Caddy as reverse proxy with duckdns package
Windows amd64 v2.4.0-beta.1
Using Caddyfile
Windows 10
./caddy run
n/a
azurmv.duckdns.org {
                dns duckdns abc-abc-abc-abc-abc
        reverse_proxy localhost: 8096
Configuring Caddy as reverse proxy using DNS-01 challenge for DuckDns is failing
2021/03/31 20:11:47.084 ←[34mINFO←[0m   using adjacent Caddyfile
[WARNING][caddyfile] Caddyfile:1: input is not formatted with 'caddy fmt'
2021/03/31 20:11:47.091 ←[34mINFO←[0m   admin   admin endpoint started  {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2021/03/31 20:11:47.092 ←[34mINFO←[0m   tls.cache.maintenance   started background certificate maintenance      {"cache": "0xc0002bbf10"}
2021/03/31 20:11:47.092 ←[34mINFO←[0m   http    server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/03/31 20:11:47.092 ←[34mINFO←[0m   http    enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2021/03/31 20:11:47.093 ←[34mINFO←[0m   http    enabling automatic TLS certificate management   {"domains": ["azurmv.duckdns.org"]}
2021/03/31 20:11:47.094 ←[34mINFO←[0m   tls     cleaned up storage units
2021/03/31 20:11:47.096 ←[34mINFO←[0m   autosaved config        {"file": "C:\\Users\\And\\AppData\\Roaming\\Caddy\\autosave.json"}
2021/03/31 20:11:47.097 ←[34mINFO←[0m   serving initial configuration
2021/03/31 20:11:47.108 ←[34mINFO←[0m   tls.obtain      acquiring lock  {"identifier": "azurmv.duckdns.org"}
2021/03/31 20:11:47.117 ←[34mINFO←[0m   tls.obtain      lock acquired   {"identifier": "azurmv.duckdns.org"}
2021/03/31 20:11:47.129 ←[34mINFO←[0m   tls.issuance.acme       waiting on internal rate limiter        {"identifiers": ["azurmv.duckdns.org"]}
2021/03/31 20:11:47.130 ←[34mINFO←[0m   tls.issuance.acme       done waiting on internal rate limiter   {"identifiers": ["azurmv.duckdns.org"]}
2021/03/31 20:11:48.303 ←[34mINFO←[0m   tls.issuance.acme.acme_client   trying to solve challenge       {"identifier": "azurmv.duckdns.org", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2021/03/31 20:11:50.600 ←[31mERROR←[0m  tls.issuance.acme.acme_client   cleaning up solver      {"identifier": "azurmv.duckdns.org", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for azurmv.duckdns.org (probably OK if presenting failed)"}
2021/03/31 20:11:50.783 ←[34mINFO←[0m   tls.issuance.acme       waiting on internal rate limiter        {"identifiers": ["azurmv.duckdns.org"]}
2021/03/31 20:11:50.783 ←[34mINFO←[0m   tls.issuance.acme       done waiting on internal rate limiter   {"identifiers": ["azurmv.duckdns.org"]}
2021/03/31 20:11:52.491 ←[34mINFO←[0m   tls.issuance.acme.acme_client   trying to solve challenge       {"identifier": "azurmv.duckdns.org", "challenge_type": "dns-01", "ca": "https://acme.zerossl.com/v2/DV90"}
2021/03/31 20:11:53.608 ←[31mERROR←[0m  tls.issuance.acme.acme_client   cleaning up solver      {"identifier": "azurmv.duckdns.org", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for azurmv.duckdns.org (probably OK if presenting failed)"}
2021/03/31 20:11:54.035 ←[31mERROR←[0m  tls.obtain      will retry      {"error": "[azurmv.duckdns.org] Obtain: [azurmv.duckdns.org] solving challenges: presenting for challenge: adding temporary record for zone duckdns.org.: DuckDNS request failed, expected (OK) but got (KO), url: [https://www.duckdns.org/update?domains=org.duckdns.org&token=abc-abc-abc-abc-abc&txt=3uyr6BglN1r5L-5qECvj408-JI9bv0lD6Pzor4C8Tpg&verbose=true], body: KO (order=https://acme.zerossl.com/v2/DV90/order/er6EGeHX_3VBNechqWKMiA) (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 6.9176337, "max_duration": 2592000}
For me is strange that the specified domain is org.duckdns.org
I’ve generated my own certificate using acme.sh client, which has been added to the Caddyfile.
Could you try again, building with v2.4.0-beta.2, which was just released last night?
same problem here. lack skills to build caddy by myself.
2021/04/12 15:34:47.606 e[31mERRORe[0m  tls.obtain      will retry      {"error": "[temptest.duckdns.org] Obtain: [temptest.duckdns.org] solving challenges: presenting for challenge: adding temporary record for zone duckdns.org.: DuckDNS request failed, expected (OK) but got (KO), url: [https://www.duckdns.org/update?domains=org.duckdns.org&token=b4cd5684-8f81-49af-a6bc-be9b53c16ec7&txt=dU61Lr4P93v-JezDMYUbuAObAjgV62PLL6S1zxz5Ows&verbose=true], body: KO (order=https://acme.zerossl.com/v2/DV90/order/Y-ThW_VjUcoSxcM9m0KbKQ) (ca=https://acme.zerossl.com/v2/DV90)", "attempt": 1, "retrying_in": 60, "elapsed": 36.5961613, "max_duration": 2592000}
@ivan just follow these instructions:
tried : xcaddy build --with github.com/caddy-dns/duckdns
in china,the authority blocked golang.org,so i set system proxy,still got this error.
2021/04/13 12:16:25 [INFO] Pinning versions
2021/04/13 12:16:25 [INFO] exec (timeout=0s): C:\Program Files\Go\bin\go.exe get -d -v github.com/caddyserver/caddy/v2
go get: module github.com/caddyserver/caddy/v2: Get "https://proxy.golang.org/github.com/caddyserver/caddy/v2/@v/list": dial tcp 172.217.160.113:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2021/04/13 12:16:46 [FATAL] exit status 1
any ideas?
I don’t know what platform you’re on, but you could try this link (uses the Download Caddy page, build server):
https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com/caddyserver/caddy/v2@v2.4.0-beta.2&p=github.com/caddy-dns/duckdns&idempotency=52564368580212
thx man,im on windows,this command solved it.
$env:GOPROXY = "https://goproxy.io,direct"
xcaddy build v2.4.0-beta.2 --with github.com/caddy-dns/duckdns
So are you saying that the problem doesn’t exist when using v2.4.0-beta.2 compared to v2.3.0 @ivan ?
yes,but compared to v2.4.0-beta.1,
v2.4.0-beta.1, got same error as amv’s.
v2.4.0-beta.2` works fine.
thx again.
