Where are you using the generate/maintain Caddy docs? Our small IT department is looking to migrate technical documentation to markdown, and Caddy docs look awesome!
The Caddy docs are manually built using HTML because, well, I prefer it and it works around a few limitations to Markdown that we need to overcome. But Caddy’s Markdown direcrtive is pretty great; you can use it to easily render Markdown files using just one line in your Caddyfile!
