Caddy crashes (panic) when using Souin with Redis as cache storage
Hi everyone,
I’m having an issue when using Caddy together with Souin for caching in Ubuntu 24.04.3 LTS, Whenever I enable caching with Redis as the storage backend, Caddy panics and crashes.
I tried switching the cache storage to Dragonfly, but the same problem occurs.
I also experimented with several configuration changes, but nothing seems to have any effect.
Has anyone else experienced this issue or found a stable configuration for Souin with Redis/Dragonfly?
Any guidance or example configs would be really appreciated.
Thanks in advance!
Oct 25 08:58:37 samenc-worker-1 caddy[953102]: {"level":"error","ts":1761370117.7274086,"logger":"http.log.error.log2","msg":"error handling handler error","request":{"remote_ip":"93.119.208.56","remote_port":"58327","client_ip":"93.119.208.56","proto":"HTTP/3.0","method":"GET","host":"hrm.site.com","uri":"/index.php/offices/department-of-staff-training-and-development","headers":{"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["same-site"],"Accept-Language":["en-US,en;q=0.5"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Alt-Used":["hrm.site.com"],"Upgrade-Insecure-Requests":["1"],"Cookie":["REDACTED"],"Sec-Fetch-User":["?1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Sec-Fetch-Dest":["document"],"Priority":["u=0, i"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:143.0) Gecko/20100101 Firefox/143.0"],"Referer":["https://www.site.com/"]},"tls":{"resumed":true,"version":772,"cipher_suite":4865,"proto":"h3","server_name":"hrm.site.com"}},"duration":0.000146588,"error":"{id=60g91zmvj} fileserver.(*FileServer).notFound (staticfiles.go:705): HTTP 404","first_error":{"msg":"TLS handshake not complete, remote IP cannot be verified","status":425,"err_id":"jane0atiq","err_trace":"caddyhttp.MatchRemoteIP.MatchWithError (ip_matchers.go:162)"}}
Oct 25 08:58:38 samenc-worker-1 caddy[953102]: {"level":"info","ts":1761370118.291342,"logger":"http.handlers.cache","msg":"recovered due to closed errorCacheCh chan, the request context has finished prematurely /favicon.ico"}
Oct 25 08:58:38 samenc-worker-1 caddy[953102]: {"level":"info","ts":1761370118.5642972,"logger":"http.handlers.cache","msg":"recovered due to closed errorCacheCh chan, the request context has finished prematurely /images/1404/mehr/-2147483648_-212559_2.mp4"}
Oct 25 08:58:43 samenc-worker-1 caddy[953102]: {"level":"error","ts":1761370123.670613,"logger":"http.handlers.reverse_proxy","msg":"can't switch protocols using non-Hijacker ResponseWriter","type":"struct { coraza.responseWriter; http.Pusher }"}
Oct 25 08:58:44 samenc-worker-1 caddy[953102]: {"level":"error","ts":1761370124.206436,"logger":"http.handlers.reverse_proxy","msg":"can't switch protocols using non-Hijacker ResponseWriter","type":"struct { coraza.responseWriter; http.Pusher }"}
Oct 25 08:58:45 samenc-worker-1 caddy[953102]: {"level":"info","ts":1761370125.481823,"logger":"http.handlers.cache","msg":"Reused response from concurrent request with the key GET-https-www.site.com-/"}
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: fatal error: concurrent map read and map write
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: goroutine 1794470 [running]:
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: internal/runtime/maps.fatal({0x20f7a50?, 0xc07319b0d0?})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         runtime/panic.go:1058 +0x18
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2/modules/caddyhttp.GetVar(...)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/modules/caddyhttp/vars.go:424
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2/modules/caddyhttp.LoggableHTTPRequest.MarshalLogObject({0xc0530697c0?, 0x45?}, {0x26abf60, 0xc02c9b0540})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/modules/caddyhttp/marshalers.go:43 +0x133
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.(*jsonEncoder).AppendObject(0xc02c9b0540, {0x2677bc0, 0xc05d44b3f0})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/json_encoder.go:225 +0x25a
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.(*jsonEncoder).AddObject(0xc02c9b0540, {0x20adf66?, 0x30?}, {0x2677bc0, 0xc05d44b3f0})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/json_encoder.go:107 +0x3b
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.Field.AddTo({{0x20adf66, 0x7}, 0x2, 0x0, {0x0, 0x0}, {0x205b0c0, 0xc05d44b3f0}}, {0x26abf60, 0xc02c9b0540})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/field.go:121 +0xaa2
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.addFields(...)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/field.go:210
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.(*ioCore).With(0xc00107dc20, {0xc060459900, 0x1, 0x350?})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/core.go:83 +0x1a5
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2.(*filteringCore).With(0xc0008a78c0, {0xc060459900?, 0x0?, 0x1f?})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/logging.go:593 +0x29
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.multiCore.With({0xc00088cd88, 0x35, 0xc053069680?}, {0xc060459900, 0x1, 0x1})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/tee.go:51 +0x8e
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.(*lazyWithCore).initOnce.func1()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/lazy_with.go:42 +0x30
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: sync.(*Once).doSlow(0x4773d9?, 0x80?)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         sync/once.go:78 +0xab
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: sync.(*Once).Do(...)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         sync/once.go:69
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.(*lazyWithCore).initOnce(0x419f45?)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/lazy_with.go:41 +0x36
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap/zapcore.(*lazyWithCore).With(0xc060459940, {0xc073cb1f40, 0x1, 0x1})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/zapcore/lazy_with.go:47 +0x27
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: go.uber.org/zap.(*Logger).With(0xc03f3ad780, {0xc073cb1f40, 0x1, 0x1})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         go.uber.org/zap@v1.27.0/logger.go:185 +0xaf
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2/modules/caddyhttp.(*Server).ServeHTTP(0xc0016d7c08, {0x2688690, 0xc03f3ad700}, 0xc0530692c0)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/modules/caddyhttp/server.go:387 +0x1034
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/quic-go/quic-go/http3.(*Server).handleRequest.func2(0x268bb78?, 0xc0e0e27c70?, {0x2677b60?, 0xc0016d7c08?}, 0xc09b4f6048?, 0x16?)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/quic-go/quic-go@v0.50.1/http3/server.go:690 +0x5f
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/quic-go/quic-go/http3.(*Server).handleRequest(0xc039cd24b0, 0xc00a1a60e0, {0x269b570, 0xc0a3e9ec60}, 0xc0901cacd0, 0xc0976cf1a0)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/quic-go/quic-go@v0.50.1/http3/server.go:691 +0xac5
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/quic-go/quic-go/http3.(*Server).handleConn.func1()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/quic-go/quic-go@v0.50.1/http3/server.go:578 +0x5b
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: created by github.com/quic-go/quic-go/http3.(*Server).handleConn in goroutine 1790687
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/quic-go/quic-go@v0.50.1/http3/server.go:574 +0x32d
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: goroutine 1 [select (no cases), 40 minutes]:
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2/cmd.cmdRun({0x0?})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/cmd/commandfuncs.go:291 +0xc69
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2/cmd.init.1.func2.WrapCommandFuncForCobra.1(0xc0004f8308, {0x2099eda?, 0x4?, 0x2099e96?})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/cmd/cobra.go:141 +0x2f
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/spf13/cobra.(*Command).execute(0xc0004f8308, {0xc000578f40, 0x2, 0x2})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/spf13/cobra@v1.9.1/command.go:1015 +0xaaa
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/spf13/cobra.(*Command).ExecuteC(0xc0002b5b08)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/spf13/cobra@v1.9.1/command.go:1148 +0x46f
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/spf13/cobra.(*Command).Execute(...)
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/spf13/cobra@v1.9.1/command.go:1071
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2/cmd.Main()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/cmd/main.go:72 +0x65
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: main.main()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         caddy/main.go:16 +0xf
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: goroutine 46 [syscall, 40 minutes]:
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: os/signal.signal_recv()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         runtime/sigqueue.go:152 +0x29
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: os/signal.loop()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         os/signal/signal_unix.go:23 +0x13
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: created by os/signal.Notify.func1.1 in goroutine 50
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         os/signal/signal.go:152 +0x1f
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: goroutine 50 [chan receive, 40 minutes]:
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2.trapSignalsCrossPlatform.func1()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/sigtrap.go:43 +0xde
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: created by github.com/caddyserver/caddy/v2.trapSignalsCrossPlatform in goroutine 1
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/sigtrap.go:38 +0x1a
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: goroutine 51 [chan receive, 40 minutes]:
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/caddyserver/caddy/v2.trapSignalsPosix.func1()
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/sigtrap_posix.go:39 +0xda
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: created by github.com/caddyserver/caddy/v2.trapSignalsPosix in goroutine 1
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/caddyserver/caddy/v2@v2.10.0/sigtrap_posix.go:35 +0x4b
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: goroutine 225 [chan receive]:
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/redis/rueidis.(*pipe).Do(0xc02dd02000, {0x268b9b8, 0x389cbc0}, {0xc0c0cc8180, 0x2000, 0xbf63})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/redis/rueidis@v1.0.54/pipe.go:912 +0x56f
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/redis/rueidis.(*mux).pipeline(0xc0055a6300, {0x268b9b8, 0x389cbc0}, {0xc0c0cc8180, 0x2000, 0xbf63})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/redis/rueidis@v1.0.54/mux.go:270 +0xf1
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/redis/rueidis.(*mux).Do(0x452308970?, {0x268b9b8?, 0x389cbc0?}, {0xc0c0cc8180, 0x2000, 0xbf63})
Oct 25 08:58:46 samenc-worker-1 caddy[953102]:         github.com/redis/rueidis@v1.0.54/mux.go:218 +0x14b
Oct 25 08:58:46 samenc-worker-1 caddy[953102]: github.com/redis/rueidis.(*singleClient).Do(0xc006c60630, {0x268b9b8, 0x389cbc0}, {0xc0c0cc8180, 0x2000, 0xbf63})
xcaddy build–with github.com/darkweak/souin/configurationtypes–with –with github.com/corazawaf/coraza-caddy/v2–with –with github.com/darkweak/souin/plugins/caddy–with github.com/darkweak/storages/redis/caddy–with  \
http://**.site.com {
   redir https://{host}{uri} permanent
*.site.com:443 , site.com:443 {
    tls  /etc/caddy/certs/77d1bf2a126b4cbcaa56875b5f88a9ea_fullchain.pem  /etc/caddy/certs/77d1bf2a126b4cbcaa56875b5f88a9ea_key.pem
        -via
	-X-Powered-By
        -X-AspNet-Version
        -X-AspNetMvc-Version
        -X-Runtime
        -X-Drupal-Cache
        -X-Generator
        -X-Pingback
        -X-Backend-Server
        -X-Varnish
        -Via
        -X-CDN
        -X-Amz-Cf-Pop
        -X-Amz-Cf-Id
        -X-Cache
        -X-Cache-Hits
        -X-LiteSpeed-Cache
        -X-Mod-Pagespeed
        -X-HW
        -X-Served-By
        -X-Node
        -X-Host
        -X-Server
        -X-SourceFiles
        -X-Engine
        -X-Envoy-Upstream-Service-Time
        -X-Firefox-Spdy
        -X-Frame-Options
        server "SamenCloudSecurity/1.0"
@upgrade {
     header Connection *Upgrade*
     header Upgrade    *websocket*
    route {
handle @upgrade {
      reverse_proxy https://10.20.30.40:443
            @ip_access_list {
                not remote_ip 0.0.0.0/0
            handle @ip_access_list {
                rewrite /var/www/default_pages/403_acl.html
#            @geo_access_list {
#                not remote_ip 0.0.0.0/0
#            handle @geo_access_list {
#                rewrite /var/www/default_pages/403_geo.html
#                file_server
            coraza_waf {
                load_owasp_crs
                directives `
                    SecRuleEngine On
                    SecAuditEngine On
                    SecAuditLogParts ABCDEFGHIJKZ
                    SecAuditLogFormat json
                    SecAuditLog /var/log/caddy/audit/82c09d3596a8460a819913012906baf4.log
                    include /etc/caddy/coraza-coreruleset/rules/crs-setup.conf
                    include /etc/caddy/coraza-coreruleset/rules/@owasp_crs/*.conf
                # include /etc/caddy/coraza-coreruleset/rules/WAFaaS/44073a1e-65da-451f-879e-fb39eafc545d.conf
                encode {
                    gzip 6
                    br 6
                    minimum_length 1024
                    match {
                        header Content-Type text/html
                        header Content-Type text/css
                        header Content-Type text/javascript
                        header Content-Type application/javascript
                        header Content-Type application/json
                        header Content-Type image/svg+xml
            @cacheable {
                method GET
                method HEAD
            cache @cacheable {
                ttl 3600s
                stale 60s
                key {
			hide
			hash
		cache_name test
                default_cache_control
                allowed_additional_status_codes 200 301 302 404
                redis {
                    url 127.0.0.1:6379
                storers redis
                Cache-Control "public, max-age=3600"
            reverse_proxy  {
                to https://10.20.30.40:443
                        lb_policy round_robin
                header_up X-Forwarded-Host {http.request.host}
                health_interval 60s
                health_timeout 60s
                    keepalive 30s
                    read_buffer 4MiB
                    write_buffer 4MiB
                    max_conns_per_host 10000
                    max_response_header 64MiB
                    dial_timeout 360s
                    response_header_timeout 360s
                    tls
                    tls_insecure_skip_verify
        output file /var/log/caddy/82c09d3596a8460a819913012906baf4.log {
            roll_size 100mb
            roll_keep 5
        format json
        level info
Pretty sure this was fixed already. Please run caddy list-modules –versions and share the output.
Thank you for your quick response, this is my caddy module list:
admin.api.load v2.10.0
admin.api.metrics v2.10.0
admin.api.pki v2.10.0
admin.api.reverse_proxy v2.10.0
caddy.adapters.caddyfile v2.10.0
caddy.config_loaders.http v2.10.0
caddy.filesystems v2.10.0
caddy.listeners.http_redirect v2.10.0
caddy.listeners.proxy_protocol v2.10.0
caddy.listeners.tls v2.10.0
caddy.logging.cores.mock v2.10.0
caddy.logging.encoders.append v2.10.0
caddy.logging.encoders.console v2.10.0
caddy.logging.encoders.filter v2.10.0
caddy.logging.encoders.filter.cookie v2.10.0
caddy.logging.encoders.filter.delete v2.10.0
caddy.logging.encoders.filter.hash v2.10.0
caddy.logging.encoders.filter.ip_mask v2.10.0
caddy.logging.encoders.filter.query v2.10.0
caddy.logging.encoders.filter.regexp v2.10.0
caddy.logging.encoders.filter.rename v2.10.0
caddy.logging.encoders.filter.replace v2.10.0
caddy.logging.encoders.json v2.10.0
caddy.logging.writers.discard v2.10.0
caddy.logging.writers.file v2.10.0
caddy.logging.writers.net v2.10.0
caddy.logging.writers.stderr v2.10.0
caddy.logging.writers.stdout v2.10.0
caddy.network_proxy.none v2.10.0
caddy.network_proxy.url v2.10.0
caddy.storage.file_system v2.10.0
events v2.10.0
http v2.10.0
http.authentication.hashes.bcrypt v2.10.0
http.authentication.providers.http_basic v2.10.0
http.encoders.gzip v2.10.0
http.encoders.zstd v2.10.0
http.handlers.acme_server v2.10.0
http.handlers.authentication v2.10.0
http.handlers.copy_response v2.10.0
http.handlers.copy_response_headers v2.10.0
http.handlers.encode v2.10.0
http.handlers.error v2.10.0
http.handlers.file_server v2.10.0
http.handlers.headers v2.10.0
http.handlers.intercept v2.10.0
http.handlers.invoke v2.10.0
http.handlers.log_append v2.10.0
http.handlers.map v2.10.0
http.handlers.metrics v2.10.0
http.handlers.push v2.10.0
http.handlers.request_body v2.10.0
http.handlers.reverse_proxy v2.10.0
http.handlers.rewrite v2.10.0
http.handlers.static_response v2.10.0
http.handlers.subroute v2.10.0
http.handlers.templates v2.10.0
http.handlers.tracing v2.10.0
http.handlers.vars v2.10.0
http.ip_sources.static v2.10.0
http.matchers.client_ip v2.10.0
http.matchers.expression v2.10.0
http.matchers.file v2.10.0
http.matchers.header v2.10.0
http.matchers.header_regexp v2.10.0
http.matchers.host v2.10.0
http.matchers.method v2.10.0
http.matchers.not v2.10.0
http.matchers.path v2.10.0
http.matchers.path_regexp v2.10.0
http.matchers.protocol v2.10.0
http.matchers.query v2.10.0
http.matchers.remote_ip v2.10.0
http.matchers.tls v2.10.0
http.matchers.vars v2.10.0
http.matchers.vars_regexp v2.10.0
http.precompressed.br v2.10.0
http.precompressed.gzip v2.10.0
http.precompressed.zstd v2.10.0
http.reverse_proxy.selection_policies.client_ip_hash v2.10.0
http.reverse_proxy.selection_policies.cookie v2.10.0
http.reverse_proxy.selection_policies.first v2.10.0
http.reverse_proxy.selection_policies.header v2.10.0
http.reverse_proxy.selection_policies.ip_hash v2.10.0
http.reverse_proxy.selection_policies.least_conn v2.10.0
http.reverse_proxy.selection_policies.query v2.10.0
http.reverse_proxy.selection_policies.random v2.10.0
http.reverse_proxy.selection_policies.random_choose v2.10.0
http.reverse_proxy.selection_policies.round_robin v2.10.0
http.reverse_proxy.selection_policies.uri_hash v2.10.0
http.reverse_proxy.selection_policies.weighted_round_robin v2.10.0
http.reverse_proxy.transport.fastcgi v2.10.0
http.reverse_proxy.transport.http v2.10.0
http.reverse_proxy.upstreams.a v2.10.0
http.reverse_proxy.upstreams.multi v2.10.0
http.reverse_proxy.upstreams.srv v2.10.0
pki v2.10.0
tls v2.10.0
tls.ca_pool.source.file v2.10.0
tls.ca_pool.source.http v2.10.0
tls.ca_pool.source.inline v2.10.0
tls.ca_pool.source.pki_intermediate v2.10.0
tls.ca_pool.source.pki_root v2.10.0
tls.ca_pool.source.storage v2.10.0
tls.certificates.automate v2.10.0
tls.certificates.load_files v2.10.0
tls.certificates.load_folders v2.10.0
tls.certificates.load_pem v2.10.0
tls.certificates.load_storage v2.10.0
tls.client_auth.verifier.leaf v2.10.0
tls.ech.publishers.dns v2.10.0
tls.get_certificate.http v2.10.0
tls.get_certificate.tailscale v2.10.0
tls.handshake_match.local_ip v2.10.0
tls.handshake_match.remote_ip v2.10.0
tls.handshake_match.sni v2.10.0
tls.handshake_match.sni_regexp v2.10.0
tls.issuance.acme v2.10.0
tls.issuance.internal v2.10.0
tls.issuance.zerossl v2.10.0
tls.leaf_cert_loader.file v2.10.0
tls.leaf_cert_loader.folder v2.10.0
tls.leaf_cert_loader.pem v2.10.0
tls.leaf_cert_loader.storage v2.10.0
tls.permission.http v2.10.0
tls.stek.distributed v2.10.0
tls.stek.standard v2.10.0
  Standard modules: 127
admin.api.souin v1.7.7
cache v1.7.7
http.encoders.br v1.6.0
http.handlers.cache v1.7.7
http.handlers.waf v2.1.0
http.matchers.fail2ban v0.0.0-20250425042450-c4139952edef
storages.cache.redis v0.0.15
  Non-standard modules: 7
  Unknown modules: 0
