Caddy - duckdns for internal only on Synology NAS
1. Caddy version:
2.6.4
Downloaded from caddyserver.com with duckdns add on
Synology DSM 7.1.1-42962 Update 4 using Docker
sudo docker-compose up -d
version: '3'
  vaultwarden:
    image: vaultwarden/server:latest
    container_name: vaultwarden
    restart: always
      WEBSOCKET_ENABLED: "true"  # Enable WebSocket notifications.
      - ./vw-data:/data
    image: caddy:2
    restart: always
      - ${CADDY_HTTP_PORT}:80
      - ${CADDY_HTTPS_PORT}:443
      - ./caddy:/usr/bin/caddy  # Your custom build of Caddy.
      - ./caddy-config:/config
      - ./caddy-data:/data
      DOMAIN: $DUCKDNS_DOMAIN  # Your domain.
      EMAIL: $EMAIL                 # The email address to use for ACME registration.
      TOKEN: $DUCKDNS_TOKEN                   # Your Duck DNS token.
      LOG_FILE: "/data/access.log"
{$DOMAIN}:443 {
    level INFO
    output file {$LOG_FILE} {
      roll_size 10MB
      roll_keep 10
  # Use the ACME DNS-01 challenge to get a cert for the configured domain.
    dns duckdns {$TOKEN}
  # This setting may have compatibility issues with some browsers
  # (e.g., attachment downloading on Firefox). Try disabling this
  # if you encounter issues.
  # Notifications redirected to the WebSocket server
  reverse_proxy /notifications/hub vaultwarden:3012
  # Proxy everything else to Rocket
  reverse_proxy vaultwarden:80
Everything appears to go well but I am unable to open the web page with the following error:
This site can’t provide a secure connection
192.168.1.216 sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
{"level":"warn","ts":1676558976.7078424,"logger":"http.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-staging-v02.api.letsencrypt.org/directory","error":"performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:35696->127.0.0.11:53: i/o timeout"}
{"level":"error","ts":1676558997.2154634,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"bwc-vw.duckdns.org","issuer":"acme-v02.api.letsencrypt.org-directory","error":"registering account [] with server: provisioning client: performing request: Get \"https://acme-staging-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-staging-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:47122->127.0.0.11:53: i/o timeout"}
{"level":"warn","ts":1676558997.2156646,"logger":"tls.issuance.zerossl","msg":"missing email address for ZeroSSL; it is strongly recommended to set one for next time"}
{"level":"error","ts":1676559007.2246764,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"bwc-vw.duckdns.org","issuer":"acme.zerossl.com-v2-DV90","error":"account pre-registration callback: performing EAB credentials request: Post \"https://api.zerossl.com/acme/eab-credentials-email\": dial tcp: lookup api.zerossl.com on 127.0.0.11:53: read udp 127.0.0.1:36016->127.0.0.11:53: i/o timeout"}
I have uninstalled docker completely and reinstalled everything. I’m still getting the same error.
My issue has been resolved. Firewall was blocking port 80.
