Trying to connect caddy to a websocket. The backend is activemq, and it is working with apache and nginx.
For some reason caddy returns 404.
The backend is working
Not working from caddy, working from apache (I had to edit to image because I am only allowed one image):
just caddy run
the caddy.exe file
http://127.0.0.1 {
reverse_proxy /mq* 127.0.0.1:43020 {
header_up Connection {>Connection}
header_up Upgrade {>Upgrade}
header_up Sec-WebSocket-Key {>Sec-WebSocket-Key}
header_up Sec-WebSocket-Version {>Sec-WebSocket-Version}
header_up Sec-WebSocket-Protocol "v10.stomp"
reverse_proxy /* 127.0.0.1:8080 {
header_up Host {host}
output file "c:\Programs\caddy_2.7.6_windows_amd64\logs\caddy_access.log"
level ERROR
format json
