Hello, I’m wondering if there’s a way to get the actual IP of the client in my setup. I’m running Caddy and Cloudflare Tunnels (cloudflared) in LXC containers on Proxmox (doing a new install after moving Caddy away from Unraid). Each of the containers has their own IP.
I want to block certain domains to local access only or tailscale only (if possible) while leaving others free to be accessed by any IP range. Currently when accessing sites I get remote_ip and client_ip in logs as my Cloudflared LXC container’s IP.
Cloudflared LXC IP: 192.168.86.13
I’ve searched over the forums and google and tried multiple things but never was able to solve this. Gave up and now I’m here asking for help because it’s bugging me.
Just confirms what I’m seeing
2024/11/07 17:21:35.812 e[34mINFOe[0m http.log.access.log2 handled request {"request": {"remote_ip": "192.168.86.13", "remote_port": "52486", "client_ip": "192.168.86.13", "proto": "HTTP/1.1", "method": "GET", "host": "test.domain.com", "uri": "/", "headers": {"Connection": ["keep-alive"], "Dnt": ["1"], "Priority": ["u=0, i"], "Upgrade-Insecure-Requests": ["1"], "Accept-Language": ["en-US,en;q=0.9"], "Cf-Ipcountry": ["US"], "Cf-Visitor": ["{\"scheme\":\"https\"}"], "Sec-Fetch-Mode": ["navigate"], "Sec-Fetch-User": ["?1"], "Cache-Control": ["max-age=0"], "Cf-Warp-Tag-Id": ["f984e815-8ffe-4030-b167-bffba16c5ccd"], "Sec-Ch-Ua": ["\"Chromium\";v=\"130\", \"Google Chrome\";v=\"130\", \"Not?A_Brand\";v=\"99\""], "Cf-Ray": ["8def00251ba03b8c-IAD"], "Sec-Ch-Ua-Platform": ["\"macOS\""], "X-Forwarded-Proto": ["https"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/130.0.0.0 Safari/537.36"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8"], "Sec-Ch-Ua-Mobile": ["?0"], "Sec-Fetch-Dest": ["document"], "Sec-Fetch-Site": ["none"], "X-Forwarded-For": ["173.163.124.234"], "Accept-Encoding": ["gzip, br"], "Cdn-Loop": ["cloudflare; loops=1"], "Cf-Connecting-Ip": ["173.163.124.234"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "", "server_name": "test.domain.com"}}, "bytes_read": 0, "user_id": "", "duration": 0.043235828, "size": 5, "status": 200, "resp_headers": {"Content-Type": ["text/plain; charset=utf-8"], "Server": ["Caddy"], "Alt-Svc": ["h3=\":443\"; ma=2592000"], "Referrer-Policy": ["strict-origin"], "Strict-Transport-Security": ["max-age=31536000; includeSubDomains;"], "X-Content-Type-Options": ["nosniff"], "X-Frame-Options": ["SAMEORIGIN"], "X-Robots-Tag": ["noindex, nofollow, nosnippet, noarchive"]}}
Running Caddy v2.8.4
LXC container running Debian 12.
Ran using this script: ProxmoxVE/install/caddy-install.sh at main · community-scripts/ProxmoxVE · GitHub (the commands of interest are below)
curl -1sLf 'https://dl.cloudsmith.io/public/caddy/stable/gpg.key' | gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf 'https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt' >/etc/apt/sources.list.d/caddy-stable.list
apt-get update
apt-get install -y caddy
Type=notify
email caddy@domain.com
servers {
trusted_proxies cloudflare
client_ip_headers CF-Connecting-IP
(security_headers) {
Strict-Transport-Security "max-age=31536000; includeSubDomains;"
X-Frame-Options "SAMEORIGIN"
Referrer-Policy "strict-origin"
X-Robots-Tag "noindex, nofollow, nosnippet, noarchive"
(log_settings) {
output file /var/log/caddy/caddylog.log {
roll_size 10MiB
roll_keep 2
roll_keep_for 72h
level DEBUG
format console
(cloudflare) {
dns cloudflare <token>
(simple_lb) {
lb_policy first
lb_try_duration 5s
lb_try_interval 250ms
fail_duration 10s
max_fails 1
unhealthy_status 5xx
unhealthy_latency 5s
unhealthy_request_count 1
import log_settings
root * /usr/share/caddy
*.domain.com {
import cloudflare
import log_settings
import security_headers
@test host test.domain.com
handle @test {
respond "Works."
abort
Searched all over looking for people with similar-ish problems (including the most recent help topic) but they rarely had the same setup and tried their working solutions but nothing worked for me so far.
