caddy:2-alpine
i run caddy through docker-compose, but in different files for different project. Right now I try to run a portainer alongside it. Those are the compose files:
docker on linux
docker-compose up -d
Caddy
version: '3.9'
image: caddy:2-alpine
- certs-volume:/data
- caddy_config:/config
certs-volume:
caddy_config:
default:
external:
and the portainer file
version: '3.9'
portainer:
image: portainer/portainer-ce
container_name: portainer
restart: always
- portainer_data:/data portainer/portainer
entrypoint: /portainer -p :80
- "1000:80"
portainer_data:
default:
external:
Caddyfile
email simonheiss87@gmail.com
smallhetzi.fading-flame.com {
reverse_proxy portainer:1000
The certificates are being generated fine, this is working, but when i call the url, I get a 502 because caddy can not connect to the portainer container.
"level": "error",
"ts": 1629873106.715402,
"logger": "http.log.error",
"msg": "dial tcp 172.20.0.2:1000: connect: connection refused",
"request": {
"remote_addr": "89.247.255.231:15146",
"proto": "HTTP/2.0",
"method": "GET",
"host": "smallhetzi.fading-flame.com",
"uri": "/",
"headers": {
"Accept-Encoding": [
"gzip, deflate, br"
"Accept-Language": [
"de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"
"Cache-Control": [
"max-age=0"
"User-Agent": [
"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/92.0.4515.159 Safari/537.36"
"Sec-Fetch-Site": [
"none"
"Accept": [
"text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"
"Sec-Fetch-Mode": [
"navigate"
"Sec-Fetch-User": [
"?1"
"Sec-Fetch-Dest": [
"document"
"Sec-Ch-Ua": [
"\"Chromium\";v=\"92\", \" Not A;Brand\";v=\"99\", \"Google Chrome\";v=\"92\""
"Sec-Ch-Ua-Mobile": [
"?0"
"1"
"tls": {
"resumed": false,
"version": 772,
"cipher_suite": 4865,
"proto": "h2",
"proto_mutual": true,
"server_name": "smallhetzi.fading-flame.com"
"duration": 0.000580828,
"status": 502,
"err_id": "pq78d9hen",
"err_trace": "reverseproxy.statusError (reverseproxy.go:857)"
When I replace the Caddyfile with something like that:
Caddyfile
reverse_proxy 65.21.139.246:1000
everything works fine, but I dont want to spread my IP over the Caddyfile. Is there something I am missing for docker environments? I also tried other versions, with http:// in front or making it in the same compose file, but that did not work either.
