docker latest v2 alpine Docker Hub
OS:
Distributor ID: Ubuntu
Description: Ubuntu 20.04.4 LTS
Release: 20.04
Codename: focal
docker version:
Client: Docker Engine - Community
Version: 20.10.14
API version: 1.41
Go version: go1.16.15
Git commit: a224086
Built: Thu Mar 24 01:48:02 2022
OS/Arch: linux/amd64
Context: default
Experimental: true
Server: Docker Engine - Community
Engine:
Version: 20.10.14
API version: 1.41 (minimum version 1.12)
Git commit: 87a90dc
Built: Thu Mar 24 01:45:53 2022
Experimental: false
containerd:
Version: 1.5.11
GitCommit: 3df54a852345ae127d1fa3092b95168e4a88e2f8
runc:
Version: 1.0.3
GitCommit: v1.0.3-0-gf46b6ba
docker-init:
Version: 0.19.0
GitCommit: de40ad0
see next section for docker command
docker run -d --name caddy -v /etc/Caddyfile:/etc/caddy/Caddyfile -v /etc/caddy:/root/.local/share/caddy --net host --restart on-failure caddy/caddy:alpine
subdomain.personaldomain.net {
reverse_proxy 127.0.0.1:9998
basicauth {
username bcrypt_base64_encoded_pass
I’m having an issue with the basicauth to my internal service. For some reason there is a login prompt loop that occurs.
tested on: on mobile (haven’t seemed to experience the issue on PC) iPhone chrome browser and safari tested. Latest app versions and iOS. On chrome and safari, it log me in to my service but then when I click around on the website, it prompts me to login again, however I can hit cancel or I can enter the login username/pass and gain access again.
no errors in the logs.
I’ve tried searching google, which the auto fill shows that people are searching for this same problem - but no relevant forum posts show up in the results.
I tried looking at caddy logs but literally nothing shows up there.
I think I’m setting up the basicauth correctly based on various examples I’ve found.
