Static website not working, could not get certificate from issuer.
2023/02/26 20:13:14.334 ERROR http.acme_client challenge failed {"identifier": "legendsmp.minecraft.pe", "challenge_type": "http-01", "problem": {"type": "", "title": "", "detail": "", "instance": "", "subproblems": []}}
2023/02/26 20:13:14.334 ERROR http.acme_client validating authorization {"identifier": "legendsmp.minecraft.pe", "problem": {"type": "", "title": "", "detail": "", "instance": "", "subproblems": []}, "order": "https://acme.zerossl.com/v2/DV90/order/ug2m5O7yTqBXNeJvQM4T4Q", "attempt": 1, "max_attempts": 3}
2023/02/26 20:13:14.334 ERROR tls.obtain could not get certificate from issuer {"identifier": "legendsmp.minecraft.pe", "issuer": "acme.zerossl.com-v2-DV90", "error": "HTTP 0 - "}
2023/02/26 20:13:14.334 ERROR tls.obtain will retry {"error": "[legendsmp.minecraft.pe] Obtain: [legendsmp.minecraft.pe] solving challenge: legendsmp.minecraft.pe: [legendsmp.minecraft.pe] authorization failed: HTTP 0 - (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 5.36740649, "max_duration": 2592000}
caddy version 2.6.4
installation:
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy
ubuntu(most recent), caddy version 2.6.4
caddy start
Oracle Free Tier VM
legendsmp.minecraft.pe {
root * web
Please forgive me for any inconsistencies, and if you’re able to answer help please put suggestions in simple terms as I’m only 14. Thanks in advance ![]()
