v.2.4.6
systemd
Manjaro Gnome.
systemctl start caddy.service
The one came with the distribution package.
# caddy.service
# for your installation.
Description=Caddy web server
After=network-online.target
StartLimitIntervalSec=14400
StartLimitBurst=10
Environment=XDG_DATA_HOME=/var/lib
Environment=XDG_CONFIG_HOME=/etc
ExecStartPre=/usr/bin/caddy validate --config /etc/caddy/Caddyfile
ExecStopPost=/usr/bin/rm -f /run/caddy/admin.socket
# Do not allow the process to be restarted in a tight loop. If the
# process fails to start, something critical needs to be fixed.
Restart=on-abnormal
# Use graceful shutdown with a reasonable timeout
# Hardening options
DevicePolicy=closed
LockPersonality=true
MemoryAccounting=true
MemoryDenyWriteExecute=true
NoNewPrivileges=true
PrivateDevices=true
ProcSubset=pid
ProtectClock=true
ProtectControlGroups=true
ProtectHome=true
ProtectHostname=true
ProtectKernelLogs=true
ProtectKernelModules=true
ProtectKernelTunables=true
ProtectProc=invisible
ProtectSystem=strict
RemoveIPC=true
ReadWritePaths=/var/lib/caddy /var/log/caddy /run/caddy
RestrictNamespaces=true
RestrictRealtime=true
RestrictSUIDSGID=true
# The configuration below serves a welcome page over HTTP on port 80.
# domain name.
# https://caddyserver.com/docs/caddyfile/concepts#addresses
# Restrict the admin interface to a local unix file socket whose directory
# is restricted to caddy:caddy. By default the TCP socket allows arbitrary
# modification for any process and user that has access to the local
# interface. If admin over TCP is turned on one should make sure
# implications are well understood.
admin "unix//run/caddy/admin.socket"
git.nas3.noom.home {
tls internal
respond "Hello"
The service does not start.
ม.ค. 29 22:04:15 nas3 systemd[1]: Starting Caddy web server...
ม.ค. 29 22:04:15 nas3 caddy[5146]: {"level":"info","ts":1643468655.6806788,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
ม.ค. 29 22:04:15 nas3 caddy[5146]: {"level":"warn","ts":1643468655.6811702,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":13}
ม.ค. 29 22:04:15 nas3 caddy[5146]: {"level":"info","ts":1643468655.6813505,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003eb570"}
ม.ค. 29 22:04:15 nas3 caddy[5146]: {"level":"info","ts":1643468655.681369,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003eb570"}
ม.ค. 29 22:04:15 nas3 caddy[5146]: validate: loading http app module: provision http: getting tls app: loading tls app module: provision tls: provisioning automation pollicy 0: loading TLS automation management module: position 0: loading module 'internal': provision tls.issuance.internal: loading pki app module: provision pki: provisionioning CA 'local': parsing root certificate PEM: no PEM block found
ม.ค. 29 22:04:15 nas3 systemd[1]: caddy.service: Control process exited, code=exited, status=1/FAILURE
ม.ค. 29 22:04:15 nas3 systemd[1]: caddy.service: Failed with result 'exit-code'.
ม.ค. 29 22:04:15 nas3 systemd[1]: Failed to start Caddy web server.
- Remove the
tls internaland it starts. - Also running the command directly
caddy startwith the same config file will start as well. - changing the permission of
/root/.local/share/caddy/**/does not help, same error. - Run
# XDG_DATA_HOME=/var/lib caddy trustas per Caddy - ArchWiki suggestions.
