I’m kind of new to TLS but I have a cert from GoDaddy for my domain. I can use it no problem in Apache2 by using the SSLCertificateChainFile
option for the vhost, but I’m having trouble getting it to work in caddy.
Here are the files I have (Located in /etc/ssl
- mydomain.net.crt
- mydomain.net.key
- gd_bundle-g2-g1.crt
Here is my Caddyfile:
mydomain.net {
root /var/www/mydomain
tls /etc/ssl/mydomain.net.crt /etc/ssl/mydomain.net.key
It works fine in Chrome on my Mac but Linux complains when using curl:
curl: (60) server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none
I got the same error while using apache2 until I added SSLCertificateChainFile /etc/ssl/gd_bundle-g2-g1.crt
to my vhosts config.
Just to review: Using the same crt and key files (except for gd_bundle-g2-g1.crt
which I do not know how to use in caddy) curl in linux works with apache and does not with caddy.
Any suggestions?
