I believe caddy.DefaultConfigFile
should be a var instead of a const, so that I can override it, because my config file is named Corefile
Hmm, this goes back to the discussion/question of what Caddy is. Now I’m not sure.
Is a server type plugin the actual application? What if there are 2 server types plugged in? Which one “wins”?
I suggest we keep it just called “Caddyfile” which is agnostic of server type.
Your branding situation… it is tricky…
