I just got a particular Caddy setup working after hours of trying out various things, and wanted to share. I was looking to have a fully Dockerized setup that puts Caddy behind a Cloudflare tunnel, while also allowing the cloudflared browser-based SSH to work.
First up is cloudflared - I’m using msnelling/cloudflared as the official image lacks ARM support. Most of my setup is based off of this tutorial, so you’ll have to follow that for the initial steps so far as creating a tunnel goes. Here are some of the files I’m using as well as some notes on what makes them work:
cloudflared
cloudflare/docker-compose.yml:
version: '3.4'
cloudflared:
image: msnelling/cloudflared
container_name: cloudflared
- ./config:/etc/cloudflared
# interpolate environment vars into config template to make config and then run
command: [sh, -c, ( echo "cat <<EOF" ; cat /etc/cloudflared/config.yml.template ; echo EOF ) | sh > /etc/cloudflared/config.yml && /usr/local/bin/cloudflared tunnel --no-autoupdate run]
env_file:
- .env
restart: always
extra_hosts:
- "host.docker.internal:host-gateway"
- cloudflared
cloudflared:
external: true
- Although
cloudflaredrequires aconfig.ymlof its own, it does not use environment variables for specified values at runtime. Since I want to be able to easily share/change my setup, I added a step to thecommandthat takes aconfig.yml.template, and interpolates in environment variables to create a finalconfig.ymlbeforecloudflaredis run within the container. - The
extra_hostsis required for SSH to work throughcloudflared, as a container binding to port 22 cannot otherwise be started while SSH’d into the server. The only alternatives I am aware of are:network_mode: host, which keeps you from putting thecloudflaredcontainer on any other networks and therefore makes it more difficult to send traffic to yourcaddycontainer- running
cloudflaredas a system service without Docker, which both makes sending traffic tocaddyharder and makes the system harder to transport
cloudflared/config/config.yml.template
tunnel: ${TUNNEL_UUID}
ingress:
# hostname for SSH, best as tname.domain.tld/ssh
- hostname: "${HOST_HOSTNAME}.${DOMAIN}"
service: ssh://host.docker.internal:22
# hostname for root domain in form domain.tld
- hostname: "${DOMAIN}"
service: https://caddy:443
originRequest:
originServerName: "${DOMAIN}"
# hostname for everything else in form *.domain.tld
- hostname: "*.${DOMAIN}"
originRequest:
- service: http_status:404
- The first ingress allows you to use SSH from a browser at
host_hostname.domain.tldas long as you’ve followed the other instructions in the aforementioned tutorial. This is where having theextra_hostsfrom our Compose file was necessary. - The second ingress proxies the root domain to our
caddycontainer. - The third ingress proxies all subdomains to our
caddycontainer. Note that theoriginServerNameis still justdomain.tldrather than including the subdomain (this one took me like an hour to figure out, since I know next to nothing about networking).
cloudflared/.env.template
TUNNEL_UUID=
DOMAIN=
HOST_HOSTNAME=
- These are the environment variables that will be interpolated into
config.yml.templateto make aconfig.yml.
Caddy
caddy/Dockerfile
ARG CADDY_VERSION=2.5.0
FROM caddy:${CADDY_VERSION}-builder AS builder
RUN xcaddy build \
--with github.com/lucaslorentz/caddy-docker-proxy/plugin \
--with github.com/greenpau/caddy-security
FROM caddy:${CADDY_VERSION}-alpine
CMD ["caddy", "docker-proxy"]
- Haven’t yet tagged the plugin versions but will do that soon.
caddy/docker-compose.yml
version: "3.9"
build:
context: .
dockerfile: Dockerfile
image: caddy:v2.5.0
labels:
caddy.acme_dns: "cloudflare {env.CF_API_TOKEN}"
caddy.email: "{env.EMAIL}"
- CADDY_INGRESS_NETWORKS=caddy
env_file:
- .env
- caddy
- cloudflared
# for caddy-docker-proxy to work
# for caddy itself
- ~/data/caddy/data:/data
- ~/data/caddy/config:/config
external: true
cloudflared:
external: true
- Goes on the
cloudflarednetwork to recieve traffic through the tunnel, while all of your application containers can go on just thecaddynetwork. - This also assumes that your DNS is through Cloudflare… which, if you’re using Cloudflare tunnels, it must be.
caddy/.env.template
CF_API_TOKEN=
EMAIL=
And that’s it! With caddy-docker-proxy as part of the image, every container on the caddy Docker network will get picked up and should “just work”.
