Caddy does not start and gives errors about being in a read-only filesystem. It was working before, but then I think I messed up the file permsions by running sudo brew services start caddy
instead of brew services start caddy
. I can run caddy by just using caddy run --config /usr/local/etc/caddy/Caddyfile
and I get no errors.
{"level":"info","ts":1702417423.4799092,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc00050c880"}
Error: loading initial config: loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision tls: provisioning automation policy 1: loading TLS automation management module: position 0: loading module 'internal': provision tls.issuance.internal: loading pki app module: provision pki: provisioning CA 'local': generating root: saving root certificate: mkdir caddy: read-only file system
{"level":"warn","ts":1702417433.524765,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702417433.526219,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"info","ts":1702417433.531339,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702417433.531646,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0005f0b00"}
{"level":"info","ts":1702417433.532754,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0005f0b00"}
{"level":"warn","ts":1702417443.579307,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702417443.5803258,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"info","ts":1702417443.586103,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702417443.58641,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000229200"}
{"level":"info","ts":1702417443.587548,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000229200"}
{"level":"warn","ts":1702417453.634177,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702417453.63552,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"info","ts":1702417453.64098,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
{"level":"info","ts":1702417453.641263,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000408b00"}
{"level":"info","ts":1702417453.642445,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000408b00"}
{"level":"warn","ts":1702417463.6884859,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702417463.689966,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"info","ts":1702417463.695403,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702417463.695755,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004eb800"}
{"level":"info","ts":1702417463.696915,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0004eb800"}
{"level":"warn","ts":1702417473.73346,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702417473.734858,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"info","ts":1702417473.740309,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702417473.740619,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000588580"}
{"level":"info","ts":1702417473.7417102,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000588580"}
{"level":"warn","ts":1702417483.787861,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702417483.7895548,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"info","ts":1702417483.794925,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702417483.795254,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0001b6380"}
{"level":"info","ts":1702417483.796416,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0001b6380"}
{"level":"warn","ts":1702417493.843434,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702417493.8447201,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"info","ts":1702417493.850249,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702417493.850566,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000096180"}
{"level":"info","ts":1702417493.851651,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc000096180"}
{"level":"warn","ts":1702418006.9935691,"msg":"unable to determine directory for user configuration; falling back to current directory","error":"$HOME is not defined"}
{"level":"info","ts":1702418006.995017,"msg":"using provided configuration","config_file":"/usr/local/etc/caddy/Caddyfile","config_adapter":""}
{"level":"warn","ts":1702418006.997278,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/usr/local/etc/caddy/Caddyfile","line":16}
{"level":"info","ts":1702418007.000478,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1702418007.000729,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000589800"}
{"level":"info","ts":1702418007.0007339,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1702418007.0008051,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"warn","ts":1702418007.00084,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
{"level":"warn","ts":1702418007.0014741,"logger":"tls","msg":"unable to get instance ID; storage clean stamps will be incomplete","error":"open caddy/instance.uuid: no such file or directory"}
{"level":"info","ts":1702418007.001556,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1702418007.0016289,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"error","ts":1702418007.001627,"logger":"tls","msg":"could not clean default/global storage","error":"unable to acquire storage_clean lock: creating lock file: open caddy/locks/storage_clean.lock: no such file or directory"}
{"level":"info","ts":1702418007.0017002,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1702418007.0018291,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1702418007.001847,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["ssh.awesomesheep48.ca","awesomesheep48.ca"]}
{"level":"error","ts":1702418007.002037,"msg":"unable to create folder for config autosave","dir":"caddy","error":"mkdir caddy: read-only file system"}
{"level":"info","ts":1702418007.002055,"msg":"serving initial configuration"}
{"level":"warn","ts":1702418007.002064,"msg":"$HOME environment variable is empty - please fix; some assets might be stored in ./caddy"}
{"level":"error","ts":1702418007.002202,"logger":"tls","msg":"job failed","error":"ssh.awesomesheep48.ca: obtaining certificate: failed storage check: mkdir caddy: read-only file system - storage is probably misconfigured"}
{"level":"error","ts":1702418007.00224,"logger":"tls","msg":"job failed","error":"awesomesheep48.ca: obtaining certificate: failed storage check: mkdir caddy: read-only file system - storage is probably misconfigured"}
{"level":"info","ts":1702418050.627368,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1702418050.627423,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1702418050.627467,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1702418050.627681,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1702418050.627726,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
Using macOS homebrew
macOS 10.15, x86_64
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>KeepAlive</key>
<true/>
<key>Label</key>
<string>homebrew.mxcl.caddy</string>
<key>LimitLoadToSessionType</key>
<array>
<string>Aqua</string>
<string>Background</string>
<string>LoginWindow</string>
<string>StandardIO</string>
<string>System</string>
</array>
<key>ProgramArguments</key>
<array>
<string>/usr/local/opt/caddy/bin/caddy</string>
<string>run</string>
<string>--config</string>
<string>/usr/local/etc/caddy/Caddyfile</string>
</array>
<key>RunAtLoad</key>
<true/>
<key>StandardErrorPath</key>
<string>/usr/local/var/log/caddy.log</string>
<key>StandardOutPath</key>
</dict>
</plist>
awesomesheep48.ca, rebeccas-imac.local:80 {
root * /usr/local/var/www/AwesomeSheep48s-Landing
file_server browse
encode zstd gzip
import snippets/global
output file /usr/local/var/log/caddy_log
format json
snippets/global
templates #for the 'handle errors' section below
uri strip_suffix .html
try_files {path}.html {path}
Strict-Transport-Security "max-age=31536000; includeSubdomains; preload"
X-Frame-Options DENY
Referrer-Policy no-referrer
Permissions-Policy interest-cohort=()
handle_errors {
respond "{http.error.status_code} {http.error.status_text}"
encode zstd gzip #zstd is better, but not every browser supports it
