Caddy domain not accessible when using DDNS
I want my docker app (emby) that’s exposed to internet to be accessible with portless caddy domain however I can’t get it working no matter what. Simply said, currently it’s accessible from:
http://app.example.domain:port
I want it to be accessible like this:
https://app.example.domain
Other info:
I use cloudflare to set DNS records
I use dynamic_dns plugin in caddy for my emby domain
All my containers are in caddy_network, emby is pingable and accessible within caddy network
I have open port 8096
I use Tailscale VPN for my other docker apps, so why I am not using it on emby? Because if I go somewhere else, into hotels, friends house, I want to simply install emby on TV and connect to my domain, Tailscale is not avaiable on TVs as far as I know.
No errors
I’ve built my own dockerfile with plugins I needed - dynamicdns, cloudflare, sablier, run with docker run
ARG CADDY_VERSION=2.9.1
FROM caddy:${CADDY_VERSION}-builder AS builder
ADD https://github.com/sablierapp/sablier.git /sablier
RUN xcaddy build \
    --with github.com/sablierapp/sablier/plugins/caddy=/sablier/plugins/caddy \
	--with github.com/mholt/caddy-dynamicdns
Device: Raspberry Pi 5
OS: Raspberry OS 64-bit
Using docker
    image: caddy:cloudflare-sablier
      - caddy_network
      - "8082:80"
      - "2019:2019"
      - /DATA/AppData/caddy:/data
      - /DATA/AppData/caddy/conf/Caddyfile:/etc/caddy/Caddyfile
	admin 0.0.0.0:2019 # Allow external API access
	acme_dns cloudflare {env.CLOUDFLARE_ZONE_TOKEN}
	order sablier before reverse_proxy
	email my@email.com
	dynamic_dns {
		provider cloudflare {env.CLOUDFLARE_ZONE_TOKEN}
		domains {
			example.domain emby
		versions ipv4
		check_interval 1m
		ttl 5m
emby.example.domain {
	reverse_proxy emby:8096
	handle_errors {
		respond "{err.status_code} {err.status_text}"
These together are dangerous if your machine is exposed to the Internet because it means anyone in the World can configure your Caddy instance
Why 8082?
You need to allow ports 80 and 443
  1. what do you mean anyone can configure my Caddy instance, only port that is open to internet is 8096 which is for Emby only, other than that they are safe in my docker network
  2. Port 8082, I just came up with random port because port 80 is already allocated by Pihole container
  3. Allow ports 80 and 443 in terms of opening them in router? Isn’t that unsafe?
You’re exposing it in the docker-compose config, so it’s available outside the container. If that’s still strictly within your LAN, then it’s fine (depending on your threat model, though not as risky).
Alright, as long as you’re forwarding port 80 on the router to this port.
Define unsafe. What are you considering as risk? There’s no connectivity from the outside without ports. What you call “portless” is not without port, rather there’s an implicit assumed port (80 for HTTP, and 443 for HTTPS). You don’t want to use tunneling solution, so you’ll have to expose 80 and 443 to the outside.
So I exposed ports 8082 and 443, but now when accessing url I get bad gateway error.
You must expose 80 as well, not 8082.
Same error with port 80 open, but 8082 is pointing to port 80 inside Caddy container
What’s your port forwarding rule? Port 80 on the router must forward to 8082
Still bad gateway error
Router:
https://imgur.com/a/kaICncI
Caddy:
https://imgur.com/aJIJb53
After restarting Emby it now works, however I don’t understand why can’t port 443 be mapped to something different, like I have port 80 mapped to 8082 and it works fine, but when I try to map port 443 to 8443, Emby will no longer be accessible.
You should be able to. Ensure that the external Docker port matches the internal port stated in your router port forwarding config, but the router’s external port must be 443.
