Hi. So this is my first time messing around with both Nginx and Caddy so please forgive me if this is a dumb question.
I have a supabase setup that uses docker with multiple containers and an webpage that allows me to view my database. I want this page to have basicauth. The nginx config that I have works fine in terms of requiring a password when visiting the site. Caddy requires a password but it also blocks request between the site and the server even though the site is hosted from the server.
Can anyone explain where my logic is flawed or point me in the right direction? I want to understand what’s going on. I’m guessing there’s something extra Caddy or Nginx is doing behind the scenes like blocking or allowing internal requests with basicauth?
Caddyfile
https://example.com {
reverse_proxy /rest/v1/* localhost:8000
reverse_proxy /auth/v1/* localhost:8000
reverse_proxy /realtime/v1/* localhost:8000
reverse_proxy /storage/v1/* localhost:8000
reverse_proxy * localhost:3000
basicauth /* {
admin <HASH generated from caddy hash-passwrd>
Nginx config
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream supabase {
server localhost:3000;
upstream kong {
server localhost:8000;
server {
server_name example.com;
# REST
location ~ ^/rest/v1/(.*)$ {
proxy_set_header Host $host;
proxy_pass http://kong;
proxy_redirect off;
# AUTH
location ~ ^/auth/v1/(.*)$ {
proxy_redirect off;
# REALTIME
location ~ ^/realtime/v1/(.*)$ {
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
# STORAGE
location ~ ^/storage/v1/(.*)$ {
proxy_redirect off;
# STUDIO
location / {
proxy_pass http://supabase;
proxy_redirect off;
auth_basic "Administrator’s Area";
auth_basic_user_file /etc/apache2/.htpasswd;
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/example.com/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/example.com/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = example.com) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
Requests made to /rest/v1/
come back with 401 error. If I turn off basicauth, all is fine.
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy
Unbuntu 22.04
b. Command to start caddy:
sudo systemctl restart caddy
