Caddy Does Not Auto Redirect from HTTP to HTTPS
Caddy does not auto redirect from HTTP to HTTPS.
● caddy.service - Caddy
     Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
     Active: active (running) since Sat 2023-03-04 18:57:38 CST; 2min 46s ago
   Main PID: 2732 (caddy)
      Tasks: 8 (limit: 2160)
     Memory: 10.0M
        CPU: 65ms
             └─2732 /usr/bin/caddy run --environ --config /etc/caddy/Caddyfile
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.0060575,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.0061102,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.0061612,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.0061824,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.006288,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.0063279,"msg":"serving initial configuration"}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.0065663,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0001f73b0"}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.0065904,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ caddy[2732]: {"level":"info","ts":1677927458.006751,"logger":"tls","msg":"finished cleaning storage units"}
Mar 04 18:57:38 iZj6cel50obn3u2xe5n08jZ systemd[1]: Started Caddy.
Ubuntu 22.04
systemd
# caddy.service
# for your installation.
Type=notify
PrivateDevices=yes
# domain name.
	root * /usr/share/caddy
	# php_fastcgi localhost:9000
hk.zimoe.com {
	root * /var/www/html
	tls /var/local/hk.zimoe.com_bundle.crt /var/local/hk.zimoe.com.key
Caddy works! (zimoe.com)
ガーリッシュ ナンバー 公式ホームページ|TBSテレビ (zimoe.com)
I have another server with a Caddyfile as below, it does not have this problem:
# domain name.
us1.chitose.ml, chitose.ml, us.zimoe.com {
	tls ricky50575@gmail.com
	reverse_proxy /chitose 127.0.0.1:11314 {
			versions h2c
Caddy 2.6.2
I resolved this problem as below, but I do not know why it performs differently between my two servers:
# domain name.
http://hk.zimoe.com {
  redir https://{host}{uri} permanent
https://hk.zimoe.com {
Remove this from your config. This is preventing HTTP redirects from working.
You’re not meant to leave this in your config, you’re meant to replace it with your own config.
This is right; but to elaborate, it’s because you’re explicitly listening and serving sites on the HTTP port, port 80, for all hostnames, so your explicit configuration overrides implicit redirects.
