I have a 32GB RAM Machine running caddy, and I have noticed that it consumed a lot of memory (about 20GB, in comparison 2GB in the past) after a high traffic event.
And during the period of increased memory usage, it experienced up to 2000 QPS and about 35k Requests in flight due to a slow upstream.
I have collected some profile, but I can’t find the reason about the problem .
Maybe the function runtime.malg
have some memory leak? .
It seems no error logs.
Install — Caddy Documentation, using systemd to start it up.
Debian 12 with 32GB RAM and 8 cores.
StartLimitIntervalSec=0
Type=notify
Restart=always
RestartSec=5
MemoryMax=30G
order replace after encode
cert_issuer acme {
dir https://acme.zerossl.com/v2/DV90
eab <redacted>
dns duckdns <redacted>
dns_challenge_override_domain buct.duckdns.org
resolvers 223.5.5.5
servers {
metrics
(waf) {
route {
waf_chaitin {
waf_engine_addr 10.2.137.30:8000
initial_cap 8
max_idle 32
max_cap 64
idle_timeout 30
(to_web_cluster) {
reverse_proxy * {
to http://192.168.1.10 http://192.168.1.36
health_uri /main.htm
health_status 2xx
health_headers {
Host www.buct.edu.cn
(log) {
output file /var/log/caddy/{args[0]}.log {
roll_keep_for 48h
format filter {
wrap json
fields {
common_log delete
https://*.buct.edu.cn {
import log access
encode zstd gzip
request_body {
max_size 4GB
import waf
import to_web_cluster
@jwglxt-proxy4 host jwglxt-proxy4.buct.edu.cn
handle @jwglxt-proxy4 {
encode zstd gzip
import waf
rewrite /jwglxt/ /sso/jziotlogin
@Permit {
not remote_ip 10.0.0.0/8 172.16.0.0/12 192.168.0.0/16
reverse_proxy * {
to 121.195.154.186:80 121.195.154.187:80 121.195.154.188:80 121.195.154.189:80 121.195.154.190:80 121.195.154.191:80 121.195.154.192:80 121.195.154.193:80 121.195.154.194:80
header_up X-Real-IP 202.4.130.100
header_up X-Forwarded-For 202.4.130.100
header_up X-Forwarded-Port 80
header_up X-Forwarded-Proto http
header_down X-Backend-Server {http.reverse_proxy.upstream.host}
header_down X-Backend-Request-counts {http.reverse_proxy.upstream.requests}
lb_policy cookie lb buct_lb {
fallback ip_hash
keepalive_idle_conns_per_host 32
max_conns_per_host 64
reverse_proxy /WebReport* 121.195.154.186:8099 {
reverse_proxy @Permit {
header_down Location portal.buct.edu.cn experimental-auth-endpoint.buct.edu.cn
fallback ip_hash
replace {
stream
match {
header Content-Type application/json*
header Content-Type application/x-javascript*
header Content-Type text/*
http://121.195.154.186:8099/WebReport https://jwglxt-proxy4.buct.edu.cn/WebReport
################### the end ###############################
Caddy binary was compile with
xcaddy build \
--with github.com/caddy-dns/duckdns \
--with github.com/W0n9/caddy_waf_t1k@v0.0.5 \
--with github.com/caddyserver/replace-response \
--with github.com/chaitin/t1k-go=github.com/w0n9/t1k-go@v1.5.6
Profiles:
- Before high load: caddy_issues/caddy_memory_inuse_space_bytes_space_bytes_2024-12-26_0759-to-2024-12-26_0829.pb.gz at master · W0n9/caddy_issues · GitHub
- During high load: caddy_issues/caddy_memory_inuse_space_bytes_space_bytes_2024-12-26_1225-to-2024-12-26_1300.pb.gz at master · W0n9/caddy_issues · GitHub
- After high load: caddy_issues/caddy_memory_inuse_space_bytes_space_bytes_2024-12-27_1446-to-2024-12-27_1516.pb.gz at master · W0n9/caddy_issues · GitHub
