Caddy Docker upgrade 2.10.0
Apparently there is no new docker image ?
how to upgrade from 2.9 to 2.10 ?
NA
v2.9.1
docker compose
debian 12
NA
    container_name: caddy_ext
    image: caddy:latest
      - 2019:2019
      - 443:443/tcp
      - 443:443/udp
      - ./caddy-config:/config
      - ./caddy-data:/data
      - ./index.html:/usr/share/caddy/index.html
      - /root/SSL:/root/SSL
      - default
    healthcheck:
      test: wget --quiet --tries=1 --spider http://localhost:2019/metrics|| exit 1
      interval: 10s
      timeout: 30s
      retries: 10
      start_period: 180s
    labels:
      - autoheal=true
  default:
    enable_ipv6: true
NA
NA
Docker release process is outside our control. We’re waiting on the Docker team.
Thé image is published
Is there something special to do ?
Compose modification ? .env ?
Thank you
You’ll have to run docker compose pull, though it’s strongly unadvisable to use latest.
OK thanks
so version 2.10 then
