Caddy-docker-proxy as reverse proxy for multiple containers which are in their own network
So, I’d like to have each container (if possible) in their own network (to improve security) but I’d still like caddy to be able to be used as a reverse proxy. However, caddy isn’t able to get the upstream port. I’ve also tried to add the caddy_ingress_network label for each container as explained here:
You can also specify the ingress network per container/service by adding to it a label caddy_ingress_network with the network name.
It still doesn’t work though.
{“level”:“info”,“ts”:1769472804.2777095,“logger”:“docker-proxy”,“msg”:“Running caddy proxy server”}
{“level”:“info”,“ts”:1769472804.2782907,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“localhost:2019”,“enforce_origin”:false,“origins”:\[“//localhost:2019”,“//\[::1\]:2019”,“//127.0.0.1:2019”\]}
{“level”:“info”,“ts”:1769472804.2783718,“msg”:“autosaved config (load with --resume flag)”,“file”:“/config/caddy/autosave.json”}
{“level”:“info”,“ts”:1769472804.2783754,“logger”:“docker-proxy”,“msg”:“Running caddy proxy controller”}
{“level”:“info”,“ts”:1769472804.2977865,“logger”:“docker-proxy”,“msg”:“Start”,“CaddyfilePath”:“”,“EnvFile”:“”,“LabelPrefix”:“caddy”,“PollingInterval”:30,“ProxyServiceTasks”:true,“ProcessCaddyfile”:true,“ScanStoppedContainers”:false,“IngressNetworks”:“\[caddy homarr grafana\]”,“DockerSockets”:\[“”\],“DockerCertsPath”:\[“”\],“DockerAPIsVersion”:\[“”\]}
{“level”:“info”,“ts”:1769472804.2983391,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769472804.2983522,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“info”,“ts”:1769472804.419844,“logger”:“docker-proxy”,“msg”:“IngressNetworksMap”,“ingres”:“map[ ]”}
{“level”:“info”,“ts”:1769472804.4418063,“logger”:“docker-proxy”,“msg”:“Swarm is available”,“new”:false}
{“level”:“warn”,“ts”:1769472804.446003,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“info”,“ts”:1769472804.4475465,“logger”:“docker-proxy”,“msg”:“New Caddyfile”,“caddyfile”:“http://browse.pc.vpn.tornaxo7.de {\\n\\tencode\\n\\tfile_server browse\\n\\troot /browse\\n}\\nhttp://homarr.pc.vpn.tornaxo7.de {\\n\\treverse_proxy\\n}\\nhttp://pc.vpn.tornaxo7.de {\\n\\tencode\\n\\tfile_server\\n}\\n”}
{“level”:“info”,“ts”:1769472804.447816,“logger”:“docker-proxy”,“msg”:“New Config JSON”,“json”:“{"apps":{"http":{"servers":{"srv0":{"listen":\[":80"\],"routes":\[{"match":\[{"host":\["browse.pc.vpn.tornaxo7.de"\]}\],"handle":\[{"handler":"subroute","routes":\[{"handle":\[{"handler":"vars","root":"/browse"},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":\["zstd","gzip"\]},{"browse":{},"handler":"file_server","hide":\["./Caddyfile"\]}\]}\]}\],"terminal":true},{"match":\[{"host":\["homarr.pc.vpn.tornaxo7.de"\]}\],"handle":\[{"handler":"subroute","routes":\[{"handle":\[{"handler":"reverse_proxy"}\]}\]}\],"terminal":true},{"match":\[{"host":\["pc.vpn.tornaxo7.de"\]}\],"handle":\[{"handler":"subroute","routes":\[{"handle":\[{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":\["zstd","gzip"\]},{"handler":"file_server","hide":\["./Caddyfile"\]}\]}\]}\],"terminal":true}\]}}}}}”}
{“level”:“info”,“ts”:1769472804.4478369,“logger”:“docker-proxy”,“msg”:“Sending configuration to”,“server”:“localhost”}
{“level”:“info”,“ts”:1769472804.448194,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:“/load”,“remote_ip”:“127.0.0.1”,“remote_port”:“34892”,“headers”:{“Accept-Encoding”:\[“gzip”\],“Content-Length”:\[“810”\],“Content-Type”:\[“application/json”\],“User-Agent”:\[“Go-http-client/1.1”\]}}
{“level”:“info”,“ts”:1769472804.448607,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“localhost:2019”,“enforce_origin”:false,“origins”:\[“//localhost:2019”,“//\[::1\]:2019”,“//127.0.0.1:2019”\]}
{“level”:“warn”,“ts”:1769472804.4486856,“logger”:“http.auto_https”,“msg”:“server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server”,“server_name”:“srv0”,“http_port”:80}
{“level”:“info”,“ts”:1769472804.4487653,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc000681080”}
{“level”:“warn”,“ts”:1769472804.4488668,“logger”:“http”,“msg”:“HTTP/2 skipped because it requires TLS”,“network”:“tcp”,“addr”:“:80”}
{“level”:“warn”,“ts”:1769472804.4488697,“logger”:“http”,“msg”:“HTTP/3 skipped because it requires TLS”,“network”:“tcp”,“addr”:“:80”}
{“level”:“info”,“ts”:1769472804.448871,“logger”:“http.log”,“msg”:“server running”,“name”:“srv0”,“protocols”:\[“h1”,“h2”,“h3”\]}
{“level”:“info”,“ts”:1769472804.4489605,“msg”:“autosaved config (load with --resume flag)”,“file”:“/config/caddy/autosave.json”}
{“level”:“info”,“ts”:1769472804.4489646,“logger”:“admin.api”,“msg”:“load complete”}
{“level”:“info”,“ts”:1769472804.4490292,“logger”:“docker-proxy”,“msg”:“Successfully configured”,“server”:“localhost”}
{“level”:“info”,“ts”:1769472804.4500377,“logger”:“admin”,“msg”:“stopped previous server”,“address”:“localhost:2019”}
{“level”:“info”,“ts”:1769472804.4507673,“logger”:“tls”,“msg”:“storage cleaning happened too recently; skipping for now”,“storage”:“FileStorage:/data/caddy”,“instance”:“3ec9fbb2-e8fd-42c1-a62e-1a6917d5597f”,“try_again”:1769559204.450766,“try_again_in”:86399.99999975}
{“level”:“info”,“ts”:1769472804.4508386,“logger”:“tls”,“msg”:“finished cleaning storage units”}
{“level”:“error”,“ts”:1769472805.2571235,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“49184”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“homarr.pc.vpn.tornaxo7.de”,“uri”:“/”,“headers”:{“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\[“text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8”\],“Accept-Language”:\[“en-US,en;q=0.9”\],“Cookie”:\[“REDACTED”\]}},“duration”:0.000095674,“status”:503,“err_id”:“urijgfp0a”,“err_trace”:“reverseproxy.(*Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472806.2108116,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“49184”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“homarr.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept-Language”:\[“en-US,en;q=0.9”\],“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Cookie”:\[“REDACTED”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"\]}},“duration”:0.000046398,“status”:503,“err_id”:“9nsgu2p4y”,“err_trace”:"reverseproxy.(Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472806.483072,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“49184”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“homarr.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept-Language”:\[“en-US,en;q=0.9”\],“Connection”:\[“keep-alive”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept-Encoding”:\[“gzip, deflate”\],“Cookie”:\[“REDACTED”\],“Upgrade-Insecure-Requests”:\[“1”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/;q=0.8”\]}},“duration”:0.000039273,“status”:503,“err_id”:“gh6g1i4hk”,“err_trace”:“reverseproxy.(*Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472806.7209845,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“49184”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“homarr.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Cookie”:\[“REDACTED”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"\],“Accept-Language”:\[“en-US,en;q=0.9”\],“Upgrade-Insecure-Requests”:\[“1”\]}},“duration”:0.000035719,“status”:503,“err_id”:“txb554vk2”,“err_trace”:"reverseproxy.(Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472806.9091842,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“49184”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“homarr.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/;q=0.8”\],“Accept-Language”:\[“en-US,en;q=0.9”\],“Accept-Encoding”:\[“gzip, deflate”\],“Cookie”:\[“REDACTED”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\]}},“duration”:0.000043466,“status”:503,“err_id”:“rgexu5hy8”,“err_trace”:“reverseproxy.(*Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472807.0473127,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“49184”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“homarr.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Priority”:\[“u=0, i”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"\],“Accept-Language”:\[“en-US,en;q=0.9”\],“Connection”:\[“keep-alive”\],“Cookie”:\[“REDACTED”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept-Encoding”:\[“gzip, deflate”\],“Upgrade-Insecure-Requests”:\[“1”\]}},“duration”:0.000041114,“status”:503,“err_id”:“6iqjrckwv”,“err_trace”:"reverseproxy.(Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“info”,“ts”:1769472834.4016192,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:”“}
{“level”:“error”,“ts”:1769472834.4016569,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769472834.4249902,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769472834.4250765,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769472834.427006,“logger”:“docker-proxy”,“msg”:“New Caddyfile”,“caddyfile”:“http://browse.pc.vpn.tornaxo7.de {\\n\\tencode\\n\\tfile_server browse\\n\\troot /browse\\n}\\nhttp://grafana.pc.vpn.tornaxo7.de {\\n\\treverse_proxy\\n}\\nhttp://homarr.pc.vpn.tornaxo7.de {\\n\\treverse_proxy\\n}\\nhttp://pc.vpn.tornaxo7.de {\\n\\tencode\\n\\tfile_server\\n}\\n”}
{“level”:“info”,“ts”:1769472834.4278731,“logger”:“docker-proxy”,“msg”:“New Config JSON”,“json”:”{"apps":{"http":{"servers":{"srv0":{"listen":\[":80"\],"routes":\[{"match":\[{"host":\["grafana.pc.vpn.tornaxo7.de"\]}\],"handle":\[{"handler":"subroute","routes":\[{"handle":\[{"handler":"reverse_proxy"}\]}\]}\],"terminal":true},{"match":\[{"host":\["browse.pc.vpn.tornaxo7.de"\]}\],"handle":\[{"handler":"subroute","routes":\[{"handle":\[{"handler":"vars","root":"/browse"},{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":\["zstd","gzip"\]},{"browse":{},"handler":"file_server","hide":\["./Caddyfile"\]}\]}\]}\],"terminal":true},{"match":\[{"host":\["homarr.pc.vpn.tornaxo7.de"\]}\],"handle":\[{"handler":"subroute","routes":\[{"handle":\[{"handler":"reverse_proxy"}\]}\]}\],"terminal":true},{"match":\[{"host":\["pc.vpn.tornaxo7.de"\]}\],"handle":\[{"handler":"subroute","routes":\[{"handle":\[{"encodings":{"gzip":{},"zstd":{}},"handler":"encode","prefer":\["zstd","gzip"\]},{"handler":"file_server","hide":\["./Caddyfile"\]}\]}\]}\],"terminal":true}\]}}}}}“}
{“level”:“info”,“ts”:1769472834.4279432,“logger”:“docker-proxy”,“msg”:“Sending configuration to”,“server”:“localhost”}
{“level”:“info”,“ts”:1769472834.4292347,“logger”:“admin.api”,“msg”:“received request”,“method”:“POST”,“host”:“localhost:2019”,“uri”:”/load",“remote_ip”:“127.0.0.1”,“remote_port”:“60912”,“headers”:{“Accept-Encoding”:\[“gzip”\],“Content-Length”:\[“964”\],“Content-Type”:\[“application/json”\],“User-Agent”:\[“Go-http-client/1.1”\]}}
{“level”:“info”,“ts”:1769472834.43125,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“localhost:2019”,“enforce_origin”:false,“origins”:\[“//localhost:2019”,“//\[::1\]:2019”,“//127.0.0.1:2019”\]}
{“level”:“warn”,“ts”:1769472834.4315803,“logger”:“http.auto_https”,“msg”:“server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server”,“server_name”:“srv0”,“http_port”:80}
{“level”:“warn”,“ts”:1769472834.4325264,“logger”:“http”,“msg”:“HTTP/2 skipped because it requires TLS”,“network”:“tcp”,“addr”:“:80”}
{“level”:“warn”,“ts”:1769472834.4325461,“logger”:“http”,“msg”:“HTTP/3 skipped because it requires TLS”,“network”:“tcp”,“addr”:“:80”}
{“level”:“info”,“ts”:1769472834.4325538,“logger”:“http.log”,“msg”:“server running”,“name”:“srv0”,“protocols”:\[“h1”,“h2”,“h3”\]}
{“level”:“info”,“ts”:1769472834.4326177,“logger”:“http”,“msg”:“servers shutting down with eternal grace period”}
{“level”:“info”,“ts”:1769472834.4330392,“msg”:“autosaved config (load with --resume flag)”,“file”:“/config/caddy/autosave.json”}
{“level”:“info”,“ts”:1769472834.4330747,“logger”:“admin.api”,“msg”:“load complete”}
{“level”:“info”,“ts”:1769472834.4333727,“logger”:“docker-proxy”,“msg”:“Successfully configured”,“server”:“localhost”}
{“level”:“info”,“ts”:1769472834.4354475,“logger”:“admin”,“msg”:“stopped previous server”,“address”:“localhost:2019”}
{“level”:“error”,“ts”:1769472834.6352625,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“47156”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“grafana.pc.vpn.tornaxo7.de”,“uri”:“/”,“headers”:{“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/;q=0.8”\],“Accept-Language”:\[“en-US,en;q=0.9”\],“Accept-Encoding”:\[“gzip, deflate”\]}},“duration”:0.000062617,“status”:503,“err_id”:“aw164ss06”,“err_trace”:“reverseproxy.(*Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472835.8328857,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“47156”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“grafana.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"\],“Accept-Language”:\[“en-US,en;q=0.9”\],“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\]}},“duration”:0.000103482,“status”:503,“err_id”:“d5h1zv9ab”,“err_trace”:"reverseproxy.(Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472836.351758,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“47156”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“grafana.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept-Language”:\[“en-US,en;q=0.9”\],“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/;q=0.8”\]}},“duration”:0.000123324,“status”:503,“err_id”:“mk3wxj3jx”,“err_trace”:“reverseproxy.(*Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472836.5635452,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“47156”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“grafana.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"\],“Accept-Language”:\[“en-US,en;q=0.9”\],“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\]}},“duration”:0.000068783,“status”:503,“err_id”:“dht1wwi6j”,“err_trace”:"reverseproxy.(Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472836.7039332,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“47156”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“grafana.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/;q=0.8”\],“Accept-Language”:\[“en-US,en;q=0.9”\]}},“duration”:0.000117393,“status”:503,“err_id”:“wfqz2dreu”,“err_trace”:“reverseproxy.(*Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472836.7865682,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“47156”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“grafana.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept-Language”:\[“en-US,en;q=0.9”\],“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"\]}},“duration”:0.000095179,“status”:503,“err_id”:“5vk8h9dwu”,“err_trace”:"reverseproxy.(Handler).proxyLoopIteration (reverseproxy.go:540)“}
{“level”:“error”,“ts”:1769472836.91622,“logger”:“http.log.error”,“msg”:“no upstreams available”,“request”:{“remote_ip”:“10.89.0.2”,“remote_port”:“47156”,“client_ip”:“10.89.0.2”,“proto”:“HTTP/1.1”,“method”:“GET”,“host”:“grafana.pc.vpn.tornaxo7.de”,“uri”:”/",“headers”:{“Accept-Encoding”:\[“gzip, deflate”\],“Connection”:\[“keep-alive”\],“Upgrade-Insecure-Requests”:\[“1”\],“Priority”:\[“u=0, i”\],“User-Agent”:\[“Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0”\],“Accept”:\["text/html,application/xhtml+xml,application/xml;q=0.9,*/;q=0.8”\],“Accept-Language”:\[“en-US,en;q=0.9”\]}},“duration”:0.000055861,“status”:503,“err_id”:“7fa4bnhf2”,“err_trace”:“reverseproxy.(\*Handler).proxyLoopIteration (reverseproxy.go:540)”}
{“level”:“info”,“ts”:1769472864.402932,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769472864.4029567,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769472864.415177,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769472864.4152136,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769472894.404798,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769472894.4048367,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769472894.4471378,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769472894.4471695,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“warn”,“ts”:1769472924.3676233,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769472924.3676627,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769472924.406011,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769472924.4060307,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“info”,“ts”:1769472954.4088433,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769472954.408888,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769472954.4112327,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769472954.411259,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769472984.4107192,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769472984.4107447,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769472984.4359233,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769472984.4359596,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769473014.4120667,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769473014.4120896,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769473014.426379,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769473014.426405,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769473044.4135911,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769473044.4136076,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769473044.4276745,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769473044.4277089,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769473074.4150746,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769473074.415086,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769473074.4348278,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769473074.4348686,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769473104.4522202,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769473104.4522448,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
{“level”:“warn”,“ts”:1769473104.4602902,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769473104.4603233,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“warn”,“ts”:1769473134.451997,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”,“container id”:“b685ce9a2e0be79364e1c53d451b555f1bfc8b9abc2ad0ed4f896952793f5cc4”}
{“level”:“warn”,“ts”:1769473134.4520383,“logger”:“docker-proxy”,“msg”:“Container is not in same network as caddy”,“container”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”,“container id”:“5a52e621b428c0e868860d3ff7ab4dd1e0ee32540a5bab2382605b699d9bc751”}
{“level”:“info”,“ts”:1769473134.4529474,“logger”:“docker-proxy”,“msg”:“Connecting to docker events”,“DockerSocket”:“”}
{“level”:“error”,“ts”:1769473134.452954,“logger”:“docker-proxy”,“msg”:“Docker events error”,“error”:“Error response from daemon: failed to parse event filters: scope is an invalid filter”}
Using podman-compose.
podman-compose (NixOS, stable)
podman compose up -d
./caddy/Dockerfile
ARG VERSION=2.11
FROM caddy:${VERSION}-builder-alpine AS builder
RUN --mount=type=cache,target=/go/pkg/mod \
    --mount=type=cache,target=/root/.cache/go-build \
    xcaddy build \
        --with github.com/lucaslorentz/caddy-docker-proxy/v2
FROM caddy:${VERSION}-alpine
CMD ["caddy", "docker-proxy"]
compose.yaml
    build: ./caddy
      - ./caddy/conf:/etc/caddy
      - ./caddy/site:/srv
      - ./caddy/browse:/browse
      - caddy_data:/data
      - caddy_config:/config
      - ${XDG_RUNTIME_DIR}/podman/podman.sock:/var/run/docker.sock
      - caddy
      - CADDY_INGRESS_NETWORKS=caddy,homarr,grafana
    labels:
      caddy_0: http://${DOMAIN}
      caddy_0.encode:
      caddy_0.file_server:
      caddy_ingress_network: "caddy"
      caddy_1: http://browse.${DOMAIN}
      caddy_1.encode:
      caddy_1.root: /browse
      caddy_1.file_server: browse
  homarr:
    container_name: homarr
    image: ghcr.io/homarr-labs/homarr:latest
      - ./homarr/:/appdata
      - SECRET_ENCRYPTION_KEY=1ce6b52370079cb1aed800f5e2e427e908ab4fa5ad6c7a0732567d35606a48c4
    labels:
      caddy: http://homarr.${DOMAIN}
      caddy.reverse_proxy: "{{upstreams 7575}}"
      - homarr
  grafana:
    container_name: grafana
    image: grafana/grafana
    user: root
      - ./grafana:/var/lib/grafana
    labels:
      caddy: http://grafana.${DOMAIN}
      caddy.reverse_proxy: "{{upstreams 3000}}"
      - grafana
  caddy_data:
  caddy_config:
  homarr:
  grafana:
It’s empty because somehow caddy-docker-proxy ignores my caddyfile so I’m forced to configure caddy by using labels (see here for more information).
None
