Ubuntu 20.04.3 via systemd
/usr/bin/caddy run --environ --config /media/data/1/git/peet_homeautomation/server_configs/kuat_config/Caddyfile
# caddy.service
# for your installation.
ExecStart=/usr/bin/caddy run --environ --config /media/data/1/git/peet_homeautomation/server_configs/kuat_config/Caddyfile
ExecReload=/usr/bin/caddy reload --config /media/data/1/git/peet_homeautomation/server_configs/kuat_config/Caddyfile
email my-email@gmail.com
# Snippets
####### Snippet 1 #######
(trustedlocations) {
@untrusted not remote_ip IP_ADDRESS_LIST
basicauth @untrusted {
USERNAME HASH_PASSWORD
(mylocations) {
import trustedlocations
reverse_proxy /sonarr* 127.0.0.1:8990 { # https://sonarr.tv/
reverse_proxy /radarr* 127.0.0.1:7880 { # https://github.com/Radarr/Radarr
portainer.dpeet.net {
reverse_proxy 127.0.0.1:9000 {
ha.dpeet.net {
reverse_proxy 10.0.2.40:8123
I have Eero routers, and when I activate Eero secure they take over the DNS to provide threat detection and adblocking. On reddit they have said “Eero secure hijacks all dns requests made by clients regardless of the dns settings. The gateway eero sends all dns requests through an encrypted tunnel to Zscaler where they are inspected. In that sense, the dns settings on clients doesn’t really matter (unless your using a pihole or something where the dns is a local IP).” and “It will, and does. It’ll block anything on port 53 and it also sets a DoH canary that should stop most browsers from doing DoH.”
Navigating to my websites (ie portainer.dpeet.net or dpeet.net/sonar) I’ll get the error
“Your connection is not private. NET::ERR_CERT_COMMON_NAME_INVALID”
under more information it says
“This server could not prove that it is portainer.dpeet.net; its security certificate is from dns1.eerodns.com.”
I called Eero and they said it wasn’t their fault and to contact my system admin… Any hope that I can configure this to work with caddy?
