 11. Sonarr installed natively in Windows 11.
used above docker compose to run caddy
posted above
https://mydomain.com {
route /sonarr/* {
	reverse_proxy http://localip:localport
Caddy sends the real client’s IP via the X-Forwarded-For HTTP header. If Sonarr doesn’t use that header, it sees all connections as coming from Caddy’s local IP and treats them as local clients. In that case, you should update your Sonarr configuration to require authentication for all connections.
