Caddy crash after upgrade v2.7.2 from v2.6.4
caddy crash after upgrade v2.7.2 from v2.6.4
8月 03 14:51:53 NewCaddy systemd[1]: Started Caddy.
8月 03 14:51:53 NewCaddy caddy[1591605]: caddy.HomeDir=/var/lib/caddy
8月 03 14:51:53 NewCaddy caddy[1591605]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
8月 03 14:51:53 NewCaddy caddy[1591605]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
8月 03 14:51:53 NewCaddy caddy[1591605]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
8月 03 14:51:53 NewCaddy caddy[1591605]: caddy.Version=v2.7.2 h1:QqThyoyUFAv1B7A2NMeaWlz7xmgKqU49PXBX08A+6xg=
8月 03 14:51:53 NewCaddy caddy[1591605]: runtime.GOOS=linux
8月 03 14:51:53 NewCaddy caddy[1591605]: runtime.GOARCH=amd64
8月 03 14:51:53 NewCaddy caddy[1591605]: runtime.Compiler=gc
8月 03 14:51:53 NewCaddy caddy[1591605]: runtime.NumCPU=16
8月 03 14:51:53 NewCaddy caddy[1591605]: runtime.GOMAXPROCS=16
8月 03 14:51:53 NewCaddy caddy[1591605]: runtime.Version=go1.20.7
8月 03 14:51:53 NewCaddy caddy[1591605]: os.Getwd=/
8月 03 14:51:53 NewCaddy caddy[1591605]: LANG=zh_CN.UTF-8
8月 03 14:51:53 NewCaddy caddy[1591605]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
8月 03 14:51:53 NewCaddy caddy[1591605]: HOME=/var/lib/caddy
8月 03 14:51:53 NewCaddy caddy[1591605]: LOGNAME=caddy
8月 03 14:51:53 NewCaddy caddy[1591605]: USER=caddy
8月 03 14:51:53 NewCaddy caddy[1591605]: INVOCATION_ID=a7249b07f5dc4641b77e45a70d90d891
8月 03 14:51:53 NewCaddy caddy[1591605]: JOURNAL_STREAM=8:962767775
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1151452,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"warn","ts":1691045513.116646,"logger":"caddyfile","msg":"Placeholder {args.0} deprecated, use {args[0]} instead"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1612985,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1622434,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004e6600"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1623552,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"warn","ts":1691045513.1624315,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","h
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1628265,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.166393,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1718645,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1746206,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1750474,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1778736,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.178231,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1809976,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1813412,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1839685,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.184481,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1871123,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1875393,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.190509,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.191071,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.194098,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1944644,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.196886,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.1973703,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2000952,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2004476,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2031069,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2046206,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2073767,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2077804,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.210709,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2111328,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2137358,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2143247,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2168136,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2171214,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2198417,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.220278,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2230465,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2234306,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2260604,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.22643,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.229136,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2295516,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.232313,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.232693,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.235696,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2360413,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2390244,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.239356,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2421484,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2425027,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2452998,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2456965,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2483072,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2487435,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2512512,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2516313,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2540069,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2543724,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2568827,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2573276,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2599058,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2603161,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2632115,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.2636094,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.266504,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.266888,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3047216,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3050756,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3079932,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3083735,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3104901,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3108678,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3132403,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3137724,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.316058,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.316444,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3189216,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3193362,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.322051,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.322513,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3253868,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3256934,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.328465,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3300958,"logger":"http.handlers.waf_chaitin","msg":"Provisioning WAF plugin instance"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.333279,"logger":"http.handlers.waf_chaitin","msg":"waf plugin validate"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3340855,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3341367,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3344657,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3345726,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.334671,"logger":"http.log","msg":"server running","name":"srv2","protocols":["h1","h2","h3"]}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.334695,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.buct.edu.cn","experimental-auth-endpoint.buct.edu.cn"]}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3355553,"logger":"tls","msg":"finished cleaning storage units"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3369114,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
8月 03 14:51:53 NewCaddy caddy[1591605]: {"level":"info","ts":1691045513.3369353,"msg":"serving initial configuration"}
8月 03 14:51:57 NewCaddy caddy[1591605]: {"level":"info","ts":1691045517.6671886,"msg":"Unsolicited response received on idle HTTP channel starting with \"File Not Modified\\r\\n\"; err=<nil>"}
8月 03 14:51:57 NewCaddy caddy[1591605]: {"level":"info","ts":1691045517.6811957,"msg":"Unsolicited response received on idle HTTP channel starting with \"File Not Modified\\r\\n\"; err=<nil>"}
8月 03 14:51:57 NewCaddy caddy[1591605]: {"level":"info","ts":1691045517.6813276,"msg":"Unsolicited response received on idle HTTP channel starting with \"File Not Modified\\r\\n\"; err=<nil>"}
8月 03 14:51:57 NewCaddy caddy[1591605]: {"level":"info","ts":1691045517.6845403,"msg":"Unsolicited response received on idle HTTP channel starting with \"File Not Modified\\r\\n\"; err=<nil>"}
8月 03 14:51:59 NewCaddy caddy[1591605]: {"level":"info","ts":1691045519.2223284,"msg":"Unsolicited response received on idle HTTP channel starting with \"File Not Modified\\r\\n\"; err=<nil>"}
8月 03 14:52:28 NewCaddy caddy[1591605]: {"level":"error","ts":1691045548.326144,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"121.195.132.11:443","duration":0.025321442,"request":{"remoted92:532","remote_port":"51902","client_ip":"2001:da8:237:200:d9c7:c614:2d92:532","proto":"HTTP/3.0","method":"GET","host":"www.buct.edu.cn","uri":"/_upload/article/images/b4/ad/6654543e48c98d973d3cc2043a79/86a82685-39d0-4b83-8978-7509d-Mobile":["?0"],"Sec-Fetch-Mode":["no-cors"],"Sec-Fetch-Dest":["image"],"Sec-Ch-Ua-Platform":["\"Windows\""],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["www.buct.edu.cn"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) cko) Chrome/115.0.0.0 Safari/537.36 Edg/115.0.1901.188"],"Cookie":[],"Accept-Encoding":["gzip, deflate, br"],"Sec-Ch-Ua":["\"Not/A)Brand\";v=\"99\", \"Microsoft Edge\";v=\"115\", \"Chromium\";v=\"115\""],"Accept-Language":["zh-CN,zh;q=.6"],"X-Forwarded-For":["2001:da8:237:200:d9c7:c614:2d92:532"],"Accept":["image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["same-origin"],"Referer":["https://www.buct.edu.cn/main.htm"]},"tls":{"resumed":true,"vroto":"h3","server_name":"www.buct.edu.cn"}},"error":"writing: stream 12 canceled by remote with error code 268"}
8月 03 14:52:28 NewCaddy caddy[1591605]: {"level":"error","ts":1691045548.3263478,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"121.195.132.11:443","duration":0.023191798,"request":{"remot2d92:532","remote_port":"51902","client_ip":"2001:da8:237:200:d9c7:c614:2d92:532","proto":"HTTP/3.0","method":"GET","host":"www.buct.edu.cn","uri":"/_upload/article/images/e8/1e/6bd2e1c7449eac6def3263cf9861/6b624334-edd5-4866-95b3-6aa6h-Site":["same-origin"],"Cookie":[],"X-Forwarded-For":["2001:da8:237:200:d9c7:c614:2d92:532"],"Sec-Fetch-Dest":["image"],"Sec-Ch-Ua-Platform":["\"Windows\""],"Sec-Fetch-Mode":["no-cors"],"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 Edg/115.0.1901.188"],"Accept":["image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Referer":["https://www.buct.edu.cn/main.htm"],"X-Forwarded-Host":["www.buctN,zh;q=0.9,en;q=0.8,en-GB;q=0.7,en-US;q=0.6"],"Sec-Ch-Ua":["\"Not/A)Brand\";v=\"99\", \"Microsoft Edge\";v=\"115\", \"Chromium\";v=\"115\""],"Accept-Encoding":["gzip, deflate, br"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":true,"proto":"h3","server_name":"www.buct.edu.cn"}},"error":"writing: stream 0 canceled by remote with error code 268"}
8月 03 14:52:28 NewCaddy caddy[1591605]: {"level":"error","ts":1691045548.3287551,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"121.195.132.11:443","duration":0.020698119,"request":{"remot2d92:532","remote_port":"51902","client_ip":"2001:da8:237:200:d9c7:c614:2d92:532","proto":"HTTP/3.0","method":"GET","host":"www.buct.edu.cn","uri":"/_upload/article/images/ae/72/0feefb0848f395edb3301a9e6c46/71a13e4a-3217-4665-9185-a489nt":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36 Edg/115.0.1901.188"],"X-Forwarded-For":["2001:da8:237:200:d9c7:c614:2d92:532"],"X-Forwarded-Host":["www.buct.edu.cn"]t-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["no-cors"],"Referer":["https://www.buct.edu.cn/main.htm"],"X-Forwarded-Proto":["https"],"Accept-Language":["zh-CN,zh;q=0.9,en;q=0.8,en-GB;q=0.7,en-US;q=0.6"],"Sec-Ch-Ua-Mobile":["?0"]""],"Accept":["image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Cookie":[],"Sec-Ch-Ua":["\"Not/A)Brand\";v=\"99\", \"Microsoft Edge\";v=\"115\", \"Chromium\";v=\"115\""],"Sec-Fetch-Site":["same-origin"]},"tls":{"resumed":true,"proto":"h3","server_name":"www.buct.edu.cn"}},"error":"writing: stream 4 canceled by remote with error code 268"}
8月 03 14:52:29 NewCaddy caddy[1591605]: panic: runtime error: invalid memory address or nil pointer dereference
8月 03 14:52:29 NewCaddy caddy[1591605]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x50 pc=0xa6506a]
8月 03 14:52:29 NewCaddy caddy[1591605]: goroutine 20030 [running]:
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go/internal/ackhandler.(*sentPacketHandler).ReceivedAck(0xc0023270c0?, 0xc0023270c0?, 0xa5?, {0xc001d63802?, 0x10200002c?, 0x2b874e0?})
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/internal/ackhandler/sent_packet_handler.go:298 +0x6a
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go.(*connection).handleAckFrame(0xc001d63800, 0xc002327100, 0xe0?)
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/connection.go:1484 +0x4e
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go.(*connection).handleFrame(0xc001d63800, {0x1f116e0?, 0xc002327100?}, 0x40?, {{0x82, 0x92, 0xc8, 0x7c, 0x0, 0x0, ...}, ...})
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/connection.go:1280 +0xed
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go.(*connection).handleFrames(0xc001d63800, {0xc0024f2c0e?, 0xc00216b860?, 0x40deca?}, {{0x82, 0x92, 0xc8, 0x7c, 0x0, 0x0, ...}, ...}, ...)
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/connection.go:1253 +0x365
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go.(*connection).handleUnpackedLongHeaderPacket(0xc001d63800, 0xc001425b00, 0xa7?, {0x60?, 0x0?, 0x2b874e0?}, 0x4a)
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/connection.go:1194 +0x6aa
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go.(*connection).handleLongHeaderPacket(0xc001d63800, {0xc001abee40, {0x1f12f68, 0xc001425a10}, {0xc12af18b6fc266cf, 0x88d317b02, 0x2b874e0}, {0xc0024f2c00, 0x4a, 0x5ac},
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/connection.go:967 +0x765
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go.(*connection).handlePacketImpl(0xc001d63800, {0xc001abee40, {0x1f12f68, 0xc001425a10}, {0xc12af18b6fc266cf, 0x88d317b02, 0x2b874e0}, {0xc0024f2c00, 0x4a, 0x5ac}, ...})
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/connection.go:849 +0x1a8
8月 03 14:52:29 NewCaddy caddy[1591605]: github.com/quic-go/quic-go.(*connection).run(0xc001d63800)
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/connection.go:560 +0x525
8月 03 14:52:29 NewCaddy caddy[1591605]: created by github.com/quic-go/quic-go.(*baseServer).handleInitialImpl
8月 03 14:52:29 NewCaddy caddy[1591605]:         github.com/quic-go/quic-go@v0.37.1/server.go:672 +0x7cd
8月 03 14:52:29 NewCaddy systemd[1]: caddy.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
8月 03 14:52:29 NewCaddy systemd[1]: caddy.service: Failed with result 'exit-code'.
8月 03 14:52:35 NewCaddy systemd[1]: caddy.service: Scheduled restart job, restart counter is at 6.
8月 03 14:52:35 NewCaddy systemd[1]: Stopped Caddy.
systemd service
Linux NewCaddy 5.15.0-58-generic #64~20.04.1-Ubuntu SMP Fri Jan 6 16:42:31 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
systemctl restart caddy
After=network.target
Restart=always
RestartSec=5
StartLimitIntervalSec=0
show below
plugins:
  1. GitHub - W0n9/caddy_waf_plugin
  2. GitHub - caddy-dns/duckdns: Caddy module: dns.providers.duckdns
Thanks; we’re currently trying to figure this out over in
I should note that we’re using 2.7.2 for this site and our main Caddy website with no issues. We haven’t been able to reproduce the problem.
If you restart your server (maybe even power-cycle) does the error still happen?
I have tried restart caddy and even reboot my server, it still have this problem.
I have rolled back to v2.6.4 now :cry:
