Caddy docker-compose getting module named 'caddy.logging.encoders.single_field': module not registered
Hi folks. Hope everyone is doing well :wink:
Caddy looks tremendously nice
Thanks to all the community !
i’m totally noob with the CaddyFile syntax and basics if someone can give me some hint i wold be grateful. thank you .
I try to deploy a very simple caddy server with docker-compose. It works like charm but i need to produce logs (access.log) .
then need to transform my access.log to be readable by goaccess
If i understand correctly i need at least one external module :
caddy.logging.encoders.json
i really want to keep things simple and don’t want to compile via xcaddy.
My question is how can i achieve this very simple puprose or writing logs somewhere ?
i can’t find logs in data/acces.logs
{"level":"info","ts":1705715576.5076275,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'log': getting module named 'caddy.logging.writers.data/access.log': module not registered: caddy.logging.writers.data/access.log, at /etc/caddy/Caddyfile:10
v2.7.6 h1
via docker compose
rocky 9 with podman.
podman-compose up -d
version: "3.9"
    image: caddy:latest
      - "443:443/udp"
      - ./site:/var/www/html
      - caddy_data:/data
      - caddy_config:/config
    depends_on:
      - webdav
  caddy_data:
  caddy_config:
my.super.domain {
        # Set webroot
        root * /var/www/html
        # enable compression
        encode zstd gzip
        # enable log for goaccess
        log default {
        output data/access.log
        format json
single_field no longer exists. It’s was deprecated a couple years ago, and removed about a year later.
This is invalid syntax, the output option takes a module name as the first argument, for example file and then file takes arguments, i.e. a file name.
See the docs: log (Caddyfile directive) — Caddy Documentation
Thanks for your answer. I’m really uncomforatble with the syntax. so is this syntax ok ?
my.super.domainame{
        # Set webroot
        encode zstd gzip
        log default {
        output file data/access.log {
You must have a space between your domain and the {
The indentation is weird, you should tab in the output line another step.
Also, you can remove the inner { } after the filename because you’re not providing any options to the file writer.
You can run caddy fmt -w <path-to-your-Caddyfile> to clean up the syntax.
IMO the comments you have are not that useful, they state the obvious.
Thank you for you suggestions and explanations.
I end-up with this conf working like a charm :
my.super.domain {
    encode zstd gzip
            format json
            roll_local_time
            roll_keep     10
            roll_keep_for 365d
