Hello, I would like to use Caddy Server as a reverse proxy with automatic HTTPS. Is it possible to do it? For example, I would like to points my domains to one IP address (the one where Caddy Server is installed) and point to another server server IP. How can I do it?
v2.7.6
I did follow this guide to install Caddy:
sudo apt update
sudo apt install caddy
Ubuntu 22.04 LTS
