Caddy duckdns jellyfin
I want to connect jellyfin outside my home. I have caddy.exe with duckdns module. My ports 80 and 443 are closed (dont know why) but have ports 9000 for jellyfin and 8000 (http) and 4443 (https) for caddy.
c:\Caddy>caddy run
2025/07/20 00:29:25.474 ←[34mINFO←[0m   maxprocs: Leaving GOMAXPROCS=12: CPU quota undefined
2025/07/20 00:29:25.475 ←[34mINFO←[0m   GOMEMLIMIT is updated   {"package": "github.com/KimMachineGun/automemlimit/memlimit", "GOMEMLIMIT": 7660685721, "previous": 9223372036854775807}
2025/07/20 00:29:25.478 ←[34mINFO←[0m   using adjacent Caddyfile
2025/07/20 00:29:25.484 ←[34mINFO←[0m   adapted config to JSON  {"adapter": "caddyfile"}
2025/07/20 00:29:25.484 ←[33mWARN←[0m   Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies    {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2025/07/20 00:29:25.496 ←[34mINFO←[0m   admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["//[::1]:2019", "//127.0.0.1:2019", "//localhost:2019"]}
2025/07/20 00:29:25.498 ←[34mINFO←[0m   tls.cache.maintenance   started background certificate maintenance      {"cache": "0xc0001d8d00"}
2025/07/20 00:29:25.498 ←[34mINFO←[0m   http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 4443}
2025/07/20 00:29:25.498 ←[34mINFO←[0m   http.auto_https enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2025/07/20 00:29:25.499 ←[33mWARN←[0m   http    HTTP/2 skipped because it requires TLS  {"network": "tcp", "addr": ":8000"}
2025/07/20 00:29:25.499 ←[33mWARN←[0m   http    HTTP/3 skipped because it requires TLS  {"network": "tcp", "addr": ":8000"}
2025/07/20 00:29:25.499 ←[34mINFO←[0m   http.log        server running  {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2025/07/20 00:29:25.499 ←[34mINFO←[0m   http    enabling HTTP/3 listener        {"addr": ":4443"}
2025/07/20 00:29:25.500 ←[34mINFO←[0m   http.log        server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2025/07/20 00:29:25.501 ←[34mINFO←[0m   http    enabling automatic TLS certificate management   {"domains": ["peyeyo1958.duckdns.org"]}
2025/07/20 00:29:25.504 ←[33mWARN←[0m   tls     stapling OCSP   {"error": "no OCSP stapling for [peyeyo1958.duckdns.org]: no OCSP server specified in certificate", "identifiers": ["peyeyo1958.duckdns.org"]}
2025/07/20 00:29:25.521 ←[34mINFO←[0m   autosaved config (load with --resume flag)      {"file": "C:\\Users\\O\\AppData\\Roaming\\Caddy\\autosave.json"}
2025/07/20 00:29:25.521 ←[34mINFO←[0m   serving initial configuration
2025/07/20 00:29:25.522 ←[34mINFO←[0m   tls     storage cleaning happened too recently; skipping for now        {"storage": "FileStorage:C:\\Users\\O\\AppData\\Roaming\\Caddy", "instance": "34d1ace2-259a-4f56-b022-90abbefc6909", "try_again": "2025/07/21 00:29:25.522", "try_again_in": 86400}
2025/07/20 00:29:25.526 ←[34mINFO←[0m   tls     finished cleaning storage units
Caddy: v2.10.0
Windows 10 64bit (up to date)
http_port 8000
https_port 4443
peyeyo1958.duckdns.org {
    reverse_proxy localhost:9000
I made the caddy.exe with xcaddy and Go.
I think I built it with " go install github.com/caddyserver/xcaddy/cmd/xcaddy@latest then xcaddy build
–with GitHub - caddy-dns/duckdns: Caddy module: dns.providers.duckdns " .
Neither of these two ports seems to be open. Make sure your router is configured to port-forward them to the server running Caddy.
Also, if this is your complete Caddyfile, it doesn’t look like you’re using the DuckDNS module at all … or at least, you haven’t configured it.
Thanks for the reply. I ended up using Tailscale.
