Caddy causes http error 502 (connect: connection refused)
I have a small test setup: a VPS with 3 docker containers: nginx, php8-fpm and caddy. I have a domain name that points to the VPS IP with an A record and a CNAME record for the www subdomain.
I want the Caddy container to send all requests from 80 and 443 to the nginx container. Requests for both the naked domain and www subdomain reach Caddy but the browser page and logs show status 502 and connection refused.
Error for www:
{"level":"error","ts":1708205138.2808132,"logger":"http.log.error","msg":"dial tcp 172.25.0.3:9999: connect: connection refused","request":{"remote_ip":"86.125.245.170","remote_port":"58418","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"www.mapq.org","uri":"/","headers":{"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-User":["?1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Encoding":["gzip, deflate, br"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["none"],"Te":["trailers"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"www.mapq.org"}},"duration":0.004002846,"status":502,"err_id":"g6tgn343s","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
Error for naked domain:
{"level":"error","ts":1708205271.8090503,"logger":"http.log.error","msg":"dial tcp 172.25.0.3:9999: connect: connection refused","request":{"remote_ip":"86.125.245.170","remote_port":"20819","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"mapq.org","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["none"],"Te":["trailers"],"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-User":["?1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mapq.org"}},"duration":0.002894735,"status":502,"err_id":"jgaxjq4i0","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
Full debug for www::
{"level":"debug","ts":1708205138.2291155,"logger":"events","msg":"event","name":"tls_get_certificate","id":"14fb1c4f-ad2a-48dd-a3fe-c5300ce321f3","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],"ServerName":"www.mapq.org","SupportedCurves":[29,23,24,25,256,257],"SupportedPoints":"AA==","SignatureSchemes":[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"86.125.245.170","Port":58418,"Zone":""},"LocalAddr":{"IP":"172.25.0.2","Port":443,"Zone":""}}}}
{"level":"debug","ts":1708205138.2296107,"logger":"tls.handshake","msg":"choosing certificate","identifier":"www.mapq.org","num_choices":1}
{"level":"debug","ts":1708205138.2296846,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"www.mapq.org","subjects":["www.mapq.org"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"cfb0e8661cb491e7b6fa8b8029f52d7d08192306b9c10894887a0f8da73bfa81"}
{"level":"debug","ts":1708205138.2297025,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"86.125.245.170","remote_port":"58418","subjects":["www.mapq.org"],"managed":true,"expiration":1715971578,"hash":"cfb0e8661cb491e7b6fa8b8029f52d7d08192306b9c10894887a0f8da73bfa81"}
{"level":"debug","ts":1708205138.276901,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"test-php-nginx-web-server-1:9999","total_upstreams":1}
{"level":"debug","ts":1708205138.279826,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"test-php-nginx-web-server-1:9999","duration":0.001933431,"request":{"remote_ip":"86.125.245.170","remote_port":"58418","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"www.mapq.org","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"X-Forwarded-Host":["www.mapq.org"],"Te":["trailers"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-For":["86.125.245.170"],"X-Forwarded-Proto":["https"],"Sec-Fetch-Site":["none"],"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"Sec-Fetch-Dest":["document"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"www.mapq.org"}},"error":"dial tcp 172.25.0.3:9999: connect: connection refused"}
{"level":"debug","ts":1708205138.699084,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"test-php-nginx-web-server-1:9999","total_upstreams":1}
{"level":"debug","ts":1708205138.699791,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"test-php-nginx-web-server-1:9999","duration":0.000015286,"request":{"remote_ip":"86.125.245.170","remote_port":"58418","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"www.mapq.org","uri":"/favicon.ico","headers":{"X-Forwarded-For":["86.125.245.170"],"X-Forwarded-Proto":["https"],"Te":["trailers"],"Accept":["image/avif,image/webp,*/*"],"Referer":["https://www.mapq.org/"],"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["no-cors"],"X-Forwarded-Host":["www.mapq.org"],"Sec-Fetch-Dest":["image"],"Sec-Fetch-Site":["same-origin"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"www.mapq.org"}},"error":"context canceled"}
Full debug for naked domain:
{"level":"debug","ts":1708205271.7507212,"logger":"events","msg":"event","name":"tls_get_certificate","id":"eb3fbe6c-927c-42cb-b7c4-c68c1029069d","origin":"tls","data":{"client_hello":{"CipherSuites":[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],"ServerName":"mapq.org","SupportedCurves":[29,23,24,25,256,257],"SupportedPoints":"AA==","SignatureSchemes":[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"86.125.245.170","Port":20819,"Zone":""},"LocalAddr":{"IP":"172.25.0.2","Port":443,"Zone":""}}}}
{"level":"debug","ts":1708205271.7512536,"logger":"tls.handshake","msg":"choosing certificate","identifier":"mapq.org","num_choices":1}
{"level":"debug","ts":1708205271.7513387,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"mapq.org","subjects":["mapq.org"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"d715bf065d9d0cc1ad435eb6e062ad76c3081146e374dbb531ece85b6b5a9784"}
{"level":"debug","ts":1708205271.7513757,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"86.125.245.170","remote_port":"20819","subjects":["mapq.org"],"managed":true,"expiration":1715954471,"hash":"d715bf065d9d0cc1ad435eb6e062ad76c3081146e374dbb531ece85b6b5a9784"}
{"level":"debug","ts":1708205271.8063219,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"test-php-nginx-web-server-1:9999","total_upstreams":1}
{"level":"debug","ts":1708205271.8084307,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"test-php-nginx-web-server-1:9999","duration":0.001445347,"request":{"remote_ip":"86.125.245.170","remote_port":"20819","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"mapq.org","uri":"/","headers":{"Sec-Fetch-Dest":["document"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"X-Forwarded-For":["86.125.245.170"],"X-Forwarded-Host":["mapq.org"],"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-User":["?1"],"Upgrade-Insecure-Requests":["1"],"Te":["trailers"],"Sec-Fetch-Site":["none"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-Proto":["https"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mapq.org"}},"error":"dial tcp 172.25.0.3:9999: connect: connection refused"}
{"level":"debug","ts":1708205272.2034175,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"test-php-nginx-web-server-1:9999","total_upstreams":1}
{"level":"debug","ts":1708205272.2043493,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"test-php-nginx-web-server-1:9999","duration":0.000013632,"request":{"remote_ip":"86.125.245.170","remote_port":"20819","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"mapq.org","uri":"/favicon.ico","headers":{"Referer":["https://mapq.org/"],"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"X-Forwarded-Proto":["https"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"],"Accept":["image/avif,image/webp,*/*"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["no-cors"],"X-Forwarded-For":["86.125.245.170"],"Sec-Fetch-Dest":["image"],"Sec-Fetch-Site":["same-origin"],"Te":["trailers"],"X-Forwarded-Host":["mapq.org"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mapq.org"}},"error":"context canceled"}
curl command for http:
radu@winubuntu:/mnt/c/Cloud/Projects/php/caddy-proxy$ curl -vL mapq.org
*   Trying 162.19.226.144:80...
* Connected to mapq.org (162.19.226.144) port 80 (#0)
> GET / HTTP/1.1
> Host: mapq.org
> User-Agent: curl/7.81.0
< Connection: close
< Location: https://mapq.org/
< Server: Caddy
< Date: Sat, 17 Feb 2024 21:45:57 GMT
< Content-Length: 0
* Closing connection 0
* Issue another request to this URL: 'https://mapq.org/'
*   Trying 162.19.226.144:443...
* Connected to mapq.org (162.19.226.144) port 443 (#1)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Finished (20):
* TLSv1.2 (OUT), TLS header, Supplemental data (23):
*  subject: CN=mapq.org
*  start date: Feb 17 14:01:11 2024 GMT
*  expire date: May 17 14:01:10 2024 GMT
*  subjectAltName: host "mapq.org" matched cert's "mapq.org"
* Using Stream ID: 1 (easy handle 0x55cd0248aeb0)
> GET / HTTP/2
> Host: mapq.org
> user-agent: curl/7.81.0
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Sat, 17 Feb 2024 21:45:57 GMT
* Connection #1 to host mapq.org left intact
curl command for https:
radu@winubuntu:/mnt/c/Cloud/Projects/php/caddy-proxy$ curl -vL https://mapq.org
* Connected to mapq.org (162.19.226.144) port 443 (#0)
* ALPN, offering h2
* Using Stream ID: 1 (easy handle 0x55775e732eb0)
> GET / HTTP/2
> Host: mapq.org
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Sat, 17 Feb 2024 21:46:43 GMT
* Connection #0 to host mapq.org left intact
v2.7.6
First I installed nginx and php from the official images with docker compose:
default.conf
server {
    index index.php index.html;
    server_name localhost;
    error_log  /var/log/nginx/error.log;
    access_log /var/log/nginx/access.log;
    root /var/www/html;
    location ~ \.php$ {
        try_files $uri =404;
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_pass php:9000;
        fastcgi_index index.php;
        include fastcgi_params;
        fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
        fastcgi_param PATH_INFO $fastcgi_path_info;
docker-compose.yml
version: '3.9'
  web-server:
    image: nginx:latest
      - '9998:80'
      - '9999:433'
      - ./app:/var/www/html
      - ./default.conf:/etc/nginx/conf.d/default.conf
    depends_on:
      - php
  php:
    image: php:8-fpm
./app folder contains just an index.php file with the phpinfo() function.
Then I installed Caddy.
Caddyfile
    email aaa@bbb.ccc
mapq.org, www.mapq.org {
    reverse_proxy https://test-php-nginx-web-server-1:9999
and I tried also with http (but the same result):
    email aaa@bbb.ccc
    reverse_proxy http://test-php-nginx-web-server-1:9998
docker-compose.yml
version: '3'
  proxy:
    image: caddy
      - web-apps-network
      - ./data/:/data/
      - ./config/:/config/
  web-apps-network:
I added the nginx and php containers to the same network as caddy.
These are the containers:
CONTAINER ID   IMAGE                           COMMAND                  CREATED             STATUS          PORTS        NAMES
cc37f9b0c3bb   nginx:latest                    "/docker-entrypoint.…"   About an hour ago   Up 46 minutes   0.0.0.0:9998->80/tcp, :::9998->80/tcp, 0.0.0.0:9999->443/tcp, :::9999->443/tcp                   test-php-nginx-web-server-1
1379dc63f359   caddy                           "caddy run --config …"   7 hours ago         Up 37 minutes   0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp, 443/udp, 2019/tcp      caddy-proxy-1
28b82d164850   php:8-fpm                       "docker-php-entrypoi…"   8 hours ago         Up 46 minutes   9000/tcp        test-php-nginx-php-1
This is the common network:
        "Name": "caddy_web-apps-network",
        "Id": "0a9607eb6a5854d33b7e8964ebf52bff14cb4b39b10e7e62c7d4954fa8661df0",
        "Created": "2024-02-17T13:39:00.302830467Z",
        "Scope": "local",
        "Driver": "bridge",
        "EnableIPv6": false,
        "IPAM": {
            "Driver": "default",
            "Options": null,
            "Config": [
                    "Subnet": "172.25.0.0/16",
                    "Gateway": "172.25.0.1"
        "Internal": false,
        "Attachable": false,
        "Ingress": false,
        "ConfigFrom": {
            "Network": ""
        "ConfigOnly": false,
        "Containers": {
            "1379dc63f3593d15c40f5e2985ab6280fefe716e0c693576bf47f38550ad7508": {
                "Name": "caddy-proxy-1",
                "EndpointID": "c714ca58b39da002ecb6bbe83244d97eb4e2c2bebf21e83ed17ac0c37f3e3887",
                "MacAddress": "02:42:ac:19:00:02",
                "IPv4Address": "172.25.0.2/16",
                "IPv6Address": ""
            "28b82d164850e9577f0248b8cb9052c57be4a81c0cb57436946b0f137021cd9d": {
                "Name": "test-php-nginx-php-1",
                "EndpointID": "074069d701e8f85121065080c53b7445b7ef1640d6e02b031cccebe335d77291",
                "MacAddress": "02:42:ac:19:00:04",
                "IPv4Address": "172.25.0.4/16",
                "IPv6Address": ""
            "cc37f9b0c3bba4efccb5fca2ded68de4730f431ec6775aa44f7ba54acafbb666": {
                "Name": "test-php-nginx-web-server-1",
                "EndpointID": "4f782eb232a87311bbc6082f51a9283c80223611899b1de43a0307fb079cb24d",
                "MacAddress": "02:42:ac:19:00:03",
                "IPv4Address": "172.25.0.3/16",
                "IPv6Address": ""
        "Options": {},
        "Labels": {
            "com.docker.compose.network": "web-apps-network",
            "com.docker.compose.project": "caddy",
            "com.docker.compose.version": "2.24.5"
OS: Ubuntu 23.04
Docker version: 25.0.2, build 29cf629
See above.
See above.
    email aaa@bbb.ccc
and
    email aaa@bbb.ccc
Why are you using nginx? You can serve PHP from Caddy:
But anyway, your problem is that you’re trying to proxy to the port you published to the host. Networking between Docker containers uses the internal ports. So you’d need to proxy to port 80, not 9999.
Thanks for the tip about Caddy serving PHP files, I will check that, I’m new to both Caddy and Docker. I thought Caddy is just a proxy server.
I reloaded Caddy with the changed port:
    reverse_proxy https://test-php-nginx-web-server-1:443
However the problem persists:
{"level":"debug","ts":1708211724.3816175,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"test-php-nginx-web-server-1:443","total_upstreams":1}
{"level":"debug","ts":1708211724.3837872,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"test-php-nginx-web-server-1:443","duration":0.002070624,"request":{"remote_ip":"86.125.245.170","remote_port":"21995","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"mapq.org","uri":"/","headers":{"Sec-Fetch-Site":["none"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-For":["86.125.245.170"],"X-Forwarded-Proto":["https"],"Sec-Fetch-User":["?1"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"],"Accept-Encoding":["gzip, deflate, br"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"X-Forwarded-Host":["mapq.org"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"Te":["trailers"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mapq.org"}},"error":"dial tcp 172.25.0.3:443: connect: connection refused"}
{"level":"error","ts":1708211724.3838663,"logger":"http.log.error","msg":"dial tcp 172.25.0.3:443: connect: connection refused","request":{"remote_ip":"86.125.245.170","remote_port":"21995","client_ip":"86.125.245.170","proto":"HTTP/2.0","method":"GET","host":"mapq.org","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:122.0) Gecko/20100101 Firefox/122.0"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Mode":["navigate"],"Te":["trailers"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Language":["ro,en-US;q=0.7,en;q=0.3"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Dest":["document"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"mapq.org"}},"duration":0.002369192,"status":502,"err_id":"z8xkrdt32","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
I tried again with port 80 and http instead of port 443 and http:
    reverse_proxy http://test-php-nginx-web-server-1:80
And it works, the problem is solved.
Thank you!
If possible, can you tell me why https and 443 didn’t work? From what I read, I should use https because if I specifically set http it will not redirect to 443 (but it still does redirect now with http).
For HTTPS to work between servers, the upstream needs a valid, trusted TLS certificate. Setting that up is complicated, and has no benefit. Caddy can’t trust the cert from nginx, so the connection fails.
You only need HTTPS over public networks (i.e. over the public internet). There’s no reason to use HTTPS between docker containers. The point is to encrypt traffic over networks that you don’t trust, but you do trust the connection between your containers. Also HTTPS adds overhead because it needs to perform a TLS handshake which is wasteful between containers.
Caddy is a general purpose HTTP server. It can do anything you need with HTTP, including serving static files and proxying to php-fpm.
