Im using caddy to reverse proxy a gitea-instance to the internet. This is working as intended and without any issues.
When im trying to access this site via another subnet, caddy does not seem to answer any requests. I have a DNS override in opnsense, that redirects my gitea-domain to the internal ip. I can see in the firewall that requests (curl, telnet) are not beeing blocked between the two nets.
No error messages are visible in caddylog, even with debug loggin enabled. I can however see the connection when using tcpdump.
v2.7.6 with plugins for wildcard dns validation
Centos 9 Stream, native as a systemd service.
systemctl start caddy.service
# caddy.service
# for your installation.
Type=notify
PrivateDevices=yes
pw.domain1.de {
@admin {
path /admin*
redir @admin /
reverse_proxy 192.168.169.5:10008 {
reverse_proxy /notifications/hub 192.168.169.5:10009
reverse_proxy /notifications/hub/negotiate 192.168.169.5:10008
pwadmin.domain1.de {
import /etc/caddy/caddy_certauth
reverse_proxy 192.168.169.5:10008/admin
todo.domain1.de {
import /etc/caddy/caddy_securityheaders
reverse_proxy 192.168.169.5:3456
wiki.domain1.de {
reverse_proxy 192.168.169.5:10001
gitea.domain2.de {
reverse_proxy 192.168.169.5:3000
sync.domain1.de {
reverse_proxy 192.168.169.5:10002
domain3.de {
@blocked {
path /xmlrpc.php
respond @blocked 404
reverse_proxy 192.168.169.5:10003
*.domain2.de {
issuer acme {
dns netcup {
customer_number secret
api_key secret
api_password secret
resolvers 8.8.8.8 1.1.1.1
propagation_timeout 30m
propagation_delay 25m
@invidious host invidious.domain2.de
handle @invidious {
reverse_proxy 192.168.169.20:3000
@beatbump host beatbump.domain2.de
handle @beatbump {
reverse_proxy 192.168.169.20:3001
@wedding host wedding.domain2.de
handle @wedding {
reverse_proxy 192.168.169.5:10006
the caddy_securityheaders
### caddy security via https://caddyserver.com/docs/caddyfile/directives/header
# disable FLoC tracking
Permissions-Policy interest-cohort=()
# enable HSTS
# clickjacking protection
X-Frame-Options DENY
### additional security via https://cyberhost.uk/caddy-advanced-setup/
X-XSS-Protection "1; mode=block;"
X-Robots-Tag none
