2.4.1.
I am using Caddy (besides others) as a reverse proxy to the SCM Manager, a web frontend for managing SVN, Mercurial and GIT repositories.
Kubuntu 21.04/x64 (bare metal, no virtualisation)
I am trying to check out one of my repositories from my company’s workstation:
hg clone https://scm.xxxxxxx.de/repo/scmadmin/blog-contents
"admin":
"disabled": false,
"config":
"persist": false
"logging":
"sink":
"writer":
"output": "file",
"filename": "/opt/caddy/logs/sink.log",
"roll": true,
"roll_size_mb": 100,
"roll_local_time": true,
"roll_keep": 0,
"roll_keep_days": 0
"logs":
"default":
"writer":
"output": "file",
"filename": "/opt/caddy/logs/caddy.log",
"roll": true,
"roll_keep": 0,
"roll_keep_days": 0
"level": "info",
"encoder": { "format": "json" }
"storage":
"module": "file_system",
"root": "/opt/caddy/store"
"apps":
"http":
"grace_period": "5s",
"servers":
"all":
"listen":
"[::]:80",
"[::]:443"
"routes":
"group": "site selection",
"match":
"host": [ "www.yyyyyyyy.de", "der.yyyyyyyy.de" ]
"handle":
"handler": "file_server",
"root": "/opt/caddy/sites/yyyyyyyy/cur",
"index_names": [ "index.html", "index.xml" ]
"match":
"host": [ "www.zzzzzzzz.de" ]
"handle":
"root": "/opt/caddy/sites/zzzzzzzz",
"index_names": [ "index.html" ]
"match":
"host": [ "scm.xxxxxxx.de" ]
"handle":
"handler": "reverse_proxy",
"transport":
"protocol": "http",
"compression": false,
"versions": ["1.1"]
"upstreams":
"dial": "[::1]:1080"
"handle":
"root": "/opt/caddy/sites/default",
"logs":
"default_logger_name": "default"
The problem is that despite the configuration, caddy attempts to connect the downstream server (SCM Manager) via HTTPS. But this happens only if I connect from my company’s workstation. From within my home network or from a direct connection from outside, everything works fine.
Setup:
workstation in the company
-> proxy (195.253.xxx.xxx)
-> home router with NAT
-> caddy (192.168.1.9:443)
-> scm manager (::1:1080)
Software versions:
- workstation:
OS: Kubuntu 21.04/x64,
Mercurial: 5.6.1
- Proxy: Squid 4.10
- Host of caddy/scm manager:
Caddy: 2.4.1
SCM Manager: 2.18.0
1st exchange
workstation:
communication between proxy and caddy:
tcpflow -c -D -i any port 443 (on 192.168.1.9)
195.253.xxx.xxx.36318-192.168.001.009.00443:
0000: 1603 0102 0001 0001 fc03 0377 ddd1 579f eea5 e699 ac1f 2d50 67da 810a 19c5 f656 ...........w..W.......-Pg......V
0020: e1c5 db07 267f 50fe 002a 8e20 0c51 2219 9be2 db41 0312 41b3 ac34 f8e7 2f3c 0944 ....&.P..*. .Q"....A..A..4../<.D
...515 bytes in total
192.168.001.009.00443-195.253.xxx.xxx.36318:
0000: 1603 0300 7a02 0000 7603 034c eeb8 6114 a518 bb9a 6efa bc73 0cc4 cb89 e335 4e34 ....z...v..L..a.....n..s.....5N4
0020: 75e8 72d1 dda6 994e fcc4 4320 0c51 2219 9be2 db41 0312 41b3 ac34 f8e7 2f3c 0944 u.r....N..C .Q"....A..A..4../<.D
...quite a lot of data
communication between caddy and scm manager:
tcpflow -c -D -i any port 1080
::1.60586-::1.01080:
0000: 4745 5420 2f72 6570 6f2f 7363 6d61 646d 696e 2f62 6c6f 672d 636f 6e74 656e 7473 GET /repo/scmadmin/blog-contents
0020: 3f63 6d64 3d63 6170 6162 696c 6974 6965 7320 4854 5450 2f31 2e31 0d0a 486f 7374 ?cmd=capabilities HTTP/1.1..Host
0040: 3a20 7363 6d2e xxxx xxxx xxxx xx2e 6465 0d0a 5573 6572 2d41 6765 6e74 3a20 6d65 : scm.xxxxxxx.de..User-Agent: me
0060: 7263 7572 6961 6c2f 7072 6f74 6f2d 312e 3020 284d 6572 6375 7269 616c 2035 2e36 rcurial/proto-1.0 (Mercurial 5.6
0080: 2e31 290d 0a41 6363 6570 743a 2061 7070 6c69 6361 7469 6f6e 2f6d 6572 6375 7269 .1)..Accept: application/mercuri
00a0: 616c 2d30 2e31 0d0a 4163 6365 7074 2d45 6e63 6f64 696e 673a 2069 6465 6e74 6974 al-0.1..Accept-Encoding: identit
00c0: 790d 0a58 2d46 6f72 7761 7264 6564 2d46 6f72 3a20 3139 352e 3235 332e 322e 3135 y..X-Forwarded-For: 195.253.2.15
00e0: 300d 0a58 2d46 6f72 7761 7264 6564 2d50 726f 746f 3a20 6874 7470 730d 0a0d 0a 0..X-Forwarded-Proto: https....
::1.01080-::1.60586:
0000: 4854 5450 2f31 2e31 2034 3031 2055 6e61 7574 686f 7269 7a65 640d 0a57 5757 2d41 HTTP/1.1 401 Unauthorized..WWW-A
0020: 7574 6865 6e74 6963 6174 653a 2042 6173 6963 2072 6561 6c6d 3d22 534f 4e49 4120 uthenticate: Basic realm="SONIA
0040: 3a3a 2053 434d 204d 616e 6167 6572 220d 0a43 6163 6865 2d43 6f6e 7472 6f6c 3a20 :: SCM Manager"..Cache-Control:
0060: 6d75 7374 2d72 6576 616c 6964 6174 652c 6e6f 2d63 6163 6865 2c6e 6f2d 7374 6f72 must-revalidate,no-cache,no-stor
0080: 650d 0a43 6f6e 7465 6e74 2d4c 656e 6774 683a 2030 0d0a 5365 7276 6572 3a20 4a65 e..Content-Length: 0..Server: Je
00a0: 7474 7928 392e 342e 3335 2e76 3230 3230 3131 3230 290d 0a0d 0a tty(9.4.35.v20201120)....
caddy log entry:
{"level":"error","ts":1623700858.5017047,"logger":"http.log.access.default","msg":"handled request","request":{"remote_addr":"195.253.xxx.xxx:36318","proto":"HTTP/1.1","method":"GET","host":"scm.xxxxxxx.de","uri":"/repo/scmadmin/blog-contents?cmd=capabilities","headers":{"Accept":["application/mercurial-0.1"],"User-Agent":["mercurial/proto-1.0 (Mercurial 5.6.1)"],"Accept-Encoding":["identity"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"scm.xxxxxxx.de"}},"common_log":"195.253.xxx.xxx - - [14/Jun/2021:22:00:58 +0200] \"GET /repo/scmadmin/blog-contents?cmd=capabilities HTTP/1.1\" 401 0","duration":0.002265057,"size":0,"status":401,"resp_headers":{"Server":["Caddy","Jetty(9.4.35.v20201120)"],"Www-Authenticate":["Basic realm=\"SONIA :: SCM Manager\""],"Cache-Control":["must-revalidate,no-cache,no-store"],"Content-Length":["0"]}}
2nd exchange
Mercurial dialog:
http authorization required for https://scm.xxxxxxx.de/repo/scmadmin/blog-contents
realm: SONIA :: SCM Manager
user: klaus
password:
abort: HTTP Error 502: Bad Gateway
195.253.xxx.xxx.36324-192.168.001.009.00443:
0000: 1603 0102 0001 0001 fc03 032d d68d 57bf 6d69 c900 fe1f dd72 714e bfc5 2d63 e5b8 ...........-..W.mi.....rqN..-c..
0020: abc2 c69b a18d 362e d204 3d20 25b3 34cf e1cf c163 e34e 65ea e0a8 5319 a028 77f7 ......6...= %.4....c.Ne...S..(w.
0040: 48c7 3411 19e3 6b7f 2568 4617 003e 1302 1303 1301 c02c c030 009f cca9 cca8 ccaa H.4...k.%hF..>.......,.0........
0060: c02b c02f 009e c024 c028 006b c023 c027 0067 c00a c014 0039 c009 c013 0033 009d .+./...$.(.k.#.'.g.....9.....3..
0080: 009c 003d 003c 0035 002f 00ff 0100 0175 0000 0013 0011 0000 0e73 636d 2exx xxxx ...=.<.5./.....u.........scm.xxx
00a0: xxxx xxxx 2e64 6500 0b00 0403 0001 0200 0a00 0c00 0a00 1d00 1700 1e00 1900 1800 xxxx.de.........................
00c0: 2300 0000 1600 0000 1700 0000 0d00 2a00 2804 0305 0306 0308 0708 0808 0908 0a08 #.............*.(...............
00e0: 0b08 0408 0508 0604 0105 0106 0103 0303 0103 0204 0205 0206 0200 2b00 0504 0304 ..........................+.....
0100: 0303 002d 0002 0101 0033 0026 0024 001d 0020 b6e1 e1d5 97e3 fb10 7a69 a2b7 8d2b ...-.....3.&.$... ........zi...+
0120: 17d4 6592 64c8 2e74 34dc 7ca5 d44b 1b14 7400 0015 00cf 0000 0000 0000 0000 0000 ..e.d..t4.|..K..t...............
0140: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ................................
0160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ................................
0180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ................................
01a0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ................................
01c0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ................................
01e0: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 ................................
0200: 0000 0000 00 .....
192.168.001.009.00443-195.253.xxx.xxx.36324:
0000: 1603 0300 7a02 0000 7603 0353 97d2 902e b45f 8ce8 14e1 46d5 90f9 a981 8ef1 dcd8 ....z...v..S....._....F.........
0020: 7e59 1e5f e55c e815 fba0 dc20 25b3 34cf e1cf c163 e34e 65ea e0a8 5319 a028 77f7 ~Y._.\..... %.4....c.Ne...S..(w.
0040: 48c7 3411 19e3 6b7f 2568 4617 1301 0000 2e00 2b00 0203 0400 3300 2400 1d00 204b H.4...k.%hF.......+.....3.$... K
0060: 3060 9170 e2d5 2cc0 7c43 6297 8a86 3cbc a653 e584 e326 beb7 c978 1ca6 7efd 7614 0`.p..,.|Cb...<..S...&...x..~.v.
0080: 0303 0001 0117 0303 0017 7778 42a6 45c8 f5fe 304e 2273 46f4 0d52 c40c a912 27be ..........wxB.E...0N"sF..R....'.
00a0: 6c17 0303 0eff fd78 8d0d 4ba1 0547 c7e1 796a 2698 293f ac40 abe2 4a82 5178 e701 l......x..K..G..yj&.)?.@..J.Qx..
00c0: 5079 3a1d 0bfc a045 7ea2 405c c221 e3fe e883 16c0 f55b d49f 3906 d334 db83 d858 Py:....E~.@\.!.......[..9..4...X
00e0: a409 6669 522a 834a f34c 355e c800 767d e1d9 fe60 d5b0 87f2 5cb3 69e3 4797 8c06 ..fiR*.J.L5^..v}...`....\.i.G...
::1.60588-::1.01080:
0000: 1603 0100 ee01 0000 ea03 0377 8425 bb66 6353 5028 6667 f371 67af ea30 383f a89d ...........w.%.fcSP(fg.qg..08?..
0020: 644b de8b 3d9e 0418 33b7 e620 e013 1332 d36a 353c 703b 75cb 121a c44a 05c7 fba6 dK..=...3.. ...2.j5<p;u....J....
0040: a047 3c7e ce12 b218 f413 a4ed 0026 c02f c030 c02b c02c cca8 cca9 c013 c009 c014 .G<~.........&./.0.+.,..........
0060: c00a 009c 009d 002f 0035 c012 000a 1301 1303 1302 0100 007b 0005 0005 0100 0000 ......./.5.............{........
0080: 0000 0a00 0a00 0800 1d00 1700 1800 1900 0b00 0201 0000 0d00 1a00 1808 0404 0308 ................................
00a0: 0708 0508 0604 0105 0106 0105 0306 0302 0102 03ff 0100 0100 0012 0000 002b 0009 .............................+..
00c0: 0803 0403 0303 0203 0100 3300 2600 2400 1d00 20ab 0752 ae96 d4b9 7cec eb1c 947b ..........3.&.$... ..R....|....{
00e0: 5d0b c1a5 f369 1c3d 775d 1a75 1a7c 0a9f e86c 6b ]....i.=w].u.|...lk
::1.01080-::1.60588:
0000: 4854 5450 2f31 2e31 2034 3030 2049 6c6c 6567 616c 2063 6861 7261 6374 6572 2043 HTTP/1.1 400 Illegal character C
0020: 4e54 4c3d 3078 3136 0d0a 436f 6e74 656e 742d 5479 7065 3a20 7465 7874 2f68 746d NTL=0x16..Content-Type: text/htm
0040: 6c3b 6368 6172 7365 743d 6973 6f2d 3838 3539 2d31 0d0a 436f 6e74 656e 742d 4c65 l;charset=iso-8859-1..Content-Le
0060: 6e67 7468 3a20 3730 0d0a 436f 6e6e 6563 7469 6f6e 3a20 636c 6f73 650d 0a53 6572 ngth: 70..Connection: close..Ser
0080: 7665 723a 204a 6574 7479 2839 2e34 2e33 352e 7632 3032 3031 3132 3029 0d0a 0d0a ver: Jetty(9.4.35.v20201120)....
00a0: 3c68 313e 4261 6420 4d65 7373 6167 6520 3430 303c 2f68 313e 3c70 7265 3e72 6561 <h1>Bad Message 400</h1><pre>rea
00c0: 736f 6e3a 2049 6c6c 6567 616c 2063 6861 7261 6374 6572 2043 4e54 4c3d 3078 3136 son: Illegal character CNTL=0x16
00e0: 3c2f 7072 653e </pre>
caddy log entries:
{"level":"error","ts":1623700861.3709624,"logger":"http.log.error.default","msg":"tls: first record does not look like a TLS handshake","request":{"remote_addr":"195.253.xxx.xxx:36324","proto":"HTTP/1.1","method":"GET","host":"scm.xxxxxxx.de","uri":"https://scm.xxxxxxx.de/repo/scmadmin/blog-contents?cmd=capabilities","headers":{"Authorization":["Basic xxxxxxxxxxxxxxx"],"User-Agent":["mercurial/proto-1.0 (Mercurial 5.6.1)"],"Accept-Encoding":["identity"],"Accept":["application/mercurial-0.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"scm.xxxxxxx.de"}},"duration":0.001667712,"status":502,"err_id":"cf1w2ce0e","err_trace":"reverseproxy.statusError (reverseproxy.go:861)"}
{"level":"error","ts":1623700861.3710773,"logger":"http.log.access.default","msg":"handled request","request":{"remote_addr":"195.253.xxx.xxx:36324","proto":"HTTP/1.1","method":"GET","host":"scm.xxxxxxx.de","uri":"https://scm.xxxxxxx.de/repo/scmadmin/blog-contents?cmd=capabilities","headers":{"Accept-Encoding":["identity"],"Accept":["application/mercurial-0.1"],"Authorization":["Basic xxxxxxxxxxxxxxx"],"User-Agent":["mercurial/proto-1.0 (Mercurial 5.6.1)"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"scm.xxxxxxx.de"}},"common_log":"195.253.xxx.xxx - - [14/Jun/2021:22:01:01 +0200] \"GET https://scm.xxxxxxx.de/repo/scmadmin/blog-contents?cmd=capabilities HTTP/1.1\" 502 0","duration":0.001667712,"size":0,"status":502,"resp_headers":{"Server":["Caddy"]}}
