PREFACE: I have my own custom caddy build with xcaddy with the cloudflare DNS module installed on my server as a service and starts and runs fine and gets my certificates from the DNS challenge from my CF account just fine with my credentials. Recently, I have been wanting to run caddy in a docker container instead, but I am not able to receive my cert due to the DNS challenge failing and I am not sure why. I am using the same API token from my CF account that I use for my caddy binary on my server and works fine, but trying it within docker gives me a weird issue for some reason. I have listed below what I am doing for my docker build and what the error is.
1. Caddy version (caddy version): Caddy v2.5.0
Created my custom docker image using a dockerfile with:
FROM caddy:2.5.0-builder AS builder
RUN xcaddy build --with github.com/caddy-dns/cloudflare --with github.com/greenpau/caddy-trace
FROM caddy:2.5.0
Image builds fine and I am able to use it on my server no problem. Everything starts.
I build on my laptop for my pi, (armv7 userland)
docker buildx build --platform linux/arm/v7 -f Dockerfile . -t azoller12/caddy
Here is my system:
OS: Raspbian GNU/Linux 11 (bullseye) aarch64
Host: Raspberry Pi 4 Model B Rev 1.4
Kernel: 5.15.33-v8+
CPU: BCM2835 (4) @ 1.800GHz
Memory: 795MiB / 1892MiB
docker compose file, compose.yml:
default:
image: azoller12/custom-caddy:2.5.0
- 443:443
- /home/alexz/docker/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/alexz/docker/caddy/site:/srv
- /home/alexz/docker/caddy/caddy_data:/data
- /home/alexz/docker/caddy/caddy_config:/config
All of my volumes have proper permissions for the root user. The logs don’t indicate any permission issues.
Caddyfile snippet of TLS challenge:
*.azollerhome.xyz {
# disable FLoC tracking
Permissions-Policy interest-cohort=()
# enable HSTS
Strict-Transport-Security max-age=31536000
# clickjacking protection
X-Frame-Options DENY
protocols tls1.3
dns cloudflare custom_api_token
@home host home.azollerhome.xyz
handle @home {
reverse_proxy localhost:81
Error Message/Logs (Docker logs)
This error message continually loops.
2022-05-01T08:04:24.585226785Z {"level":"error","ts":1651392264.5849605,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.azollerhome.xyz","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.azollerhome.xyz] solving challenges: presenting for challenge: adding temporary record for zone xyz.: got error status: HTTP 403: [{Code:9109 Message:Invalid access token}] (order=https://acme-v02.api.letsencrypt.org/acme/order/519669747/84827465237) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2022-05-01T08:04:24.586578341Z {"level":"info","ts":1651392264.5864255,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.azollerhome.xyz"],"ca":"https://acme.zerossl.com/v2/DV90","account":"alexzoller1@protonmail.com"}
2022-05-01T08:04:24.586637210Z {"level":"info","ts":1651392264.586479,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.azollerhome.xyz"],"ca":"https://acme.zerossl.com/v2/DV90","account":"alexzoller1@protonmail.com"}
^[[<0;42;16m2022-05-01T08:05:06.972162480Z {"level":"info","ts":1651392306.9718812,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.azollerhome.xyz","challenge_type":"dns-01","ca":"https://acme.zerossl.com/v2/DV90"}
2022-05-01T08:05:08.259174582Z {"level":"error","ts":1651392308.2571886,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.azollerhome.xyz","challenge_type":"dns-01","error":"no memory of presenting a DNS record for azollerhome.xyz (probably OK if presenting failed)"}
2022-05-01T08:05:21.396422100Z {"level":"error","ts":1651392321.3961182,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.azollerhome.xyz","issuer":"acme.zerossl.com-v2-DV90","error":"[*.azollerhome.xyz] solving challenges: presenting for challenge: adding temporary record for zone xyz.: got error status: HTTP 403: [{Code:9109 Message:Invalid access token}] (order=https://acme.zerossl.com/v2/DV90/order/sl8lhveAS3-T2EXxAmUMrw) (ca=https://acme.zerossl.com/v2/DV90)"}
2022-05-01T08:05:21.396534839Z {"level":"error","ts":1651392321.3962412,"logger":"tls.obtain","msg":"will retry","error":"[*.azollerhome.xyz] Obtain: [*.azollerhome.xyz] solving challenges: presenting for challenge: adding temporary record for zone xyz.: got error status: HTTP 403: [{Code:9109 Message:Invalid access token}] (order=https://acme.zerossl.com/v2/DV90/order/sl8lhveAS3-T2EXxAmUMrw) (ca=https://acme.zerossl.com/v2/DV90)","attempt":1,"retrying_in":60,"elapsed":58.005679197,"max_duration":2592000}
Things I have tried
- I have a CAA rule to only allow certs from
letsencrypt.org. I even turned this off but still did not help. - I have created new API keys twice to no avail. Using the same API key that I use for my binary caddy service on my host didn’t work even when it works if I do not use docker. The API token has Zone.DNS Edit and Zone.Zone Read rights.
- I have also just used the global “Zone API” token for my account to use and did not work either.
I am just confused to why it says "Invalid access token" when that same token works with my Caddyfile outside of docker. I am not sure what is happening here.
When I run docker exec caddy caddy list-modules it shows the cloudflare dns module was successfully built:
tls.issuance.acme
tls.issuance.internal
tls.issuance.zerossl
tls.stek.distributed
tls.stek.standard
Standard modules: 95
dns.providers.cloudflare
http.handlers.trace
Non-standard modules: 2
Unknown modules: 0
