wenkechen
(Wenke Chen)
June 29, 2023, 3:42pm
1
I have some API servers behind a entry server.
eg: api1:8080
, api2:8080
, api3:8080
There is a entry API server: api.demo.com
I want to foward request to different server by sub dir, eg:
https://api.demo.com/api1/api/v1/foo => api1:8080/api/v1/foo
https://api.demo.com/api2/api/v1/foo => api2:8080/api/v1/foo
https://api.demo.com/api3/api/v1/foo => api3:8080/api/v1/foo
But the following configuration doesn’t work
api.demo.com {
output file /var/log/api.access.log
@backend {
path_regexp backend ^/([^/]+)/(.+)
handle_path /{re.backend.1}/* {
reverse_proxy {re.backend.1}:8080
matt
(Matt Holt)
June 29, 2023, 5:53pm
2
Try this: handle_path @backend {
wenkechen
(Wenke Chen)
June 30, 2023, 4:15am
3
{"level":"info","ts":1688098398.0698562,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'handle_path': /etc/caddy/Caddyfile:29 - Error during parsing: path matcher must begin with '/', got @backend
I changed it to handle_path /@backend {
, still not work
matt
(Matt Holt)
June 30, 2023, 5:50am
4
That’s not what I typed Double check that
You can’t use handle_path
in that case, it only supports simple path matchers. It’s a shortcut for handle
+ uri strip_prefix
so it doesn’t support all matchers.
You can use the long form instead like this:
@backend path_regexp backend ^/([^/]+)/(.+)
handle @backend {
uri strip_prefix /{re.backend.1}
wenkechen
(Wenke Chen)
June 30, 2023, 6:41am
6
Thank you a lot !!!
This problem has bothered me for many days
matt
(Matt Holt)
June 30, 2023, 6:49am
7
Oh, oops. I totally forgot about that. Thanks Francis
system
(system)
Closed
July 30, 2023, 6:50am
8
